- 11 May 2011
Hello there.
I installed my first pc and as I have expected something had to go wrong.
As soon as I try to opened it the monitor would not get recognised for a few times. Then when it did, there were some flickering in the bios image and then when i logged on to Windows the flickering began more intense creating disstorted images and then filling my screen with some vertical lines.
The recomendations I got was that my video card was faulty. I send it back and they told me that the card is working fine at their workstation.
Now my concern is i think the RAM installed are not compatible with my motherboard.
Here is the links below:
Motherboard - Asus P8P67 LE
RAM - OCZ Special Ops
When I go into my motherboards specification it states that it support this kind of RAM: x4 1.5v DDR3 DIMM Sockets
When i look at the Ram Specification is says this:- 1.55-1.65 Volts
Can someone tell me if my motherboard and ram are compatible?
And also can this be the cause of my problems?
Thanks In Advance
Thanks In Advance
