Grab these fantastic deals at vastly reduced prices. We have plenty of stock to go around so no worries
Gigabyte GK-K6800 Multimedia Keyboard @ £9.98 inc VAT
The Gigabyte GK-K6800 is an attractive keyboard designed especially for seeking trendsetting users.
Fashion and contemporary bright-black design of outlook is perfectly for any working space.
- USB Interface
- 14 Function Keys
- Membrane switches
- Dimensions: 467 x 205 x 31mm
Was £10.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
OCZ Vertex 3 240GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-240G) @ £399.98 inc VAT
As the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 240GB
- Controller: SandForce SF-2281
- Maximum Read: 550MB/sec
- Maximum Write: 525MB/sec
- Sustained Write: 525MB/sec
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £424.99 Inc. VAT
Only £399.98 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £219.98 inc VAT
- Capacity: 120GB
- Maximum Write: 500MB/sec
- Sustained Write: 500MB/sec
- Warranty: 3 Years
Was £249.98 Inc. VAT
Only £219.98 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £65.99 inc VAT
nonl2br
<br>
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels. <br>
<br>
- Real 5.1 Surround sound with speakers aligned at a 12° angle<br>
- Microphone with mute LED fully rotatable and completely removable<br>
- Tip’N’Control desktop remote for central management of all volume functions<br>
- Dual sound-profile with movie and game settings<br>
- Solid aluminium hinges enabling heavy duty use<br>
- Hand-sewn comfortable earcups featuring external noise cancelling<br>
- Adjustable vibration unit for a realistic gaming experience <br>
- Headband with three pads for equal weight distribution<br>
- Easy to carry folding and compact design <br>
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/125bfd1f2f2cc9251cc512dfde5e4fb1.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/f620e869ce025933aeef18e4d0fd3894.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/798d360d6701787365c7266f8cf96fbe.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/48545abd6c12c63d38c082c343da0099.jpg">
Was £67.99 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
"Primo Drone" AMD Athlon II X2 Dual Core 250 3.00GHz DDR3 System @ £269.98 inc VAT
The "Primo Drone" offers the performance needed for home and business use at a low price. The AMD Athlon II X2 Dual Core 250 3.00GHz combined with 4GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience.
Why You Should Buy This System?
- AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) offers multitasking performance.
- 500GB Seagate Barracuda hard drive gives a solid and reliable storage capacity.
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
System Specification
- Case: OcUK EZCool NA-705 microATX case - Black
- Power Supply: OcUK Value 500W PSU
- CPU: AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3)
- Motherboard: AMD nForce 630a (Socket AM2+/AM3) DDR3 Motherboard
- RAM: 4GB DDR3 1333MHz Dual Channel Kit
- Hard Drive: Western Digital Caviar Blue 500GB SATA 6GB/s
- Graphics Card: Onboard integrated NVIDIA GeForce 7025 GPU
- Sound: ALC662 6-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Compact, reliable and smart. The "Primo Drone" give you everything you need in a entry level home/business system.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £279.97 Inc. VAT
Only £269.98 inc VAT.
ORDER NOW
"Primo Ignition" Intel Core i3 550 3.20GHz DDR3 System @ £369.97 inc VAT
The "Primo Ignition" features a Intel Core i3 550 3.20GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
- Intel Core i3 540 3.06GHz (Clarkdale) Processer with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: OcUK EZCool NA-705 microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 550 3.20GHz (Clarkdale)
- Motherboard: Intel H55 (Socket 1156) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo Ignition" is perfect for the user looking for a highperformance system for a low price.
Was £389.98 Inc. VAT
Only £369.97 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - Black @ £33.98 inc VAT
nonl2br
The TT Esports Gamers Headset Shock brings gaming to a new level. Immerse deeply into your games with 40mm speaker drivers and stereo surround sound. Take advantage of your soundcard with 3.5mm speaker jacks bringing maximum sound performance. The ultra comfortable padded earcups make sure that comfort is key, especially for intense professional gaming. <br><br>
- Stereo surround sound<br>
- Quality 40mm speaker driver with enhanced bass performance<br>
- Noise cancelling microphone for communciation in gaming activities<br>
- Control Box with In-line control box for instant gaming sound control<br>
- 10 Levels adjustment for a perfect fit<br>
- Foldable design<br>
- Gold plated 3.5mm connctor<br>
<br>
<br>
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/2gampqTGEf8" frameborder="0" allowfullscreen></iframe>
Was £37.98 Inc. VAT
Only £33.98 inc VAT.
ORDER NOW
Corsair Enthusiast Series TX 650W V2 High Performance Power Supply (CMPSU-650TXV2UK) @ £69.98 inc VAT
The Enthusiast Series TX V2 is part of Corsair’s best price-performance range of power supplies, designed to meet the exacting standards and performance needs of demanding enthusiasts. TX Series power supplies are ideal for performance enthusiasts who require an affordable, high-wattage, reliable and highly efficient PSU. Corsair TX V2 Series PSUs are compatible with the latest Intel and AMD platforms and NVIDIA and AMD multi-graphics configurations.
- The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80PLUS Bronze certified, delivering up to 85% energy efficiency at real world load conditions.
- Active Power Factor Correction (PFC) with PF value of 0.99
- Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
- A dedicated single +12V rail offers maximum compatibility with the latest components
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
- High-quality Japanese capacitors provide uncompromised performance and reliability
- A five year warranty and lifetime access to Corsair¡¦s legendary technical support and customer service
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
Was £74.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Cooler Master GX 450w Power Supply @ £45.98 inc VAT
Cooler Master is electrifying gamers PCs with the new GX-series, specifically targeted at systems in the upper-mid to high-end range, yet reasonably priced, providing users with unsurpassed cost per performance. The Cooler Master GX Series of power supplies feature a single highly robust 12 V rail, proficiently delivering power to the most demanding components including the processor, drives, cooling fans and even the most intense dual graphic cards, such as the SLI or CrossFireX. Now including a double-layer EMI Filter, an intelligent 120 mm controllable fan and an active PFC/PWM combo controller for increased efficiency, the GX Series will keep the power in your hands.
- Compliance with the latest Intel standard ATX 12V V 2.31
- Single 12V rail for most demanding SLI configurations
- High efficiency design that meets 80plus requirements (85% typical)
- Ultra-silent operation with intelligent 120mm fan speed control
- Multiple protection design
- High reliability
- Huge bulk capacitor for hold time up >17ms at full loading
- Integrated Active PFC with PWM
- Efficient transformer
- Five year warranty
Was £47.99 Inc. VAT
Only £45.98 inc VAT.
ORDER NOW
Steelseries 5H v2 Stereo Gaming Headset - Black @ £49.99 inc VAT
Steelseries 5H v2 - trust your senses. A truly remarkable professional gaming headset. Every detail and aspect has been designed and developed in cooperation with the best gamers in the world. The sound quality is awe-inspiring, allowing gamers to rely fully on their senses. The headset features a pull-out microphone attached to the right cup; the microphone metal goose neck is covered in high quality transparent plastic to ensure durability. The headset can be disassembled into three separate parts to ensure safe and easy transportation.
- Pull-out microphone system
- Custom engineered soundscape for gaming
- Specifically optimized for FPS games
- Comfortable XL-sized ear cushions
- Features extra durable braided cord
- Can be dismantled into 3 separate pieces
Was £51.98 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
"Titan Nero" AMD Athlon II X2 Dual Core 250 3.00GHz DDR3 System @ £279.98 inc VAT
The "Titan Nero" offers the performance needed for home and business use at a low price. The AMD Athlon II X2 Dual Core 250 3.00GHz combined with 4GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience. With HDMI output the "Titan Nero" is more than capable of being a efficient home entertainment system.
- Seagate 500GB SATA-II 16MB Cache
- Case: Coolermaster Elite 335 - Black
- Power Supply: OCZ 500w StealthXStream II
- Motherboard: AMD 880G (Socket AM3) DDR3 Motherboard
- Graphics Card: Onboard AMD Graphics
- Sound: ALC888B 8-channel High Definition Audio CODEC
Service Package
Designed for the gamer who doesn't have a massive budget, yet expects quality gaming performance. The "Titan Nero" is the ultimate entry level gaming system.
Was £299.98 Inc. VAT
Only £279.98 inc VAT.
ORDER NOW
Cooler Master Storm Enforcer Gaming Case - Black @ £67.98 inc VAT
This new chassis contains a wealth of features coveted by most gaming enthusiasts, including USB 3.0, SSD drive support and a removable/rotatable HDD cage to support easy installation of the highest end video cards.
CM Storm has come up with a design that not only meets the expectations of its customer base, enthusiasts and esports prodigies, but does so within a price range that all will appreciate.
- Front I / O Panel with USB 3.0 (internal)
- Tool - free for 5.25” device
- Dust Filters on bottom and front intakes
- Cable management for better cable routing
- Reinforced front door protects your vital devices
- Supports rear internal 120mm water cooling radiator
- Removable & Rotatable HDD cage for convenient installation
- Support high-end graphics cards including ATI Radeon HD 5970
- Storm Guard - security system for safeguarding your gaming peripherals
- Motherboard: Micro-ATX & ATX
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- 4 x 2.5" Drive Bays
- Front I/O Ports: USB3.0 x 2 / USB2.0 x 2 / Audio x 2
- Front Cooling: 1 x 200mm Red LED fan 1000RPM @ 19dBA
- Rear Cooling: 1 x 120mm Black fan 1200 rPM @ 17dBA
- Top Cooling: 1 x 200mm fan (optional)
- Side Cooling: 1 x 120mm fan (optional)
- Expansion Slots: 7+1
- Max CPU Cooler: 175mm
- Max GPU Size: 390mm
Was £75.98 Inc. VAT
Only £67.98 inc VAT.
ORDER NOW
Plantronics GameCom 377 Gaming Headset (79731-05) @ £22.99 inc VAT
Because your hardware should be as powerful as your gaming skills, the GameCom 377 gaming hedset delivers rugged construction and vigorous sound. A lightweight frame and specially designed ear pods redistribute pressure for maximum comfort, while the open-ear design lets you catch all the in-game sound effects without losing touch with your surroundings. When you’re ready to fire off orders, unveil the hidden, noise-cancelling microphone boom to strategise clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls. When you’re done, rotate and tuck the microphone boom inside the headset - then let your score do the talking.
- Open-ear design keeps you connected to the game and your surroundings.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-like design and extra-strength cables make your hardware hardcore.
Was £25.98 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
"Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System @ £709.98 inc VAT
Stalking through the jungle, the "Titan Spinosaur" is master of all. Featuring the Intel Core i5 2500K overclocked to a ridiculous 4.60Ghz, you can enjoy ultra smooth framerates and an immersive computing experience. With a choice of the latest DX11 graphics cards, equip yourself ready for the hunt ahead with the best offering from both Nvidia and ATI.
- A guaranteed 4.60GHz performance for the price of 3.30GHz
- Choose from a selection of graphics cards to meet your performance needs
- Precision built and cabled by Overclockers UK expert technicians
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Antec 300 Case with Purple LED Fans
- Power Supply: OCZ StealthXStream 700W
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Corsair H50 CPU Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit w/ 8GB Option available
- Graphics Card: Choice of DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Heighten your gaming experience with the "Titan Spinosaur", stalk your prey down and demolish the competition. Equipped with either ATI or Nvidia, become a champion.
Was £789.98 Inc. VAT
Only £709.98 inc VAT.
ORDER NOW
"Titan Onyx" Intel Core i7 950 3.06GHz @ 4.00GHz Quad Core DDR3 System @ £765.97 inc VAT
The "Titan Onyx" features an Intel Core i7 950 3.06GHz processor overclocked and guaranteed to a stable 4.00GHz. With a high overclock and DX11 graphics the "Titan Onyx" has a complete set of high end features straight out of the box. Everything you could ever want combined into one complete system.
Why Should You Buy This System?
- A guaranteed 4.00GHz performance for the price of 3.06GHz
- DX11 performance provided from the very latest graphics cards
- 6GB of 1600MHz DDR3 Triple Channel memory allows faster loading of games and better multi-tasking
- Case: Xigmatek Asgard Midi Tower - Black
- Power Supply: OCZ StealthXStream II 600w
- CPU: Intel Core i7 950 3.06GHz Overclocked to 4.00GHz
- Motherboard: Intel X58 (Socket 1366) DDR3 Motherboard
- Cooler: Corsair H70 CPU Cooler
- RAM: 6GB DDR3 1600MHz Tri-Channel
- Hard Drive: Seagate Barracuda 1TB 32MB Cache
- Graphics Card: A choice of the latest graphics cards
- Sound: 7.1 Channel Sound (On-Board)
Service Package
The "Titan Onyx" provides fantastic performance unseen at this price before. With all the features you could possibly dream of.
Was £789.97 Inc. VAT
Only £765.97 inc VAT.
ORDER NOW
"Ultima Thunderbolt" AMD Phenom II X6 1090T 3.20GHz @ 4.00GHz DDR3 System @ £1,175.99 inc VAT
The "Ultima Thunderbolt" features an AMD Phenom II X6 Six Core 1090T overclocked and guaranteed to a stable 4.00GHz. With six processing cores and dual channel DDR3 memory the "Ultima Thunderbolt" powers through applications and games with equal ease. Designed for gaming on the edge, the "Ultima Thunderbolt" delivers blistering performance and amazing DX11 visuals from the ATI 6970 2GB graphics card, with a crossfire option available for the real hardcore.
- A guaranteed 4.00GHz performance for the price of 2.80GHz
- Six Core processing and DX11 performance.
- USB 3.0 compatible system
- Case: Coolermaster HAF X
- Power Supply: OCZ ZX Series 850W '80 Plus Gold Certified' Modular Power Supply
- CPU: AMD Phenom II X6 Six Core 1090T 3.20Ghz overclocked to 4.00Ghz
- Motherboard: Asus Crosshair IV Motherboard
- RAM: 8GB DDR3 1600MHz
- Hard Drive: Seagate Barracuda 1TB HDD
- Graphics Card: ATI 6970 2048MB Graphics Card
- Sound: Asus Xonar DG 7.1 Sound Card
Service Package
Annihilate all with AMD six core. The "Ultima Thunderbolt" provides unrelenting performance at an amazing price.
Was £1,199.99 Inc. VAT
Only £1,175.99 inc VAT.
ORDER NOW
Xenon AMD Phenom II X4 840 3.20GHz Bundle - Quad Core @ £154.98 inc VAT
Designed by experts the "Xenon AMD Phenom II 840 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X4 840 Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
Bundle Specification
- CPU: AMD Phenom II X4 Quad Core 840 "95W Edition" 3.20GHz
- Motherboard: Gigabyte GA-M68MT-S2 (Socket AM3) DDR3 Motherboard
- RAM: 4GB (2x2GB) DDR3 1600MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £164.98 Inc. VAT
Only £154.98 inc VAT.
ORDER NOW
Logitech G930 7.1 Surround Sound Wireless Headset (981-000258) @ £133.99 inc VAT
Level up without being tied down. Gaming-grade wireless gives you a lag-free, interference-resistant connection with a range of up to 12 metres (40 feet) - so nothing stands between you and victory. 7.1 surround sound powered by Dolby technology delivers a detailed, positional soundfield that lets you hear your opponents before they see you. You'll have total command over music, voice morphing, chat clients and more with three programmable G-keys. And a memory foam-lined headband fends off fatigue, while plush ear pads ease pressure points and seal out unwanted noise.
- Gaming-grade wireless performance
- 7.1 surround sound
- Three programmable G-keys
- Memory foam-lined headband
Was £136.99 Inc. VAT
Only £133.99 inc VAT.
ORDER NOW
Argon Extreme Intel Core i3 550 3.20GHz @ 4.40GHz Overclocked Bundle @ £245.98 inc VAT
Designed by experts the "Argon Extreme Intel Core i3 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed to power through the latest games with ease. The "Argon Extreme Intel Core i3 Bundle" offers superb gaming performance at an excellent price.
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- CPU: Intel Core i3 550 3.20GHz @ 4.40GHz
- Motherboard: Gigabyte GA-H55M-UD2H (Socket 1156) DDR3 Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Artic Cooling Freezer 7 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Was £269.98 Inc. VAT
Only £245.98 inc VAT.
ORDER NOW
Krypton AMD Phenom II X6 1090T Black Edition 3.20GHz @ 4.00GHz Overclocked Bundle @ £399.98 inc VAT
Designed by experts the "Krypton AMD Phenom II X6 1090T Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- SATA 6Gb/s and USB 3.0 compatible offering lightning fast transfer speeds
- CPU: AMD Phenom II X6 1090T Black Edition 3.20GHz @ 4.00GHz
- Motherboard: Asus Crosshair IV Formula AMD 890FX (Socket AM3) DDR3 Motherboard
- Cooler: Akasa Nero S CPU Cooler (Upgrade options available)
Service Package
Was £419.98 Inc. VAT
ORDER NOW
Roccat Pyra Wireless Mobile Gaming Mouse @ £21.98 inc VAT
The ROCCAT™ Pyra Mobile Wireless Gaming Mouse offers everything you’d typically expect from an ingenious mobile gaming mouse in a compact design – and it does it all completely wirelessly. With the same polling rate as a wired mouse (1000Hz) and sensor performance that can be adjusted from 400dpi to 1600dpi, the Pyra packs a punch by offering judder-free gaming with zero lag. What’s more, its ergonomic shape makes it comfortable to use.
World first: The Pyra is the first product to feature the innovative EasyShift[+] button, which doubles the number of mouse functions.
- Wireless Compact USB Gaming Mouse
- Easyshift Button Duplicator (doubling the buttons functions)
- Motion Blue-Optic Sensor
- Adjustable DPI; 400,800 or 1600
- 1000Hz polling rate
- Roccat Griptech featuring stabilizing, non-slip side grips
- Wide, Non-Slip Mousewheel
- Left or Right Handed
- Soft Travel Case included
Was £24.98 Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
Microsoft LifeCam Cinema HD 720p Widescreen Webcam (H5D-00003) @ £36.98 inc VAT
Share every detail with friends and family in HD. This full featured webcam, with true 720p HD video, delivers smooth, detailed video and crystal clear audio. Giving you a great 1280x720 resoultion with 30 FPS for the best video capturing possible.
- 720p HD Widescreen
- Full Resolution: 1280x720
- USB Powered
- Auto Focus
- High-precision glass element lens
- ClearFrame Technology
- Digital Microphone
- Aluminum Body
- 3 Year Warranty
NB: System Requirements:
For Windows®-based PC: Windows® 7, Windows Vista®, Windows XP with Service Pack 2 (SP2) or higher (Excluding Windows XP 64-bit);
Minimum: Intel Dual-Core 1.6 GHz or higher, 1 GB of RAM
Recommended: Intel Dual-Core 3.0 GHz or higher, 2 GB of RAM, 1.5GB free HDD space
- CD-ROM
- USB 2.0
- Windows-compatible speakers or headphones
Was £37.98 Inc. VAT
Only £36.98 inc VAT.
ORDER NOW
Asus Rampage Extreme III Black Edition Intel X58 (Socket 1366) DDR3 Limited Edition Motherboard @ £360.00 inc VAT
ASUS Republic of Gamers, (ROG), offers only the best hardware engineering, the fastest performance and the most innovating ideas.
The ROG Rampage III Black Edition motherboard is an evolution of the award-winning Rampage III Extreme, which set new world records in overclocking. Everything that made the Rampage III Extreme so great is back, but with a stylish black-themed design, plus many hardware and software improvements.
Most notable is the supplied ROG ThunderBolt expansion card that enhances both LAN and audio performance. This incorporates an award-winning Bigfoot Networks Killer™ E2100 networking platform that automatically classifies and accelerates online game traffic for maximum networking performance. Class-leading XONAR™ audio technology also provides increased sound quality and a built-in headphone amplifier with adjustable impedance settings — perfect for gaining the advantage on the competition when gaming.
Combined, these two technologies provide gamers with a superior online gaming experience that is set to overwhelm the competition. Better yet, the ROG Rampage III Black Edition also comes with the ASUS GPU TweakIt utility; an upgraded feature combined in ROG Connect that allows gamers to modify the graphics card settings for the greatest visual impact.
Pro-class overclocking needs professional equipment. Extreme Engine Digi+ is equipped with high performance digital VRM design that can easily achieve the ultimate performance with adjustable CPU PWM frequency. It accelerates heat dissipation and achieves better electric conduction keeping critical components reliable.
ROG Connect provides monitoring and tuning options for every important parameter, in real-time, via a note book. ROG iDirect expands your options, allowing you to take control of voltages and frequencies with an iPhone or iPad. Bluetooth v3.0 + HS support enables smart connectivity to a variety of Bluetooth and wireless internet devices – no additional adapters required – allowing control through any PC, mobile or desktop.
GPU.DIMM Post allows quick and easy check of graphics cards and memory DIMMs status in the BIOS detecting potential component failure before even entering the OS.
SLI or CrossFireX? Fret no longer because with the ROG Rampage III Black Edition you’ll be able to run both multi-GPU setups. The board features SLI/CrossFire on Demand technology, supporting either 3-Way SLI or up to 4 cards in CrossFireX configuration. Whichever path you take, you can be assured of jaw-dropping graphics at a level previously unseen.
- R.O.G Thunderbolt Card: a dedicated Killer Nic LAN and Xonar audio combo card designed for gamers.
- Built-in Xonar Headset Amplifier: The precision sound enables gamers to hear enemies and react earlier making winning easy.
- Output Signal-to-Noise Ratio (A-Weighted): 116 dB
- Output THD+N at 1kHz: 105 dB
- C-Media 6631 audio processor (Max. 192kHz/ 24-bit)
- TI 6120A2 high fidelity headphone amplifier
- Digital-to-Analog Converter: 120 dB (Max. 192kHz/ 24-bit)
- Analog-to-Digital Converter: 114 dB (Max. 192kHz/ 24-bit)
- Supports 3 Headphone Impedance Gain Modes (up to 300 Ohms)
- Fine-tuned Game Genre EQ Profiles
- XearTM Surround Headphone
- XearTM SingFX
- Equalizer, Environment Effects, FlexBass, Smart Volume, Virtual Speaker Shifter
- DS3D GX 1.0, OpenAL
- Front-panel audio connector (AAFP)
- Line in, Line out, Optical S/PDIF out ports
- USB 2.0 Interface
Dedicated Big Foot Killer Nic Network processing unit: offers higher network throughput and decreased latency for the best in-game experience.
- Advanced Game Detect™
- Visual Bandwidth Control™
- Application Blocking
- Online Gaming PC Monitor™
- Bandwidth Tester
- Game Networking DNA™
Extreme Engine Digi+ Phase Power Design: The latest design in power regulation, providing Digital Phase power for the overclock of every enthusiasts dreams allowing you to achieve the highest possible performance from your Skt1366 Intel CPU.
- 8-phase CPU power
- 3-phase QPI/DRAM power
- 3-phase NB power
- 3-phase Memory power
- ML Caps on CPU, Memory and QPI respectively
ROG Connect: *Plug and Overclock - Tweak it the hardcore way, monitor the status of your desktop PC and tweak its parameters in real-time via a notebook
ROG iDirect: *Tune your PC from your iPhone or iPad now!
GPU.DIMM Post: helps you quickly analyze any problem hardware in order to easily fix before attempting an overclock.
Bluetooth v3.0 + HS Support: Onboard Bluetooth v3.0 + HS enables smart connectivity to Bluetooth and wireless internet devices
Probelt: takes the guesswork out of locating the motherboard’s measurement points, identifying them clearly in the form of eight sets of detection points
iROG: The iROG is a special IC which enables several ROG highlitghted functions that gives users full disposal of the motherboard at any stage!
BIOS FlashBack: *Two BIOS ROM’s. Two sets of BIOS settings. Twice the overclocking flexibility.
CPU Level Up: *A simple click for instant upgrade!, Ever wish that you could have a more expansive CPU? Upgrade your CPU at no additional cost.
Extreme Tweaker: *One stop performance tuning shop, No matter if you're looking for frequency adjustment, over-voltage options, or memory timing settings, they're all here!
Voltiminder LED: *Friendly reminder on Voltage Settings, The voltiminder LED allows quick voltage monitoring for overclockers.
COP EX: The COP EX allows overclockers to increase chipset voltages without the worries of overheating.
Loadline Calibration: *Optimal power boost for extreme CPU overclocking, It helps overclockers enjoy the motherboard's ultimate OC capabilities and benchmark scores.
Key specification:
- Form Factor: Extended ATX Form Factor, 12”x 10.6” (30.5cm x 26.9cm)
- Socket: LGA1366 socket for Intel® Core™i7 Processor Extreme Edition / Core™i7 Processor
- Chipset: Intel® X58/ICH10R
- Graphics interface: 4 x PCIe2.0 x16 slots, support x16; x16/x16; x16/x8/x8 and x8/x8/x8/x8 configurations
- Expansion Slots: 2 x PCIe x1
- Multi GPU: Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology, 4 PCIe x16 slots ready for 4 single PCB 2-slot width graphics cards
- Memory: 6 x DIMM, max. 24GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C)/1800(O.C.)/1600/1333/1066 MHz, non-ECC, un-buffered memory modules
- Audio: SupremeFX X-Fi 2 Built-in 8-Channel High Definition Audio CODEC - EAX® Advanced™ HD 5.0 - THX® TruStudio PRO™ - X-Fi® Xtreme Fidelity™ - Creative Alchemy.
- LAN: Gigabit Intel® Ethernet LAN
- Storage: - 6 x SATA 3.0 Gb/s ports supports RAID 0, 1, 5 and 10, - 2 x External SATA 3.0 Gb/s ports & 2 x SATA 6.0 Gb/s ports
- USB: - 4 x USB 3.0/2.0 ports (2 at back panel; 2 at midboard) & 11 x USB 2.0/1.1 ports (4 ports at midboard; 6 ports at back panel, 1 reserved for ROG Connect)
- Manageability: WOL by PME, WOR by PME, PXE
- Bluetooth: Bluetooth v3.0 + HS
- WIFI: IEEE 802.11b/g/n, Wi-Fi Compliant
- Back Panel I/O Ports:
1 x PS/2 Keyboard port
2 x Wi-Fi antenna jacks
1 x Clr CMOS switch
2 x External SATA ports
1 x LAN (RJ45) port
1 x ROG Connect On/Off switch
2 x USB 3.0/2.0 ports (Blue)
7 x USB 2.0/1.1 ports (1 port also for ROG Connect)
8-channel Audio I/O
- Internal I/O Connectors:
1 x USB 3.0 connector supports additional 2 USB 3.0 ports
2 x USB 2.0 connectors support additional 4 USB 2.0 ports
8 x SATA connectors: 2 x SATA 6G connectors (Grey); 6 x standard SATA connectors (Black)
8 x Fan connectors: 2 x CPU / 3 x Chassis / 3 x Optional
8 x ProbeIt Measurement Points
3 x Thermal sensor connectors
1 x QPI Loadline calibration switch jumper (QPI_LL_SW)
1 x SPDIF_Out Connector
1 x 24-pin ATX Power connector
2 x 8-pin ATX 12V Power connectors
1 x En/Dis-able Clr CMOS header
1 x LN2 Mode Header
1 x START (Power On) button
1 x RESET button
1 x EZ Plug connector (4-pin Molex Power connector)
1 x Go Button
1 x BIOS Switch button
1 x ROG light connector
1 x Audio front panel (AAFP)
1 x System panel connector
- In The Box:
1 x ROG Connect cable
1 x 3-Way SLI Bridge
1 x SLI Cable
1 x CrossFire Cable
1 x 2-in-1 ASUS Q-Connector Kit
3 x 2-in-1 SATA signal cables
1 x 2-in-1 SATA 6G cables
1 x 2-port USB2.0 + ESATA module
1 x I/O Shield
3 x Thermal Sensor Cable Packs
1 x Cable Ties Pack
1 x ROG theme label
1 x 12-in-1 ROG Cable Label
1 x USB to USB cable for ThunderBolt
2 x Wi-Fi Ring Moving Antenna
1 x Optional NB Fan
- Support DVD:
- Drivers and Applications
- Kaspersky Anti-Virus
- ASUS TurboV EVO Utility
- ASUS PC Probe II
- ASUS Update
- ASUS AI Suite II
- ASUS AI Charger
- WiFi Agent
Was £383.50 Inc. VAT
Only £360.00 inc VAT.
ORDER NOW
Intel Core i3 550 3.20GHz (Clarkdale) (Socket LGA1156) - Retail @ £89.99 inc VAT
The wait is over - now everyone can move up to smart performance. As the first level in Intel’s new processor family, the new 2010 Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. The new 2010 Intel Core i3 processor also features Intel Hyper-Threading Technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Don’t let too many open applications slow you and your PC down. Get smart performance now.
- Lithography Process: 32nm
- Cores: 2
- Threads: 4
- Frequency: 3.20GHz
- Integrated Graphics Frequency: 733MHz
- Cache: 4MB Shared L3
- Memory Controller: Dual Channel DDR3 800/1066/1333MHz
- TDP: 73w
- Socket: LGA1156
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Datawrite Titanium 16x DVD-R 4.7gb - 50 Pack Spindle @ £7.00 inc VAT
Datawrite inform us that the Datawrite Titanium 16x Branded DVD-R in Packs of 50 is one of the toughest discs they've ever made. This claim is backed up by several pieces of technology.
- High quality dye which means that all hardware will be able to make good quality, long lasting recordings of video/data/music.
- Datawrite have paid particular attention to the quality of the polycarbonate layer (the middle section of the disc). This will improve the discs long term performance.
- The top of the disc is protected by the titanium coloured top surface.
These discs have a titanium (dark grey) coloured top surface featuring the Datawrite logo and a pre-lined area for content labelling.
Was £7.50 Inc. VAT
Only £7.00 inc VAT.
ORDER NOW
AMD Athlon II X4 Quad Core 640 3.00GHz (Socket AM3) - Retail @ £71.99 inc VAT
At home or at play, AMD Athlon II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Quad Core Technology
- 3.00GHz Clock Speed
- AM3 Socket
- 2MB L2 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail @ £113.99 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Six Core Technology
- 2.80GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £119.99 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1075T 3.00GHz (Socket AM3) - Retail @ £129.59 inc VAT
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £139.99 Inc. VAT
Only £129.59 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-16000C9 2133MHz Dual Channel Kit (KHX2133C9AD3X2K2/4GX) @ £77.99 inc VAT
Kingston's KHX2133C9AD3X2K2/4GX is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-2133MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-2133MHz at a low latency timing of 9-11-9 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX2133C9AD3X2K2/4GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-11-9-28 2N
Capacity: 4GB (2GBx2)
Speed: DDR3-2133 (PC3-17000)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was £83.99 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Microsoft Wireless Keyboard 6000 - Retail (J9C-00002) @ £21.90 inc VAT
Grace your workspace with the subtle elegance of Windows Aero, bought to you in the format of the Wireless Keyboard 6000. Giving you 5 customisable keys allowing you to set hot keys for your most commonly used folders, files and webpages. There are also media keys allowing you to control your music with a single key press.
- Wireless
- Thin, Translucent Border Inspired by Windows Aero
- Comfort Curve with Quiet Touch Keys
- Flip 3D
- My Favourite Keys
- Media Keys
- Battery Status Indicator
Was £24.98 Inc. VAT
Only £21.90 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) @ £83.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM (WD2002FAEX) @ £124.99 inc VAT
nonl2br
<center>
<div id="docview"><object classid="clsid
27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,28,0" width="728" height="90"><param name="movie" value="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf" /><param name="quality" value="high" vmode=transparent /><embed src="http://wdbrand.com/collateral/bannerad/Desktop/6Gb_728x90_EN.swf
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="728" height="90"></object></div></center>
<br>
WD Caviar Black high-performance 3.5" SATA drives combine 7200RPM spin speed, 64MB cache, SATA 6 Gb/s interface, and an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Technologically advanced acoustics minimize noise and cool drive operation and enhanced reliability features help protect the drive and the data stored on it. With a massive 2TB of storage, these drives are ideal for power computing applications such as multimedia, video and photo editing, and maxed out gaming computers. Backed by a 5-year limited warranty.
<br>
<br>
- Backwards compatible with SATA-II
<br>
- Capacity: 2TB
<br>
- Cache: 64MB
<br>
- Interface: SATA 6Gb/s
<br>
- Spin Speed: 7200RPM
<br>
- Warranty: 5 Years
<br>
<br>
Was £142.99 Inc. VAT
Only £124.99 inc VAT.
ORDER NOW
Philips BluRay BD-R 25GB (10 pack spindle) @ £9.98 inc VAT
Philips BluRay discs are fantastically reliable and great quality. WIth up to 135 minutes of HD video footage and super fast recording this BluRay disc is a must.
- 25GB Storage = 5x DVD
- Super fast recording (9 MB p/s)
- 135 minutes of HD video
- Protective disc coating
- End-to-end production control
Was £11.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C8) @ £89.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £99.98 Inc. VAT
ORDER NOW
Logitech G13 Advanced GameBoard (920-000947) @ £54.98 inc VAT
The Logitech® G13 Advanced Gameboard gives you game-changing comfort and control.
- Naturally contoured design: Follows the natural shape of your hand and fingers for increased comfort during long sessions.
- Solid, stable design: Helps assure that your gameboard will keep up when your game gets intense. Strategically placed feet. Stable weight (650 grams).
- Twenty-five programmable keys: Customize keys to suit your style of play.
- Quick macros: Assign complex actions to single keystrokes—on the fly.
- Programmable mini-joystick: Maneuver quickly and easily. The control you need is under your thumb.
- Backlit keys: Let you easily locate the right key in low-light conditions or lights-out play. Plus, you can customize the keys with any backlight color that you want.
- Onboard memory: Saves your profiles so you can take your personal preferences with you.
- Portable design: Keeps the game going wherever you go.
- High-visibility GamePanel™ LCD: Gather tactical information, including live stats, system info, and communications from fellow players.
- Public software development kit (SDK): Upload the latest enhancements developed exclusively for GamePanel™ by the Logitech open-source community.
Was £59.99 Inc. VAT
Only £54.98 inc VAT.
ORDER NOW
Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) @ £58.99 inc VAT
Barracuda® Green drives from Seagate save you time. Available now with SATA 6Gb/s interface and 64MB cache and combined with the industry's only 5900-RPM spin speed, you can be sure you're getting the best performance in the green-power drive category.
Seagate SmartAlign™ technology simplifies your transition to the Advanced Format (AF), 4K standard. There is no need for time-consuming integration utilities required by similar AF drives.
- Direct Attached Storage devices–USB/FireWire/eSATA
- Network Attached Storage devices and Windows storage servers
- Eco friendly PCs
- High-capacity desktop storage
Features
- A unique 5900-RPM speed delivers the fastest-performance eco friendly drive available.
- Seagate SmartAlign technology allows you to get all the benefits of the new Advanced Format 4K sector standard without any hassle–no utilities, no extra steps.
- The SATA 6Gb/s interface and 64MB cache maximize performance.
- Low power consumption combined with leadership in the use of environmental compliance materials means you don't have to sacrifice environmental stewardship for performance.
- Cool, quiet operation
- Capacity: 2TB
- Spindle speed: 5900RPM
- Cache size: 64MB
- Warranty: 3 Years
Was £69.98 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Logitech G19 Gaming Keyboard (920-000978) @ £119.99 inc VAT
When you’re gearing up for battle, you never compromise. Not on your team, not on your weapons, and certainly not on your hardware. If you take your gameplay seriously, you want the Logitech® G19 on your side.
- Tiltable, colour GamePanel™ LCD: The (320x240) display shows unprecedented levels of information, both in and out-of-game, including game stats, system information, VOIP communication data, video playback, image slideshows, and many other items.
- User-selectable backlit characters: Personalize the keyboard to better fit with the rest of your computer and gaming equipment, and easily locate keys - even in the dark.
- Twelve fully programmable G-keys with three macros per key: Program up to 36 single keypresses or complex macros; use the MR key to record new macros on-the-fly.
- Multi-key input: Use up to five keys at once to perform multiple complex actions.
- Game/desktop mode: Disable the Windows/Context Menu keys so they won’t interrupt your game if pressed accidentally.
- Two powered Hi-Speed USB 2.0 ports: Transfer data to and from peripherals, such as MP3 players and flash drives - while also charging battery-powered devices.
- Intelligent cable management: Keep mouse, headset, and other cords out of the way by routing them through channels on the underside of the keyboard.
- Instant media access: Use the convenient one-touch controls for volume and media playback.
Was £126.98 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K3000 3TB SATA 6Gb/s 64MB Cache 7200RPM - OEM @ £119.99 inc VAT
The Deskstar™ 7K3000 is Hitachi’s first hard drive to deliver an enormous three terabytes of storage capacity and 7200 RPM performance in a standard 3.5-inch form factor. The 7K3000 is also the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB cache buffer delivers a big boost to performance over the previous generation product.
- Part Code: HDS723030ALA640
- Capacity: 3TB
- Cache: 64MB
- Bootable with Sandybridge P67/H67 Motherboards
- Warranty: 3 Years
NOTE: These drives are only bootable on 64bit versions of windows Vista and 7 as well as OSX and Linux. These will work as storage on 32bit versions.
Was £129.98 Inc. VAT
ORDER NOW
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel Kit (OCZ3P1333LV4GK) @ £29.99 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Platinum Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 7-7-7-20
- Unbuffered
- Platinum Layered Z3 XTC Heatspreader*
- Lifetime Warranty
- 1.50-1.60 Volts**
- 240 Pin DIMM
Was £39.98 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £68.99 inc VAT
nonl2br
<center>
<br>
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
<br>
<br>
<br>
- Capacity: 1TB
<br>
- Cache: 64MB
<br>
<br>
<br>
- Warranty: 5 Years
<br>
<br>
Was £72.98 Inc. VAT
Only £68.99 inc VAT.
ORDER NOW
Kingston HyperX 4GB (2x2GB) DDR2 PC2-8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) @ £65.99 inc VAT
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR.
- Size: 4GB Kit (2x2GB)
- Speed: 1066MHz
- Timing: 5-5-5-15
- Format: 240-Pin DDR2 DIMM
- 2.1 Volts
- Lifetime Warranty
Was £71.99 Inc. VAT
ORDER NOW
Coolermaster CS-M Weapon of Choice AK47 Medium Mouse Pad @ £7.98 inc VAT
The CS-M FPS Tactics Pad is developed specifically for optical gaming grade sensors, but works equally well for high-end laser sensors. The graphical theme will put a smile on the faces of all First Person Shooter-fans, with its depictions of familiar in-game situations. Excellent tracking and speedy glide, coupled with an aggressive non-slip 100% natural rubber base, making thorough contact with your desktop, ensures that your gaming surface stays firmly in place and performs at the highest level.
- 100% Natural Rubber Base
- Duracloth Surface
-405 x 285 x5 mm
- Engineered for pinpoint precision and highly responsive tracking
- Optimized for optical grade sensors, but works equally well for high-end laser sensors
- Ultra smooth glide for unprecedented speed
- Aggressive non-slip bottom grip - stick it on the table and forget about it
Was £9.98 Inc. VAT
Only £7.98 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £245.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 500W minimum PSU recommended
- Warranty: 2 Years
Was £254.99 Inc. VAT
Only £245.99 inc VAT.
ORDER NOW
XFX ATI Radeon 6950 XXX 1024MB GDDR5 PCI-Express Graphics Card @ £173.99 inc VAT
Weapon of choice! Make sure that you choose wisely and are equipped with a graphics card custom fit to your specific needs. Which is why you’ll want the XFX AMD Radeon™ HD 6950 Graphics Card. The HD 6950 does what other cards can only claim: outperform its similarly equipped competition. This series of Radeon HD graphics cards is AMD’s 3-D gaming and multi-media solution for desktop computers, plus the next level of HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D, including 2GB of GDDR5 memory. XFX also offers you additional versions with enhanced cooling solutions, plus overclocked editions of these cards to custom fit the specific needs of the gamer. No matter which version you choose, XFX makes sure you get to draw your weapon first.
Features:-
- Core Clock: 830MHz
- Memory: 1024MB GDDR5
- Memory Clock: 5200MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 2 Years
Was £179.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6850 ICEQ X TURBO 1024MB GDDR5 PCI-Express Graphics Card with FREE Games Pack @ £137.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
Features:-
- Core Clock: 820MHz
- Memory Clock: 4400MHz (Effective)
- Processing Cores: 960
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1x DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with FarCry2, Call of Duty 2: Modern Warfare and Shogun 2 PC Games
Was £149.99 Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5770 Single Slot 1024MB GDDR5 PCI-Express Graphics Card @ £77.99 inc VAT
There’s an ideal graphics card for every gamer, and the XFX ATI Radeon™ HD 5770 single slot graphics card is for the gamer looking for “ility,” as in “utility,” “stability,” and “reliability,” not to mention some excellent overclocking “capability.” A single-slot card variant of the 5700 performance card family, it sports a uniquely designed fansink, with a total heatpipe surface area that is 15% greater than the HD 5770 dual slot channel fansink. This, combined with the open space provided by the single slot environment, ensures maximum airflow to the GPU.
An acoustic comparison of the 5700 family found that the XFX ATI Radeon HD 5770 single slot was up to 23.5 dB lower than the HD 5770 dual slot full cover fansink. Enhanced cooling and reduced noise is helped by fan speed, which is controlled by a PWM circuit on the PCB. Dust levels are kept down to a minimum with IP-5X dust protection standard. For gamers who have been waiting for the ideal single-slot graphics card, the XFX ATI Radeon HD 5770 has been worth the wait. The unique cooling capacity—and reduced noise levels—of this single-slot solution turns up the “ility,” making this a very attractive graphics card indeed.
- Single Slot Design!!
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- ATI CrossFireX Ready
- ATI Avivo HD
- Warranty: 2 Years
Was £79.99 Inc. VAT
ORDER NOW
Asus GeForce GTX 560 1024MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560 - arm yourself for battle.
Features:-
- Microsoft DirectX 11 support
- DirectCompute 5.0 and OpenCL support
- One dual-link DVI-I?Display Port and one mini-HDMI 1.4a connectors
- Dual-link HDCP Capable
- Core Clock: 810MHz
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1620MHz
- Bus Type: PCI-Express 2.0
- SLI Ready
- HDCP Capable
- OpenGL 4.1 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 3 years
Was £151.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
ZOTAC GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card @ £146.39 inc VAT
Next-generation gaming has arrived. Nvidia GeForce GTX 470 gives your games an adrenaline shot with screaming fast performance and futuristic, visually stunning graphics. Experience heart pounding,
cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jaw dropping
stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 470: pure adrenaline meets visual bliss.
- Core Clock: 607MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3348MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 448
- Shader Clock: 1215MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 5 Years
Only £146.39 inc VAT.
ORDER NOW
MSI GeForce GT 430 OC Twin FrozR 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £51.59 inc VAT
The GT430 provides users with ultra-smooth multimedia entertainment. This makes it the ideal product for a home theatre PC. Accompanied by a low profile design and Blu-ray 3D acceleration the GT430 has the perfect compatibility and fit required for HTPCs and multimedia centres. The GT430 plays Blu-ray 3D playback with true HD and put's minimal stress on the CPU allowing crisp, clear viewing in excellent detail.
Specification:-
- Core Clock: 785MHz (Upto 850MHz+ possible via OC)
- Twin FrozR Cooling design
- Extreme OC possible
- Memory: 1024MB GDDR3
- Memory Clock: 2000MHz (Effective) (Upto 2200MHz+ possible via OC)
- Memory Interface: 128-Bit
- Shader Clock: 1560MHz
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue & 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Dimensions: The card size is 6.3 inches x 2.8 inches
- Low Profile brackets included
- Warranty: 2 Years
Was £53.99 Inc. VAT
Only £51.59 inc VAT.
ORDER NOW
Gainward GeForce 8400GS "SILENT" 512MB DDR2 PCI-Express Graphics Card @ £26.39 inc VAT
NVIDIA® GeForce® 8 series graphics processing units (GPUs) redefine the PC gaming experience. With a revolutionary unified architecture and full support for Microsoft® DirectX® 10 games, GeForce 8 series GPUs deliver unprecedented performance, extraordinarily detailed environments, and film quality game effects. NVIDIA® Lumenex™ Engine delivers stunning image quality and floating point accuracy at ultra-fast frame rates. Designed to run perfectly with the next-generation PCI Express bus architecture. This new bus doubles the bandwidth of AGP 8X delivering over 4 GB/sec in both upstream and downstream data transfers. Designed to meet the output protection management specifications of the Blu-ray Disc and HD DVD formats, allowing the playback of encrypted movie content on PCswhen connected to HDCP-compliant displays. The combination of high-definition video processors and NVIDIA DVD decoder software delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for all video content to turn your PC into a high-end home theater.( Feature requires supported video software.) NVIDIA’s fourth-generation GPU architecture built for Windows Vista gives users the best possible experience with the Windows Aero 3Dgraphical user interface. Fully unified shader core dynamically allocates processing power to geometry, vertex, physics, or pixel shading operations, delivering up to 2x the gaming performance of prior generation GPUs. Massively multi-threaded architecture supports thousands of independent, simultaneous threads, providing extreme processing efficiency in advanced, next generation shader programs. Blazing-fast RAMDACs support dual QXGA displays with ultra-high, ergonomic refresh rates up to 2048x1536@85Hz. Advanced shader processors architected for physics computation enable a new level of physics effects to be simulated and rendered on the GPU—all while freeing the CPU to run the game engine and AI.
- Fanless Passive cooler (Silent)
- GeForce 8400 GS core running at 567MHz
- 512MB DDR2 Memory running at 800MHz
- 64-Bit Memory interface
- Shader Model 4.0
- Connectors: DVI, HDMI & VGA
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports 2560 x 1600 resolution displays
- HDCP Enabled!!
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 2yr Warranty
Was £29.99 Inc. VAT
Only £26.39 inc VAT.
ORDER NOW
IIyama Prolite E2271HDS 22" Widescreen LED Monitor - Black @ £134.39 inc VAT
The ProLite E2271HDS is one of the stunning new range of LED-backlit monitors from iiyama. It is a full 1920x1080 high definition 22” monitor that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel, touch-sensitive controls and is finished in the latest glossy-black. The high specifications on the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity. Power consumption is only 21W typical usage and less than 1W in standby.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 525.5mm x 376.0mm x 166.0mm
- Weight: 2.9kg
- Warranty: 3 Years On-Site
Only £134.39 inc VAT.
ORDER NOW
LG Flatron W2261V-PF 22" Widescreen LCD Monitor - Black @ £143.99 inc VAT
Gamers and movie buffs will love this widescreen LCD monitor. LG’s FLATRON f-ENGINE picture-enhancing chip offers enhanced image definition, smooth motion, and superb colour reproduction, making it ideal for watching films. And, with a 2ms response time, your video games will look better than ever. A single, all-digital cable input makes it easy to connect and integrate all your digital systems, including cable/satellite boxes and games.
- Contrast Ratio: 50000:1
- Response Time: 2ms
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 519.0mm x 387.0mm x 193.0mm
- Weight: 4.2kg
Was £147.98 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
LG E2260V-PN 22" Widescreen LED Monitor - Black @ £149.99 inc VAT
The ultimate in LG Monitor displays is now available with the E60. Truly a marvel, it offers groundbreaking design elements, smart innovations like LED backligthing and the wonders of Full 1080p resolution. Imagine anything you might want in a monitor display and it’s been made a reality with the E60.
LG E60 Series monitors are backlit by LED lights. This gives colors a greater contrast and more vibrancy, and creates deeper blacks. It also allows the monitor to be slimmer and more energy efficient.
By supporting Full HD resolution and 1920 x 1080 pixels, the ideal conditions for media produced in a 16:9 format, the LG E60 monitor reproduces a myriad of images—from the minute movements of insects to thrilling videos games—in rich colors and elaborate detail.
You’ll love the stunning picture while it’s on and marvel at its appearance when it’s off. The super slim profile and seamless design will appeal to even the most refined sense of style.
The E60 Series has a 5,000,000 to 1 contrast ratio, allowing the monitors to recognize subtle color differences, as well as pitch blacks. You’ll experience more accurate colors, especially when you’re viewing videos or graphic-intensive applications with a dramatic contrast between light and dark.
Make installation of any enabled device a snap. Get 10.2Gbps of bandwidth for deeper colors and more to take advantage of the best Full HD experience. HDMI 1.3 connectivity lets you prepare yourself for tomorrow’s technology today.
Features
- LED Backlit
- Brightness: 250cd/m²
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- Weight: 2.8kg
Was £159.98 Inc. VAT
ORDER NOW
Corsair Hydro H70 High-Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) @ £72.98 inc VAT
The Corsair Hydro Series H70 is the best choice for high performance CPU cooling. A worthy big brother to the already excellent Hydro Series H50, the H70 improves upon the design in every way.
A low profile pump and improved cold plate allow for even easier mounting to your CPU. Compatibility with all modern AMD and Intel desktop CPU sockets is included in the box. A higher-performance radiator with nearly twice the surface provides even more room for liquid to get cool before it returns to the cold plate.
And as if that weren’t enough, the Hydro Series H70 comes with twin high-performance 120mm fans, optimized for a push-pull configuration, to allow maximum airflow through the radiator. The Corsair Hydro Series H70 is the best choice for a high performance CPU cooler on the market, bar none.
- A new improved cold-plate design more efficiently transfers heat.
- A thicker radiator increases the cooling surface area for even better cooling potential.
- Dual 120mm fans with multiple speed options that let you optimize the maximum cooling and minimum noise.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 50mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Selectable 1600 or 2000 RPM
- Air Flow: 50.35 – 61.2 CFM (per fan)
- Static Pressure: 1.8 – 2.3mm H20 (per fan)
- Noise Level: 26 – 31.5 dBA (per fan)
Was £79.99 Inc. VAT
Only £72.98 inc VAT.
ORDER NOW
Asus VH242H 24" Widescreen LCD Multimedia Monitor - Black @ £143.99 inc VAT
23.6” 16:9 widescreen with 1920×1080 resolution enables borderless Full HD 1080p full-screen video display. Embedded HDMI simplifies cabling and provides pristine and stunning clarity multimedia experience together with PC, game consoles, Blu-ray Disc players, etc. Built-in hidden stereo speakers and SPDIF audio output enable audio enjoyment together with true-to-life Full HD visual.
ASCR (ASUS Smart Contrast Ratio) Technology automatically adjusts the luminance of the backlight for better displays according to the image contents, and improves the contrast ratio to 20000:1 – resulting in more realistic depictions of night scenes during games or movies.
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life Full HD 1080p gaming or movie watching without any data loss or image distortion.
Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the best possible color and image fidelity.
With the five preset modes (Standard, Game, Scenery, Night View and Theater) of Splendid™ Video Intelligence Technology, you will enjoy optimized colors for various multimedia entertainment scenarios.
Features:-
- TFT-LCD Panel Panel Size: 23.6“ Wide Screen
- True Resolution: 1920X1080
- Pixel Pitch: 0.272mm
- Brightness(Max): 300 cd/?
- Contrast Ratio (Max.): 20000 :1 (ASCR)
- Display Color: 16.7M
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 5 ms
- Video Features SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes (5 modes)
- Skin-Tone Selection (3 mode)
- HDCP support
- Color Temperature Selection(5 modes)
- Audio Features Stereo Speakers 2Wx2 stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- Input / Output PC Input: DVI-D/D-Sub
- PC Audio Input: 3.5mm Mini-jack
- Video Input: HDMI
- AV Audio Input: HDMI
- Audio Output: SPDIF
- Earphone jack: 3.5mm Mini-jack
- Signal Frequency Analog Signal Frequency: 30 ~ 83 KHz(H)/50 ~ 75 Hz(V)
- Digital Signal Frequency: 30 ~ 83 KHz(H)/50 ~ 75 Hz(V)
- Power Consumption Power Consumption < 55 W
- Power Saving Mode < 2 W
- Mechanical Design Chassis Colors: Black
- Tilt: +20°~ -5°
- VESA Wall Mounting: 100x100mm
- Security Kensington lock
- Dimension (WxHxD mm) Phys.Dimension(WxHxD): 562mm x 416mm x 220mm
- Box Dimension(WxHxD): 638mm x 171mm x 491mm
- Weight Net Weight (Esti.): 5.8 kg
- Gross Weight (Esti.): 8.2 kg
- Accessory DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- support CD
- warranty card
- Regulation Approval Energy Star®, UL/cUL, CB, CE, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, RoHS, WEEE, WHQL
ORDER NOW
BenQ EW2420 24" Widescreen LED Monitor - Black @ £179.99 inc VAT
LED panel combined with VA technology delivers a whole new world of audiovisual entertainment! VA Panel technology enables ultra-wide viewing angle, authentic colors and high contrast image performance. The BenQ EW2420 brings you big-time, cinema class enjoyment with deeper blacks and up to 11 multimedia connections!
BenQ – the world's leading LED monitor brand – has again successfully taken the lead to launch the world’s first VA LED monitor! Such technological revolution is bound to bring a whole new visual experience and enjoyment to the world.
Thanks to the VA panel technology, the BenQ VW Series give you ultra-wide viewing angles of 178°/178° from left, right, above and below – with sharper details, higher contrast and truly authentic colors.
Enjoy the flawless layering and precisely contrasted details in even the darkest images! Free of bright spots with reduced light leakage, VA panels are designed to deliver naturally deeper blacks with better contrast performance by keeping the light from passing through.
8-bit VA panels give you brighter and more saturated images with faithfully recreated subtle, natural details –16.7M color shades with interpolated 24-bit true color.
Equipped with an ultra-fast 8ms gray to gray response time, all you’ll get is the smoothest images for motion picture all the time.
Multiple connectivity gives you added convenience to your multimedia digital devices – allowing you to enjoy multimedia contents. The BenQ EW 2420 has up to 11 ports covering the most popular interfaces, including 2 HDMI’s, D-sub, DVI, 4 USBs and Audio in and out. Everything you need to enjoy the ultimate multimedia visual entertainment is at your command!
An amazing 20,000,000:1 dynamic contrast ratio adds color depth and definition to darkened and complex visuals, so that every thing you see – from the brightest white to the darkest black is perfectly rendered to deliver the most incredible picture performance – and to reveal all the previously hidden details!
The BenQ EW2420 supports the highest image resolution up to 1920 x 1080 with 16:9 aspect ratio. The subtlest details are rendered to stand out with richer, more realistic colors, making your viewing experience even more absorbing.
Features
- LED Backlit
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000000:1
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Inputs: 1x Analogue, 1x DVI-D & 2x HDMI
- Weight: 6.0kg
- USB Hub
- Warranty: 2 Years On-Site
Was £184.98 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
OcUK 24" True HD Widescreen LED Monitor - Black @ £134.39 inc VAT
The OcUK LED-backlit monitor, finished in the latest glossy-black, is a full high definition 24" display that features all the benefits this technology affords. The high specifications of the monitor include the 5,000,000:1 ACR, triple input connectivity (D-Sub, DVI-D, 2 x HDMI) and fast 2ms response for excellent sharpness in high definition video. VESA mount compatibility along with one HDMI input and headphone connector on the side of the cabinet ensures great comfort of usage.
Features:-
- Diagonal: 23.6"
- Panel: LED-Backlit
- Display area: h x w 293.2 x 521.3 mm; 11.54" x 20.51"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Connections: D-Sub, DVI-D & 2x HDMI
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v 0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- 3yr Warranty
ORDER NOW
Asus VE276Q 27" Widescreen LCD Multimedia Monitor - Black @ £254.39 inc VAT
VE276Q leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Be captivated by stunning images with ASUS Smart Contrast Ratio (ASCR) technology that boosts the display´s contrast ratio to an astonishing 100,000:1. AI Light function enables the VE276Q automatically adjusting to lower brightness and make your eyes feel more comfortable in the dim environment. Furthermore, it helps save more 25% power consumption. Embedded digital HDMI and DisplayPort inputs, VE276Q enables the most advanced graphic cards/ computers connection. The DisplayPort interface also offers better support of multiple display streams, longer cable connection, and interoperability with other inputs, such as VGA, DVI and HDMI. Need to research on the Internet, but a championship game is about to start on TV? The VE276Q offers PIP(Picture in Picture) function(via hotkey) and has the capability to display images of two different signals at the same time. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 27.0"(68.6cm) 16:9 Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 100000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Display Colors : 16.7M
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes
- Skin-Tone Selection : 3 Modes
- HDCP support
- Audio Features Stereo Speakers : 3W x 2 Stereo RMS
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DisplayPort,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Power Consumption Power Consumption < 70 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Dimensions Phys.Dimension(WxHxD): 643x445.6x220mm
- Box Dimension(WxHxD): 732x560x176mm
- Weight Net Weight (Esti.): 7.2 kg
- Gross Weight (Esti.): 10.5 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, EK, J-MOSS, Taiwan Green Mark,RoHS, WEEE, WHQL
Was £259.99 Inc. VAT
Only £254.39 inc VAT.
ORDER NOW
Noctua NH-D14 Dual Radiator CPU Cooler (Socket LGA1366/LGA1156/LGA1155/LGA775/AM2/AM2) @ £66.98 inc VAT
Combining a massive six heatpipe dual radiator design with an exquisite NF-P14/NF-P12 dual fan configuration, the NH-D14 is built for ultimate quiet cooling performance. Topped off with a tube of Noctua's award-winning NT-H1 thermal compound as well as the new SecuFirm2 multi-socket mounting system, the NH-D14 is an elite choice for the highest demands in premium quality quiet cooling.
- Six heatpipe dual radiator design
- Dual NF-P14/NF-P12 fan setup
- Asymmetrical design for high compatibility
- Excellent component cooling
- SecuFirm2 multi-socket mounting system
- Dimensions(with fans): 160 x 140 x 158mm ( H x W x D)
- Materials: Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating
- Fans Included: Noctua NF-P14 / Noctua NF-P12
- Fan Speeds: 1200 & 1300 RPM
- Fan Aiflow: 64.9 & 54.3 CFM
- Fan Noise: 13.2 & 12.6bDA
- Six Year Warranty
Was £69.98 Inc. VAT
Only £66.98 inc VAT.
ORDER NOW
Iiyama ProLite E2710HDS 27" Widescreen LCD Monitor - Black @ £245.99 inc VAT
The Prolite E2710HDS 27” LCD Display features a stunning 2ms Response Time and a High Definition 1920x 1080 Resolution. The 20000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the DVI, D-Sub and USB connections ensure compatibility across a range of devices including games consoles and work stations.
- Screen Size: 27" Widescreen
- Contrast Ratio: 20000:1
- Brightness: 400cd/m²
- VESA Compliant
- Dimensions: 642.0mm x 438.5mm x 210.0mm
- Weight: 6.9kg
ORDER NOW
Thermalright MUX-120 Black CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366) @ £39.98 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775). Heatsink are all Black nickel plated to ensure the best quality and performance and could last for years. Four sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Include Thermalright X-Silent series 120mm PWM Fan (600~1300RPM) Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Dimension: L133 x W58 x H160 mm
- Weight: Weight: 590g without fan ; 670g fan included
- Fan Rated Speed: 600~1300RPM
- Noise Level: 17~25 dBA
- Air Flow: 26.6~57.6 CFM
Was £42.98 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Zalman VF3000-F Graphics Card Cooler (GTX570 and GTX580) @ £39.98 inc VAT
The dual 92mm fans cool not only the heatsink and VGA RAM, but all other peripheral components surrounding the VGA chipset.
- Powerful Cooling Performance
- Ultra Quiet Design
- Ultra Quiet Green LED Fans
- Adjustable fan controller
- High Performance ZM-STG2 thermal grease
- Includes VRAM Sinks
PLEASE NOTE REMOVING THE STOCK COOLER MAY INVALIDATE YOUR GRAPHICS CARD WARRANTY
Was £44.99 Inc. VAT
ORDER NOW
Call Of Duty: Modern Warfare 3 @ £35.99 inc VAT
nonl2br
Modern Warfare is back. On November 8th, the bestselling first-person action series of all-time returns with the epic sequel to the multiple Game of the Year award winner Call of Duty: Modern Warfare 2.<br><br>
<iframe width="640" height="390" src="http://www.youtube.com/embed/coiTJbr9m04" frameborder="0" allowfullscreen></iframe>
Was £39.98 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Acer Aspire 5552 15.6" LED AMD Phenom II Triple Core 2100MHz, 4GB RAM, 500GB HDD, DVD-RW, Win7 Home Premium @ £347.99 inc VAT
The Acer Aspire 5552 meets your daily computing needs with excellent processor performance, a 500GB hard drive, 4GB processor and impressive graphics.
The Aspire 5552's media playback features offer richer entertainment at home or on the road, while boundary-free wireless communication keeps you in touch with family and friends. Comfortable typing is provided by the Acer FineTip keyboard with independent numeric keypad and multi-gesture touchpad that lets you easily scroll, pinch, rotate and flip through web pages, files and images.
A 15.6" HD display provides ample space for multitasking and digital entertainment, while an AMD Phenom II Triple-Core X3 N830 processor handles your applications with ease, and the premium ATI Radeon HD 4250 graphics solution delivers superb image quality and visual effects. The cinematic 16:9 aspect ratio of the display presents sharp, bright visuals, while an HDMI port enables you to connect to HDTVs and projectors for awesome, big-screen entertainment.
An Acer Crystal Eye webcam with 1.3 MP resolution and built-in microphone enables quality video chats, and a Wi-Fi certified network connection lets you get online from any hotspot.
The practical yet handsome Aspire 5552 features a unique mesh-patterned exterior that is not only visually appealing but also protects against smudges and scratches.
What’s in the box:-
- Laptop
- Power cable
- User Manual
- Included Software:
- Adobe Flash Player 10
- Adobe Reader 9.1
- Microsoft Office Starter 2010
- McAfee Internet Security Suite Trial
Specification:-
- Screen Size: 15.6" (LED Backlit) (1366x768 Resolution)
- Processor Type: AMD Phenom II N830
- Processor Speed: 2.1 GHz
- RAM Type: DDR3
- Hard Drive: 500GB
- Memory: 4GB
- Webcam: 1.3 Megapixel
- Audio Type: Built-in Mono Speaker
- Battery Life: 3 Hours
- Card Reader: 2in1 Media Card Reader
- DVD-RW Drive
- Graphics Card: ATI Mobility Radeon HD 4250
- Hard Drive Speed: 5400rpm
- Keyboard: Acer FineTip Keyboard with Standard Numeric Kaypad
- Microphone: Built In
- Networking Ports: 1 x Ethernet RJ45
- Operating System: Windows 7 Home Premium 64bit
- Speakers
- System Memory (RAM) Expandable To 8GB
- USB Ports: 3
- Weight: 4.90 KG
- Wireless Enabled: 802.11 b/g/n
- Warranty: 12 Months, brand new sealed product.
Was £359.99 Inc. VAT
Only £347.99 inc VAT.
ORDER NOW
Corsair Hydro H60 High Performance Liquid CPU Cooler (Socket LGA1366/1155/1156/775/AM2/AM3) @ £54.98 inc VAT
The Corsair Hydro Series H60 is a fantastic choice for cooling. With a new micro-channel cold plate and a split-flow designed manifold, the H60 brings remarkable new technologies to an affordable price point. If that weren’t enough, the H60 also features an all-new fan, custom designed to offer enhanced static pressure, which means better cooling.
You don’t have to sacrifice performance to build a quiet system. Most high-performance coolers use crude, outdated designs that rely on two techniques: put a huge hunk of metal in your case or crank the fan to obnoxiously loud noise levels. The Hydro Series coolers feature innovative, cutting-edge designs that utilize the superior thermal conductivity of liquid over air to provide fantastic cooling at much lower noise levels. In fact, the H60 is similar in noise levels to a 120mm case fan you probably already have.
Almost any case with a rear 120mm fan mount location can house the Hydro Series H60 CPU cooler. And don’t worry about compatibility with your CPU, we’ve got you covered. AMD® sockets AM2 and AM3 are covered, and without having to install a custom backplate, making the H60 a great choice for any modern AMD CPU up to the new Phenom six-core processors. And when it comes to Intel®, don’t worry about it. Whether you’ve got Socket LGA775, LGA1155, LGA1156, or LGA1366, we’ve got compatibility inside the box. That’s right, even the brand new Core i5 and Core i7 2x00 series processors are supported, right out of the box.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 27mm
- Fan Speed: Up to 1700 RPM
- Fan Airflow: 74.4 CFM
- Fan dBA: 30.2 dBA
- Fan Static Pressure: 3.2mm/H20
- Cold Plate: Copper
- Radiator Material: Aluminium
Was £59.99 Inc. VAT
ORDER NOW
Logitech G27 Racing Wheel - PC / PS2 / PS3 (941-000047) @ £224.99 inc VAT
A simulator-grade racing wheel, the Logitech G27 Racing Wheel is designed to deliver the definitive sim racing experience for the PC and Playstation 3. Its powerful, dual-motor force feedback mechanism with helical gearing smoothly and accurately simulates traction loss, weight shift and road feel, with exceptionally quiet steering action. The six-speed shifter with push-down reverse gear allows you to quickly choose exactly the right gear. New RPM/shift indicator LEDs let you know when you should shift gears; the 28-cm leather-wrapped rim provides hours of comfortable, true-to-life racing; and steel accelerator, brake and clutch pedals deliver precise control for heightened realism.
- Dual-motor force feedback mechanism with helical gearing
- RPM/shift indicator
- Sixteen programmable buttons plus D-Pad
- 900 degree wheel rotation
- Ultra-precise optical encoding
- Carpet Grip System
- 6 Speed Gear Shifter
- Steel gas, brake and clutch pedal
- Steel ball bearings
- Works with PC, PS2, PS3
Was £229.99 Inc. VAT
Only £224.99 inc VAT.
ORDER NOW
Gigabyte Z68X-UD4 Intel Z68 (Socket 1155) DDR3 Motherboard @ £159.98 inc VAT
Was £169.99 Inc. VAT
Only £159.98 inc VAT.
ORDER NOW
Gigabyte GK-K6800 Multimedia Keyboard @ £9.98 inc VAT
The Gigabyte GK-K6800 is an attractive keyboard designed especially for seeking trendsetting users.
Fashion and contemporary bright-black design of outlook is perfectly for any working space.
- USB Interface
- 14 Function Keys
- Membrane switches
- Dimensions: 467 x 205 x 31mm
Was £10.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
OCZ Vertex 3 240GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-240G) @ £399.98 inc VAT
As the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 240GB
- Controller: SandForce SF-2281
- Maximum Read: 550MB/sec
- Maximum Write: 525MB/sec
- Sustained Write: 525MB/sec
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £424.99 Inc. VAT
Only £399.98 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £219.98 inc VAT
- Capacity: 120GB
- Maximum Write: 500MB/sec
- Sustained Write: 500MB/sec
- Warranty: 3 Years
Was £249.98 Inc. VAT
Only £219.98 inc VAT.
ORDER NOW
Roccat Kave 5.1 Surround Sound Headset @ £65.99 inc VAT
nonl2br
<br>
A Desert Eagle isn't worth its fancy name, if you don't know where to aim. Imagine your advantage within the heat of the battle when you exactly hear where your opponents are before you can actually see them. Knowing the position of your enemy is half the frag. Realistic 3D surround sound makes you locate your opponents easily by the noise they generate. The desktop control enables you to adjust to situations quickly with sound and microphone mute buttons and volume control for different channels. <br>
<br>
- Real 5.1 Surround sound with speakers aligned at a 12° angle<br>
- Microphone with mute LED fully rotatable and completely removable<br>
- Tip’N’Control desktop remote for central management of all volume functions<br>
- Dual sound-profile with movie and game settings<br>
- Solid aluminium hinges enabling heavy duty use<br>
- Hand-sewn comfortable earcups featuring external noise cancelling<br>
- Adjustable vibration unit for a realistic gaming experience <br>
- Headband with three pads for equal weight distribution<br>
- Easy to carry folding and compact design <br>
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/125bfd1f2f2cc9251cc512dfde5e4fb1.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/f620e869ce025933aeef18e4d0fd3894.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/798d360d6701787365c7266f8cf96fbe.jpg">
<br><br>
<img src="http://www.roccat.org/img/ROCCAT/48545abd6c12c63d38c082c343da0099.jpg">
Was £67.99 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
"Primo Drone" AMD Athlon II X2 Dual Core 250 3.00GHz DDR3 System @ £269.98 inc VAT
The "Primo Drone" offers the performance needed for home and business use at a low price. The AMD Athlon II X2 Dual Core 250 3.00GHz combined with 4GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience.
Why You Should Buy This System?
- AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) offers multitasking performance.
- 500GB Seagate Barracuda hard drive gives a solid and reliable storage capacity.
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
System Specification
- Case: OcUK EZCool NA-705 microATX case - Black
- Power Supply: OcUK Value 500W PSU
- CPU: AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3)
- Motherboard: AMD nForce 630a (Socket AM2+/AM3) DDR3 Motherboard
- RAM: 4GB DDR3 1333MHz Dual Channel Kit
- Hard Drive: Western Digital Caviar Blue 500GB SATA 6GB/s
- Graphics Card: Onboard integrated NVIDIA GeForce 7025 GPU
- Sound: ALC662 6-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Compact, reliable and smart. The "Primo Drone" give you everything you need in a entry level home/business system.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £279.97 Inc. VAT
Only £269.98 inc VAT.
ORDER NOW
"Primo Ignition" Intel Core i3 550 3.20GHz DDR3 System @ £369.97 inc VAT
The "Primo Ignition" features a Intel Core i3 550 3.20GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
- Intel Core i3 540 3.06GHz (Clarkdale) Processer with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: OcUK EZCool NA-705 microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 550 3.20GHz (Clarkdale)
- Motherboard: Intel H55 (Socket 1156) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo Ignition" is perfect for the user looking for a highperformance system for a low price.
Was £389.98 Inc. VAT
Only £369.97 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - Black @ £33.98 inc VAT
nonl2br
The TT Esports Gamers Headset Shock brings gaming to a new level. Immerse deeply into your games with 40mm speaker drivers and stereo surround sound. Take advantage of your soundcard with 3.5mm speaker jacks bringing maximum sound performance. The ultra comfortable padded earcups make sure that comfort is key, especially for intense professional gaming. <br><br>
- Stereo surround sound<br>
- Quality 40mm speaker driver with enhanced bass performance<br>
- Noise cancelling microphone for communciation in gaming activities<br>
- Control Box with In-line control box for instant gaming sound control<br>
- 10 Levels adjustment for a perfect fit<br>
- Foldable design<br>
- Gold plated 3.5mm connctor<br>
<br>
<br>
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/2gampqTGEf8" frameborder="0" allowfullscreen></iframe>
Was £37.98 Inc. VAT
Only £33.98 inc VAT.
ORDER NOW
Corsair Enthusiast Series TX 650W V2 High Performance Power Supply (CMPSU-650TXV2UK) @ £69.98 inc VAT
The Enthusiast Series TX V2 is part of Corsair’s best price-performance range of power supplies, designed to meet the exacting standards and performance needs of demanding enthusiasts. TX Series power supplies are ideal for performance enthusiasts who require an affordable, high-wattage, reliable and highly efficient PSU. Corsair TX V2 Series PSUs are compatible with the latest Intel and AMD platforms and NVIDIA and AMD multi-graphics configurations.
- The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80PLUS Bronze certified, delivering up to 85% energy efficiency at real world load conditions.
- Active Power Factor Correction (PFC) with PF value of 0.99
- Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
- A dedicated single +12V rail offers maximum compatibility with the latest components
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components
- High-quality Japanese capacitors provide uncompromised performance and reliability
- A five year warranty and lifetime access to Corsair¡¦s legendary technical support and customer service
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
Was £74.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Cooler Master GX 450w Power Supply @ £45.98 inc VAT
Cooler Master is electrifying gamers PCs with the new GX-series, specifically targeted at systems in the upper-mid to high-end range, yet reasonably priced, providing users with unsurpassed cost per performance. The Cooler Master GX Series of power supplies feature a single highly robust 12 V rail, proficiently delivering power to the most demanding components including the processor, drives, cooling fans and even the most intense dual graphic cards, such as the SLI or CrossFireX. Now including a double-layer EMI Filter, an intelligent 120 mm controllable fan and an active PFC/PWM combo controller for increased efficiency, the GX Series will keep the power in your hands.
- Compliance with the latest Intel standard ATX 12V V 2.31
- Single 12V rail for most demanding SLI configurations
- High efficiency design that meets 80plus requirements (85% typical)
- Ultra-silent operation with intelligent 120mm fan speed control
- Multiple protection design
- High reliability
- Huge bulk capacitor for hold time up >17ms at full loading
- Integrated Active PFC with PWM
- Efficient transformer
- Five year warranty
Was £47.99 Inc. VAT
Only £45.98 inc VAT.
ORDER NOW
Steelseries 5H v2 Stereo Gaming Headset - Black @ £49.99 inc VAT
Steelseries 5H v2 - trust your senses. A truly remarkable professional gaming headset. Every detail and aspect has been designed and developed in cooperation with the best gamers in the world. The sound quality is awe-inspiring, allowing gamers to rely fully on their senses. The headset features a pull-out microphone attached to the right cup; the microphone metal goose neck is covered in high quality transparent plastic to ensure durability. The headset can be disassembled into three separate parts to ensure safe and easy transportation.
- Pull-out microphone system
- Custom engineered soundscape for gaming
- Specifically optimized for FPS games
- Comfortable XL-sized ear cushions
- Features extra durable braided cord
- Can be dismantled into 3 separate pieces
Was £51.98 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
"Titan Nero" AMD Athlon II X2 Dual Core 250 3.00GHz DDR3 System @ £279.98 inc VAT
The "Titan Nero" offers the performance needed for home and business use at a low price. The AMD Athlon II X2 Dual Core 250 3.00GHz combined with 4GB of 1333MHz DDR3 RAM, offers a quick and easy multitasking experience. With HDMI output the "Titan Nero" is more than capable of being a efficient home entertainment system.
- Seagate 500GB SATA-II 16MB Cache
- Case: Coolermaster Elite 335 - Black
- Power Supply: OCZ 500w StealthXStream II
- Motherboard: AMD 880G (Socket AM3) DDR3 Motherboard
- Graphics Card: Onboard AMD Graphics
- Sound: ALC888B 8-channel High Definition Audio CODEC
Service Package
Designed for the gamer who doesn't have a massive budget, yet expects quality gaming performance. The "Titan Nero" is the ultimate entry level gaming system.
Was £299.98 Inc. VAT
Only £279.98 inc VAT.
ORDER NOW
Cooler Master Storm Enforcer Gaming Case - Black @ £67.98 inc VAT
This new chassis contains a wealth of features coveted by most gaming enthusiasts, including USB 3.0, SSD drive support and a removable/rotatable HDD cage to support easy installation of the highest end video cards.
CM Storm has come up with a design that not only meets the expectations of its customer base, enthusiasts and esports prodigies, but does so within a price range that all will appreciate.
- Front I / O Panel with USB 3.0 (internal)
- Tool - free for 5.25” device
- Dust Filters on bottom and front intakes
- Cable management for better cable routing
- Reinforced front door protects your vital devices
- Supports rear internal 120mm water cooling radiator
- Removable & Rotatable HDD cage for convenient installation
- Support high-end graphics cards including ATI Radeon HD 5970
- Storm Guard - security system for safeguarding your gaming peripherals
- Motherboard: Micro-ATX & ATX
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- 4 x 2.5" Drive Bays
- Front I/O Ports: USB3.0 x 2 / USB2.0 x 2 / Audio x 2
- Front Cooling: 1 x 200mm Red LED fan 1000RPM @ 19dBA
- Rear Cooling: 1 x 120mm Black fan 1200 rPM @ 17dBA
- Top Cooling: 1 x 200mm fan (optional)
- Side Cooling: 1 x 120mm fan (optional)
- Expansion Slots: 7+1
- Max CPU Cooler: 175mm
- Max GPU Size: 390mm
Was £75.98 Inc. VAT
Only £67.98 inc VAT.
ORDER NOW
Plantronics GameCom 377 Gaming Headset (79731-05) @ £22.99 inc VAT
Because your hardware should be as powerful as your gaming skills, the GameCom 377 gaming hedset delivers rugged construction and vigorous sound. A lightweight frame and specially designed ear pods redistribute pressure for maximum comfort, while the open-ear design lets you catch all the in-game sound effects without losing touch with your surroundings. When you’re ready to fire off orders, unveil the hidden, noise-cancelling microphone boom to strategise clearly with team members. Responses coming in? Adjust audio levels using in-line volume and mic-mute controls. When you’re done, rotate and tuck the microphone boom inside the headset - then let your score do the talking.
- Open-ear design keeps you connected to the game and your surroundings.
- Concealed mic boom stays hidden until you’re ready to use it.
- Specially designed ear pods redistribute pressure for maximum comfort.
- In-line volume and mic-mute controls allow for easy audio adjustment.
- Noise-cancelling microphone lets you communicate clearly.
- Rugged, military-like design and extra-strength cables make your hardware hardcore.
Was £25.98 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
"Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System @ £709.98 inc VAT
Stalking through the jungle, the "Titan Spinosaur" is master of all. Featuring the Intel Core i5 2500K overclocked to a ridiculous 4.60Ghz, you can enjoy ultra smooth framerates and an immersive computing experience. With a choice of the latest DX11 graphics cards, equip yourself ready for the hunt ahead with the best offering from both Nvidia and ATI.
- A guaranteed 4.60GHz performance for the price of 3.30GHz
- Choose from a selection of graphics cards to meet your performance needs
- Precision built and cabled by Overclockers UK expert technicians
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Case: Antec 300 Case with Purple LED Fans
- Power Supply: OCZ StealthXStream 700W
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Corsair H50 CPU Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit w/ 8GB Option available
- Graphics Card: Choice of DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
Heighten your gaming experience with the "Titan Spinosaur", stalk your prey down and demolish the competition. Equipped with either ATI or Nvidia, become a champion.
Was £789.98 Inc. VAT
Only £709.98 inc VAT.
ORDER NOW
"Titan Onyx" Intel Core i7 950 3.06GHz @ 4.00GHz Quad Core DDR3 System @ £765.97 inc VAT
The "Titan Onyx" features an Intel Core i7 950 3.06GHz processor overclocked and guaranteed to a stable 4.00GHz. With a high overclock and DX11 graphics the "Titan Onyx" has a complete set of high end features straight out of the box. Everything you could ever want combined into one complete system.
Why Should You Buy This System?
- A guaranteed 4.00GHz performance for the price of 3.06GHz
- DX11 performance provided from the very latest graphics cards
- 6GB of 1600MHz DDR3 Triple Channel memory allows faster loading of games and better multi-tasking
- Case: Xigmatek Asgard Midi Tower - Black
- Power Supply: OCZ StealthXStream II 600w
- CPU: Intel Core i7 950 3.06GHz Overclocked to 4.00GHz
- Motherboard: Intel X58 (Socket 1366) DDR3 Motherboard
- Cooler: Corsair H70 CPU Cooler
- RAM: 6GB DDR3 1600MHz Tri-Channel
- Hard Drive: Seagate Barracuda 1TB 32MB Cache
- Graphics Card: A choice of the latest graphics cards
- Sound: 7.1 Channel Sound (On-Board)
Service Package
The "Titan Onyx" provides fantastic performance unseen at this price before. With all the features you could possibly dream of.
Was £789.97 Inc. VAT
Only £765.97 inc VAT.
ORDER NOW
"Ultima Thunderbolt" AMD Phenom II X6 1090T 3.20GHz @ 4.00GHz DDR3 System @ £1,175.99 inc VAT
The "Ultima Thunderbolt" features an AMD Phenom II X6 Six Core 1090T overclocked and guaranteed to a stable 4.00GHz. With six processing cores and dual channel DDR3 memory the "Ultima Thunderbolt" powers through applications and games with equal ease. Designed for gaming on the edge, the "Ultima Thunderbolt" delivers blistering performance and amazing DX11 visuals from the ATI 6970 2GB graphics card, with a crossfire option available for the real hardcore.
- A guaranteed 4.00GHz performance for the price of 2.80GHz
- Six Core processing and DX11 performance.
- USB 3.0 compatible system
- Case: Coolermaster HAF X
- Power Supply: OCZ ZX Series 850W '80 Plus Gold Certified' Modular Power Supply
- CPU: AMD Phenom II X6 Six Core 1090T 3.20Ghz overclocked to 4.00Ghz
- Motherboard: Asus Crosshair IV Motherboard
- RAM: 8GB DDR3 1600MHz
- Hard Drive: Seagate Barracuda 1TB HDD
- Graphics Card: ATI 6970 2048MB Graphics Card
- Sound: Asus Xonar DG 7.1 Sound Card
Service Package
Annihilate all with AMD six core. The "Ultima Thunderbolt" provides unrelenting performance at an amazing price.
Was £1,199.99 Inc. VAT
Only £1,175.99 inc VAT.
ORDER NOW
Xenon AMD Phenom II X4 840 3.20GHz Bundle - Quad Core @ £154.98 inc VAT
Designed by experts the "Xenon AMD Phenom II 840 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X4 840 Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
Bundle Specification
- CPU: AMD Phenom II X4 Quad Core 840 "95W Edition" 3.20GHz
- Motherboard: Gigabyte GA-M68MT-S2 (Socket AM3) DDR3 Motherboard
- RAM: 4GB (2x2GB) DDR3 1600MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £164.98 Inc. VAT
Only £154.98 inc VAT.
ORDER NOW
Logitech G930 7.1 Surround Sound Wireless Headset (981-000258) @ £133.99 inc VAT
Level up without being tied down. Gaming-grade wireless gives you a lag-free, interference-resistant connection with a range of up to 12 metres (40 feet) - so nothing stands between you and victory. 7.1 surround sound powered by Dolby technology delivers a detailed, positional soundfield that lets you hear your opponents before they see you. You'll have total command over music, voice morphing, chat clients and more with three programmable G-keys. And a memory foam-lined headband fends off fatigue, while plush ear pads ease pressure points and seal out unwanted noise.
- Gaming-grade wireless performance
- 7.1 surround sound
- Three programmable G-keys
- Memory foam-lined headband
Was £136.99 Inc. VAT
Only £133.99 inc VAT.
ORDER NOW
Argon Extreme Intel Core i3 550 3.20GHz @ 4.40GHz Overclocked Bundle @ £245.98 inc VAT
Designed by experts the "Argon Extreme Intel Core i3 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed to power through the latest games with ease. The "Argon Extreme Intel Core i3 Bundle" offers superb gaming performance at an excellent price.
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- CPU: Intel Core i3 550 3.20GHz @ 4.40GHz
- Motherboard: Gigabyte GA-H55M-UD2H (Socket 1156) DDR3 Motherboard
- RAM: Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Artic Cooling Freezer 7 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Was £269.98 Inc. VAT
Only £245.98 inc VAT.
ORDER NOW
Krypton AMD Phenom II X6 1090T Black Edition 3.20GHz @ 4.00GHz Overclocked Bundle @ £399.98 inc VAT
Designed by experts the "Krypton AMD Phenom II X6 1090T Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- SATA 6Gb/s and USB 3.0 compatible offering lightning fast transfer speeds
- CPU: AMD Phenom II X6 1090T Black Edition 3.20GHz @ 4.00GHz
- Motherboard: Asus Crosshair IV Formula AMD 890FX (Socket AM3) DDR3 Motherboard
- Cooler: Akasa Nero S CPU Cooler (Upgrade options available)
Service Package
Was £419.98 Inc. VAT
ORDER NOW
Roccat Pyra Wireless Mobile Gaming Mouse @ £21.98 inc VAT
The ROCCAT™ Pyra Mobile Wireless Gaming Mouse offers everything you’d typically expect from an ingenious mobile gaming mouse in a compact design – and it does it all completely wirelessly. With the same polling rate as a wired mouse (1000Hz) and sensor performance that can be adjusted from 400dpi to 1600dpi, the Pyra packs a punch by offering judder-free gaming with zero lag. What’s more, its ergonomic shape makes it comfortable to use.
World first: The Pyra is the first product to feature the innovative EasyShift[+] button, which doubles the number of mouse functions.
- Wireless Compact USB Gaming Mouse
- Easyshift Button Duplicator (doubling the buttons functions)
- Motion Blue-Optic Sensor
- Adjustable DPI; 400,800 or 1600
- 1000Hz polling rate
- Roccat Griptech featuring stabilizing, non-slip side grips
- Wide, Non-Slip Mousewheel
- Left or Right Handed
- Soft Travel Case included
Was £24.98 Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
Microsoft LifeCam Cinema HD 720p Widescreen Webcam (H5D-00003) @ £36.98 inc VAT
Share every detail with friends and family in HD. This full featured webcam, with true 720p HD video, delivers smooth, detailed video and crystal clear audio. Giving you a great 1280x720 resoultion with 30 FPS for the best video capturing possible.
- 720p HD Widescreen
- Full Resolution: 1280x720
- USB Powered
- Auto Focus
- High-precision glass element lens
- ClearFrame Technology
- Digital Microphone
- Aluminum Body
- 3 Year Warranty
NB: System Requirements:
For Windows®-based PC: Windows® 7, Windows Vista®, Windows XP with Service Pack 2 (SP2) or higher (Excluding Windows XP 64-bit);
Minimum: Intel Dual-Core 1.6 GHz or higher, 1 GB of RAM
Recommended: Intel Dual-Core 3.0 GHz or higher, 2 GB of RAM, 1.5GB free HDD space
- CD-ROM
- USB 2.0
- Windows-compatible speakers or headphones
Was £37.98 Inc. VAT
Only £36.98 inc VAT.
ORDER NOW
Asus Rampage Extreme III Black Edition Intel X58 (Socket 1366) DDR3 Limited Edition Motherboard @ £360.00 inc VAT
ASUS Republic of Gamers, (ROG), offers only the best hardware engineering, the fastest performance and the most innovating ideas.
The ROG Rampage III Black Edition motherboard is an evolution of the award-winning Rampage III Extreme, which set new world records in overclocking. Everything that made the Rampage III Extreme so great is back, but with a stylish black-themed design, plus many hardware and software improvements.
Most notable is the supplied ROG ThunderBolt expansion card that enhances both LAN and audio performance. This incorporates an award-winning Bigfoot Networks Killer™ E2100 networking platform that automatically classifies and accelerates online game traffic for maximum networking performance. Class-leading XONAR™ audio technology also provides increased sound quality and a built-in headphone amplifier with adjustable impedance settings — perfect for gaining the advantage on the competition when gaming.
Combined, these two technologies provide gamers with a superior online gaming experience that is set to overwhelm the competition. Better yet, the ROG Rampage III Black Edition also comes with the ASUS GPU TweakIt utility; an upgraded feature combined in ROG Connect that allows gamers to modify the graphics card settings for the greatest visual impact.
Pro-class overclocking needs professional equipment. Extreme Engine Digi+ is equipped with high performance digital VRM design that can easily achieve the ultimate performance with adjustable CPU PWM frequency. It accelerates heat dissipation and achieves better electric conduction keeping critical components reliable.
ROG Connect provides monitoring and tuning options for every important parameter, in real-time, via a note book. ROG iDirect expands your options, allowing you to take control of voltages and frequencies with an iPhone or iPad. Bluetooth v3.0 + HS support enables smart connectivity to a variety of Bluetooth and wireless internet devices – no additional adapters required – allowing control through any PC, mobile or desktop.
GPU.DIMM Post allows quick and easy check of graphics cards and memory DIMMs status in the BIOS detecting potential component failure before even entering the OS.
SLI or CrossFireX? Fret no longer because with the ROG Rampage III Black Edition you’ll be able to run both multi-GPU setups. The board features SLI/CrossFire on Demand technology, supporting either 3-Way SLI or up to 4 cards in CrossFireX configuration. Whichever path you take, you can be assured of jaw-dropping graphics at a level previously unseen.
- R.O.G Thunderbolt Card: a dedicated Killer Nic LAN and Xonar audio combo card designed for gamers.
- Built-in Xonar Headset Amplifier: The precision sound enables gamers to hear enemies and react earlier making winning easy.
- Output Signal-to-Noise Ratio (A-Weighted): 116 dB
- Output THD+N at 1kHz: 105 dB
- C-Media 6631 audio processor (Max. 192kHz/ 24-bit)
- TI 6120A2 high fidelity headphone amplifier
- Digital-to-Analog Converter: 120 dB (Max. 192kHz/ 24-bit)
- Analog-to-Digital Converter: 114 dB (Max. 192kHz/ 24-bit)
- Supports 3 Headphone Impedance Gain Modes (up to 300 Ohms)
- Fine-tuned Game Genre EQ Profiles
- XearTM Surround Headphone
- XearTM SingFX
- Equalizer, Environment Effects, FlexBass, Smart Volume, Virtual Speaker Shifter
- DS3D GX 1.0, OpenAL
- Front-panel audio connector (AAFP)
- Line in, Line out, Optical S/PDIF out ports
- USB 2.0 Interface
Dedicated Big Foot Killer Nic Network processing unit: offers higher network throughput and decreased latency for the best in-game experience.
- Advanced Game Detect™
- Visual Bandwidth Control™
- Application Blocking
- Online Gaming PC Monitor™
- Bandwidth Tester
- Game Networking DNA™
Extreme Engine Digi+ Phase Power Design: The latest design in power regulation, providing Digital Phase power for the overclock of every enthusiasts dreams allowing you to achieve the highest possible performance from your Skt1366 Intel CPU.
- 8-phase CPU power
- 3-phase QPI/DRAM power
- 3-phase NB power
- 3-phase Memory power
- ML Caps on CPU, Memory and QPI respectively
ROG Connect: *Plug and Overclock - Tweak it the hardcore way, monitor the status of your desktop PC and tweak its parameters in real-time via a notebook
ROG iDirect: *Tune your PC from your iPhone or iPad now!
GPU.DIMM Post: helps you quickly analyze any problem hardware in order to easily fix before attempting an overclock.
Bluetooth v3.0 + HS Support: Onboard Bluetooth v3.0 + HS enables smart connectivity to Bluetooth and wireless internet devices
Probelt: takes the guesswork out of locating the motherboard’s measurement points, identifying them clearly in the form of eight sets of detection points
iROG: The iROG is a special IC which enables several ROG highlitghted functions that gives users full disposal of the motherboard at any stage!
BIOS FlashBack: *Two BIOS ROM’s. Two sets of BIOS settings. Twice the overclocking flexibility.
CPU Level Up: *A simple click for instant upgrade!, Ever wish that you could have a more expansive CPU? Upgrade your CPU at no additional cost.
Extreme Tweaker: *One stop performance tuning shop, No matter if you're looking for frequency adjustment, over-voltage options, or memory timing settings, they're all here!
Voltiminder LED: *Friendly reminder on Voltage Settings, The voltiminder LED allows quick voltage monitoring for overclockers.
COP EX: The COP EX allows overclockers to increase chipset voltages without the worries of overheating.
Loadline Calibration: *Optimal power boost for extreme CPU overclocking, It helps overclockers enjoy the motherboard's ultimate OC capabilities and benchmark scores.
Key specification:
- Form Factor: Extended ATX Form Factor, 12”x 10.6” (30.5cm x 26.9cm)
- Socket: LGA1366 socket for Intel® Core™i7 Processor Extreme Edition / Core™i7 Processor
- Chipset: Intel® X58/ICH10R
- Graphics interface: 4 x PCIe2.0 x16 slots, support x16; x16/x16; x16/x8/x8 and x8/x8/x8/x8 configurations
- Expansion Slots: 2 x PCIe x1
- Multi GPU: Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology, 4 PCIe x16 slots ready for 4 single PCB 2-slot width graphics cards
- Memory: 6 x DIMM, max. 24GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C)/1800(O.C.)/1600/1333/1066 MHz, non-ECC, un-buffered memory modules
- Audio: SupremeFX X-Fi 2 Built-in 8-Channel High Definition Audio CODEC - EAX® Advanced™ HD 5.0 - THX® TruStudio PRO™ - X-Fi® Xtreme Fidelity™ - Creative Alchemy.
- LAN: Gigabit Intel® Ethernet LAN
- Storage: - 6 x SATA 3.0 Gb/s ports supports RAID 0, 1, 5 and 10, - 2 x External SATA 3.0 Gb/s ports & 2 x SATA 6.0 Gb/s ports
- USB: - 4 x USB 3.0/2.0 ports (2 at back panel; 2 at midboard) & 11 x USB 2.0/1.1 ports (4 ports at midboard; 6 ports at back panel, 1 reserved for ROG Connect)
- Manageability: WOL by PME, WOR by PME, PXE
- Bluetooth: Bluetooth v3.0 + HS
- WIFI: IEEE 802.11b/g/n, Wi-Fi Compliant
- Back Panel I/O Ports:
1 x PS/2 Keyboard port
2 x Wi-Fi antenna jacks
1 x Clr CMOS switch
2 x External SATA ports
1 x LAN (RJ45) port
1 x ROG Connect On/Off switch
2 x USB 3.0/2.0 ports (Blue)
7 x USB 2.0/1.1 ports (1 port also for ROG Connect)
8-channel Audio I/O
- Internal I/O Connectors:
1 x USB 3.0 connector supports additional 2 USB 3.0 ports
2 x USB 2.0 connectors support additional 4 USB 2.0 ports
8 x SATA connectors: 2 x SATA 6G connectors (Grey); 6 x standard SATA connectors (Black)
8 x Fan connectors: 2 x CPU / 3 x Chassis / 3 x Optional
8 x ProbeIt Measurement Points
3 x Thermal sensor connectors
1 x QPI Loadline calibration switch jumper (QPI_LL_SW)
1 x SPDIF_Out Connector
1 x 24-pin ATX Power connector
2 x 8-pin ATX 12V Power connectors
1 x En/Dis-able Clr CMOS header
1 x LN2 Mode Header
1 x START (Power On) button
1 x RESET button
1 x EZ Plug connector (4-pin Molex Power connector)
1 x Go Button
1 x BIOS Switch button
1 x ROG light connector
1 x Audio front panel (AAFP)
1 x System panel connector
- In The Box:
1 x ROG Connect cable
1 x 3-Way SLI Bridge
1 x SLI Cable
1 x CrossFire Cable
1 x 2-in-1 ASUS Q-Connector Kit
3 x 2-in-1 SATA signal cables
1 x 2-in-1 SATA 6G cables
1 x 2-port USB2.0 + ESATA module
1 x I/O Shield
3 x Thermal Sensor Cable Packs
1 x Cable Ties Pack
1 x ROG theme label
1 x 12-in-1 ROG Cable Label
1 x USB to USB cable for ThunderBolt
2 x Wi-Fi Ring Moving Antenna
1 x Optional NB Fan
- Support DVD:
- Drivers and Applications
- Kaspersky Anti-Virus
- ASUS TurboV EVO Utility
- ASUS PC Probe II
- ASUS Update
- ASUS AI Suite II
- ASUS AI Charger
- WiFi Agent
Was £383.50 Inc. VAT
Only £360.00 inc VAT.
ORDER NOW
Intel Core i3 550 3.20GHz (Clarkdale) (Socket LGA1156) - Retail @ £89.99 inc VAT
The wait is over - now everyone can move up to smart performance. As the first level in Intel’s new processor family, the new 2010 Intel Core i3 processor is the perfect entry point for a fast, responsive PC experience. The new 2010 Intel Core i3 processor also features Intel Hyper-Threading Technology, which enables each core of your processor to work on two tasks at the same time, delivering the performance you need for smart multitasking. Don’t let too many open applications slow you and your PC down. Get smart performance now.
- Lithography Process: 32nm
- Cores: 2
- Threads: 4
- Frequency: 3.20GHz
- Integrated Graphics Frequency: 733MHz
- Cache: 4MB Shared L3
- Memory Controller: Dual Channel DDR3 800/1066/1333MHz
- TDP: 73w
- Socket: LGA1156
Was £94.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Datawrite Titanium 16x DVD-R 4.7gb - 50 Pack Spindle @ £7.00 inc VAT
Datawrite inform us that the Datawrite Titanium 16x Branded DVD-R in Packs of 50 is one of the toughest discs they've ever made. This claim is backed up by several pieces of technology.
- High quality dye which means that all hardware will be able to make good quality, long lasting recordings of video/data/music.
- Datawrite have paid particular attention to the quality of the polycarbonate layer (the middle section of the disc). This will improve the discs long term performance.
- The top of the disc is protected by the titanium coloured top surface.
These discs have a titanium (dark grey) coloured top surface featuring the Datawrite logo and a pre-lined area for content labelling.
Was £7.50 Inc. VAT
Only £7.00 inc VAT.
ORDER NOW
AMD Athlon II X4 Quad Core 640 3.00GHz (Socket AM3) - Retail @ £71.99 inc VAT
At home or at play, AMD Athlon II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Quad Core Technology
- 3.00GHz Clock Speed
- AM3 Socket
- 2MB L2 Cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1055T 2.80GHz (Socket AM3) - Retail @ £113.99 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Six Core Technology
- 2.80GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £119.99 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1075T 3.00GHz (Socket AM3) - Retail @ £129.59 inc VAT
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £139.99 Inc. VAT
Only £129.59 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-16000C9 2133MHz Dual Channel Kit (KHX2133C9AD3X2K2/4GX) @ £77.99 inc VAT
Kingston's KHX2133C9AD3X2K2/4GX is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-2133MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-2133MHz at a low latency timing of 9-11-9 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX2133C9AD3X2K2/4GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-11-9-28 2N
Capacity: 4GB (2GBx2)
Speed: DDR3-2133 (PC3-17000)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was £83.99 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Microsoft Wireless Keyboard 6000 - Retail (J9C-00002) @ £21.90 inc VAT
Grace your workspace with the subtle elegance of Windows Aero, bought to you in the format of the Wireless Keyboard 6000. Giving you 5 customisable keys allowing you to set hot keys for your most commonly used folders, files and webpages. There are also media keys allowing you to control your music with a single key press.
- Wireless
- Thin, Translucent Border Inspired by Windows Aero
- Comfort Curve with Quiet Touch Keys
- Flip 3D
- My Favourite Keys
- Media Keys
- Battery Status Indicator
Was £24.98 Inc. VAT
Only £21.90 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) @ £83.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM (WD2002FAEX) @ £124.99 inc VAT
nonl2br
<center>
<div id="docview"><object classid="clsid
" quality="high" pluginspage="http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" width="728" height="90"></object></div></center>
<br>
WD Caviar Black high-performance 3.5" SATA drives combine 7200RPM spin speed, 64MB cache, SATA 6 Gb/s interface, and an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Technologically advanced acoustics minimize noise and cool drive operation and enhanced reliability features help protect the drive and the data stored on it. With a massive 2TB of storage, these drives are ideal for power computing applications such as multimedia, video and photo editing, and maxed out gaming computers. Backed by a 5-year limited warranty.
<br>
<br>
- Backwards compatible with SATA-II
<br>
- Capacity: 2TB
<br>
- Cache: 64MB
<br>
- Interface: SATA 6Gb/s
<br>
- Spin Speed: 7200RPM
<br>
- Warranty: 5 Years
<br>
<br>
Was £142.99 Inc. VAT
Only £124.99 inc VAT.
ORDER NOW
Philips BluRay BD-R 25GB (10 pack spindle) @ £9.98 inc VAT
Philips BluRay discs are fantastically reliable and great quality. WIth up to 135 minutes of HD video footage and super fast recording this BluRay disc is a must.
- 25GB Storage = 5x DVD
- Super fast recording (9 MB p/s)
- 135 minutes of HD video
- Protective disc coating
- End-to-end production control
Was £11.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C8) @ £89.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- Lifetime Warranty
Was £99.98 Inc. VAT
ORDER NOW
Logitech G13 Advanced GameBoard (920-000947) @ £54.98 inc VAT
The Logitech® G13 Advanced Gameboard gives you game-changing comfort and control.
- Naturally contoured design: Follows the natural shape of your hand and fingers for increased comfort during long sessions.
- Solid, stable design: Helps assure that your gameboard will keep up when your game gets intense. Strategically placed feet. Stable weight (650 grams).
- Twenty-five programmable keys: Customize keys to suit your style of play.
- Quick macros: Assign complex actions to single keystrokes—on the fly.
- Programmable mini-joystick: Maneuver quickly and easily. The control you need is under your thumb.
- Backlit keys: Let you easily locate the right key in low-light conditions or lights-out play. Plus, you can customize the keys with any backlight color that you want.
- Onboard memory: Saves your profiles so you can take your personal preferences with you.
- Portable design: Keeps the game going wherever you go.
- High-visibility GamePanel™ LCD: Gather tactical information, including live stats, system info, and communications from fellow players.
- Public software development kit (SDK): Upload the latest enhancements developed exclusively for GamePanel™ by the Logitech open-source community.
Was £59.99 Inc. VAT
Only £54.98 inc VAT.
ORDER NOW
Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) @ £58.99 inc VAT
Barracuda® Green drives from Seagate save you time. Available now with SATA 6Gb/s interface and 64MB cache and combined with the industry's only 5900-RPM spin speed, you can be sure you're getting the best performance in the green-power drive category.
Seagate SmartAlign™ technology simplifies your transition to the Advanced Format (AF), 4K standard. There is no need for time-consuming integration utilities required by similar AF drives.
- Direct Attached Storage devices–USB/FireWire/eSATA
- Network Attached Storage devices and Windows storage servers
- Eco friendly PCs
- High-capacity desktop storage
Features
- A unique 5900-RPM speed delivers the fastest-performance eco friendly drive available.
- Seagate SmartAlign technology allows you to get all the benefits of the new Advanced Format 4K sector standard without any hassle–no utilities, no extra steps.
- The SATA 6Gb/s interface and 64MB cache maximize performance.
- Low power consumption combined with leadership in the use of environmental compliance materials means you don't have to sacrifice environmental stewardship for performance.
- Cool, quiet operation
- Capacity: 2TB
- Spindle speed: 5900RPM
- Cache size: 64MB
- Warranty: 3 Years
Was £69.98 Inc. VAT
Only £58.99 inc VAT.
ORDER NOW
Logitech G19 Gaming Keyboard (920-000978) @ £119.99 inc VAT
When you’re gearing up for battle, you never compromise. Not on your team, not on your weapons, and certainly not on your hardware. If you take your gameplay seriously, you want the Logitech® G19 on your side.
- Tiltable, colour GamePanel™ LCD: The (320x240) display shows unprecedented levels of information, both in and out-of-game, including game stats, system information, VOIP communication data, video playback, image slideshows, and many other items.
- User-selectable backlit characters: Personalize the keyboard to better fit with the rest of your computer and gaming equipment, and easily locate keys - even in the dark.
- Twelve fully programmable G-keys with three macros per key: Program up to 36 single keypresses or complex macros; use the MR key to record new macros on-the-fly.
- Multi-key input: Use up to five keys at once to perform multiple complex actions.
- Game/desktop mode: Disable the Windows/Context Menu keys so they won’t interrupt your game if pressed accidentally.
- Two powered Hi-Speed USB 2.0 ports: Transfer data to and from peripherals, such as MP3 players and flash drives - while also charging battery-powered devices.
- Intelligent cable management: Keep mouse, headset, and other cords out of the way by routing them through channels on the underside of the keyboard.
- Instant media access: Use the convenient one-touch controls for volume and media playback.
Was £126.98 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Hitachi Deskstar 7K3000 3TB SATA 6Gb/s 64MB Cache 7200RPM - OEM @ £119.99 inc VAT
The Deskstar™ 7K3000 is Hitachi’s first hard drive to deliver an enormous three terabytes of storage capacity and 7200 RPM performance in a standard 3.5-inch form factor. The 7K3000 is also the first Hitachi hard drive with a 6Gb/s SATA interface, which along with its 64MB cache buffer delivers a big boost to performance over the previous generation product.
- Part Code: HDS723030ALA640
- Capacity: 3TB
- Cache: 64MB
- Bootable with Sandybridge P67/H67 Motherboards
- Warranty: 3 Years
NOTE: These drives are only bootable on 64bit versions of windows Vista and 7 as well as OSX and Linux. These will work as storage on 32bit versions.
Was £129.98 Inc. VAT
ORDER NOW
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel Kit (OCZ3P1333LV4GK) @ £29.99 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Platinum Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 7-7-7-20
- Unbuffered
- Platinum Layered Z3 XTC Heatspreader*
- Lifetime Warranty
- 1.50-1.60 Volts**
- 240 Pin DIMM
Was £39.98 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) @ £68.99 inc VAT
nonl2br
<center>
<br>
WD Caviar Black high performance 3.5" SATA hard drives combine 7200RPM spin speed, 64MB cache, SATA 6Gb/s interface with an integrated dual processor for lightning-fast performance in demanding desktop, workstation, and multi-drive systems. Rock solid mechanical architecture and enhanced reliability features help protect the drive and the data stored on it. Backed by a 5-year limited warranty.
<br>
<br>
<br>
- Capacity: 1TB
<br>
- Cache: 64MB
<br>
<br>
<br>
- Warranty: 5 Years
<br>
<br>
Was £72.98 Inc. VAT
Only £68.99 inc VAT.
ORDER NOW
Kingston HyperX 4GB (2x2GB) DDR2 PC2-8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) @ £65.99 inc VAT
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR.
- Size: 4GB Kit (2x2GB)
- Speed: 1066MHz
- Timing: 5-5-5-15
- Format: 240-Pin DDR2 DIMM
- 2.1 Volts
- Lifetime Warranty
Was £71.99 Inc. VAT
ORDER NOW
Coolermaster CS-M Weapon of Choice AK47 Medium Mouse Pad @ £7.98 inc VAT
The CS-M FPS Tactics Pad is developed specifically for optical gaming grade sensors, but works equally well for high-end laser sensors. The graphical theme will put a smile on the faces of all First Person Shooter-fans, with its depictions of familiar in-game situations. Excellent tracking and speedy glide, coupled with an aggressive non-slip 100% natural rubber base, making thorough contact with your desktop, ensures that your gaming surface stays firmly in place and performs at the highest level.
- 100% Natural Rubber Base
- Duracloth Surface
-405 x 285 x5 mm
- Engineered for pinpoint precision and highly responsive tracking
- Optimized for optical grade sensors, but works equally well for high-end laser sensors
- Ultra smooth glide for unprecedented speed
- Aggressive non-slip bottom grip - stick it on the table and forget about it
Was £9.98 Inc. VAT
Only £7.98 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £245.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 500W minimum PSU recommended
- Warranty: 2 Years
Was £254.99 Inc. VAT
Only £245.99 inc VAT.
ORDER NOW
XFX ATI Radeon 6950 XXX 1024MB GDDR5 PCI-Express Graphics Card @ £173.99 inc VAT
Weapon of choice! Make sure that you choose wisely and are equipped with a graphics card custom fit to your specific needs. Which is why you’ll want the XFX AMD Radeon™ HD 6950 Graphics Card. The HD 6950 does what other cards can only claim: outperform its similarly equipped competition. This series of Radeon HD graphics cards is AMD’s 3-D gaming and multi-media solution for desktop computers, plus the next level of HDMI 1.4a and DisplayPort 1.2 solutions for Stereoscopic 3-D, including 2GB of GDDR5 memory. XFX also offers you additional versions with enhanced cooling solutions, plus overclocked editions of these cards to custom fit the specific needs of the gamer. No matter which version you choose, XFX makes sure you get to draw your weapon first.
Features:-
- Core Clock: 830MHz
- Memory: 1024MB GDDR5
- Memory Clock: 5200MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 2 Years
Was £179.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6850 ICEQ X TURBO 1024MB GDDR5 PCI-Express Graphics Card with FREE Games Pack @ £137.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
Features:-
- Core Clock: 820MHz
- Memory Clock: 4400MHz (Effective)
- Processing Cores: 960
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1x DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 2 Years
- Supplied with FarCry2, Call of Duty 2: Modern Warfare and Shogun 2 PC Games
Was £149.99 Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
XFX ATI Radeon HD 5770 Single Slot 1024MB GDDR5 PCI-Express Graphics Card @ £77.99 inc VAT
There’s an ideal graphics card for every gamer, and the XFX ATI Radeon™ HD 5770 single slot graphics card is for the gamer looking for “ility,” as in “utility,” “stability,” and “reliability,” not to mention some excellent overclocking “capability.” A single-slot card variant of the 5700 performance card family, it sports a uniquely designed fansink, with a total heatpipe surface area that is 15% greater than the HD 5770 dual slot channel fansink. This, combined with the open space provided by the single slot environment, ensures maximum airflow to the GPU.
An acoustic comparison of the 5700 family found that the XFX ATI Radeon HD 5770 single slot was up to 23.5 dB lower than the HD 5770 dual slot full cover fansink. Enhanced cooling and reduced noise is helped by fan speed, which is controlled by a PWM circuit on the PCB. Dust levels are kept down to a minimum with IP-5X dust protection standard. For gamers who have been waiting for the ideal single-slot graphics card, the XFX ATI Radeon HD 5770 has been worth the wait. The unique cooling capacity—and reduced noise levels—of this single-slot solution turns up the “ility,” making this a very attractive graphics card indeed.
- Single Slot Design!!
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Bandwidth: 76.8GB/s
- Processing Cores: 800
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- ATI CrossFireX Ready
- ATI Avivo HD
- Warranty: 2 Years
Was £79.99 Inc. VAT
ORDER NOW
Asus GeForce GTX 560 1024MB GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 560 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 560 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 560 - arm yourself for battle.
Features:-
- Microsoft DirectX 11 support
- DirectCompute 5.0 and OpenCL support
- One dual-link DVI-I?Display Port and one mini-HDMI 1.4a connectors
- Dual-link HDCP Capable
- Core Clock: 810MHz
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 336
- Shader Clock: 1620MHz
- Bus Type: PCI-Express 2.0
- SLI Ready
- HDCP Capable
- OpenGL 4.1 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 3 years
Was £151.99 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
ZOTAC GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card @ £146.39 inc VAT
Next-generation gaming has arrived. Nvidia GeForce GTX 470 gives your games an adrenaline shot with screaming fast performance and futuristic, visually stunning graphics. Experience heart pounding,
cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jaw dropping
stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 470: pure adrenaline meets visual bliss.
- Core Clock: 607MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3348MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 448
- Shader Clock: 1215MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- OpenGL 3.1 Support
- PhysX Enabled
- CUDA Enabled
- Warranty: 5 Years
Only £146.39 inc VAT.
ORDER NOW
MSI GeForce GT 430 OC Twin FrozR 1024MB GDDR3 Low Profile PCI-Express Graphics Card @ £51.59 inc VAT
The GT430 provides users with ultra-smooth multimedia entertainment. This makes it the ideal product for a home theatre PC. Accompanied by a low profile design and Blu-ray 3D acceleration the GT430 has the perfect compatibility and fit required for HTPCs and multimedia centres. The GT430 plays Blu-ray 3D playback with true HD and put's minimal stress on the CPU allowing crisp, clear viewing in excellent detail.
Specification:-
- Core Clock: 785MHz (Upto 850MHz+ possible via OC)
- Twin FrozR Cooling design
- Extreme OC possible
- Memory: 1024MB GDDR3
- Memory Clock: 2000MHz (Effective) (Upto 2200MHz+ possible via OC)
- Memory Interface: 128-Bit
- Shader Clock: 1560MHz
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue & 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Dimensions: The card size is 6.3 inches x 2.8 inches
- Low Profile brackets included
- Warranty: 2 Years
Was £53.99 Inc. VAT
Only £51.59 inc VAT.
ORDER NOW
Gainward GeForce 8400GS "SILENT" 512MB DDR2 PCI-Express Graphics Card @ £26.39 inc VAT
NVIDIA® GeForce® 8 series graphics processing units (GPUs) redefine the PC gaming experience. With a revolutionary unified architecture and full support for Microsoft® DirectX® 10 games, GeForce 8 series GPUs deliver unprecedented performance, extraordinarily detailed environments, and film quality game effects. NVIDIA® Lumenex™ Engine delivers stunning image quality and floating point accuracy at ultra-fast frame rates. Designed to run perfectly with the next-generation PCI Express bus architecture. This new bus doubles the bandwidth of AGP 8X delivering over 4 GB/sec in both upstream and downstream data transfers. Designed to meet the output protection management specifications of the Blu-ray Disc and HD DVD formats, allowing the playback of encrypted movie content on PCswhen connected to HDCP-compliant displays. The combination of high-definition video processors and NVIDIA DVD decoder software delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for all video content to turn your PC into a high-end home theater.( Feature requires supported video software.) NVIDIA’s fourth-generation GPU architecture built for Windows Vista gives users the best possible experience with the Windows Aero 3Dgraphical user interface. Fully unified shader core dynamically allocates processing power to geometry, vertex, physics, or pixel shading operations, delivering up to 2x the gaming performance of prior generation GPUs. Massively multi-threaded architecture supports thousands of independent, simultaneous threads, providing extreme processing efficiency in advanced, next generation shader programs. Blazing-fast RAMDACs support dual QXGA displays with ultra-high, ergonomic refresh rates up to 2048x1536@85Hz. Advanced shader processors architected for physics computation enable a new level of physics effects to be simulated and rendered on the GPU—all while freeing the CPU to run the game engine and AI.
- Fanless Passive cooler (Silent)
- GeForce 8400 GS core running at 567MHz
- 512MB DDR2 Memory running at 800MHz
- 64-Bit Memory interface
- Shader Model 4.0
- Connectors: DVI, HDMI & VGA
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports 2560 x 1600 resolution displays
- HDCP Enabled!!
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 2yr Warranty
Was £29.99 Inc. VAT
Only £26.39 inc VAT.
ORDER NOW
IIyama Prolite E2271HDS 22" Widescreen LED Monitor - Black @ £134.39 inc VAT
The ProLite E2271HDS is one of the stunning new range of LED-backlit monitors from iiyama. It is a full 1920x1080 high definition 22” monitor that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel, touch-sensitive controls and is finished in the latest glossy-black. The high specifications on the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity. Power consumption is only 21W typical usage and less than 1W in standby.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 525.5mm x 376.0mm x 166.0mm
- Weight: 2.9kg
- Warranty: 3 Years On-Site
Only £134.39 inc VAT.
ORDER NOW
LG Flatron W2261V-PF 22" Widescreen LCD Monitor - Black @ £143.99 inc VAT
Gamers and movie buffs will love this widescreen LCD monitor. LG’s FLATRON f-ENGINE picture-enhancing chip offers enhanced image definition, smooth motion, and superb colour reproduction, making it ideal for watching films. And, with a 2ms response time, your video games will look better than ever. A single, all-digital cable input makes it easy to connect and integrate all your digital systems, including cable/satellite boxes and games.
- Contrast Ratio: 50000:1
- Response Time: 2ms
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 519.0mm x 387.0mm x 193.0mm
- Weight: 4.2kg
Was £147.98 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
LG E2260V-PN 22" Widescreen LED Monitor - Black @ £149.99 inc VAT
The ultimate in LG Monitor displays is now available with the E60. Truly a marvel, it offers groundbreaking design elements, smart innovations like LED backligthing and the wonders of Full 1080p resolution. Imagine anything you might want in a monitor display and it’s been made a reality with the E60.
LG E60 Series monitors are backlit by LED lights. This gives colors a greater contrast and more vibrancy, and creates deeper blacks. It also allows the monitor to be slimmer and more energy efficient.
By supporting Full HD resolution and 1920 x 1080 pixels, the ideal conditions for media produced in a 16:9 format, the LG E60 monitor reproduces a myriad of images—from the minute movements of insects to thrilling videos games—in rich colors and elaborate detail.
You’ll love the stunning picture while it’s on and marvel at its appearance when it’s off. The super slim profile and seamless design will appeal to even the most refined sense of style.
The E60 Series has a 5,000,000 to 1 contrast ratio, allowing the monitors to recognize subtle color differences, as well as pitch blacks. You’ll experience more accurate colors, especially when you’re viewing videos or graphic-intensive applications with a dramatic contrast between light and dark.
Make installation of any enabled device a snap. Get 10.2Gbps of bandwidth for deeper colors and more to take advantage of the best Full HD experience. HDMI 1.3 connectivity lets you prepare yourself for tomorrow’s technology today.
Features
- LED Backlit
- Brightness: 250cd/m²
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- Weight: 2.8kg
Was £159.98 Inc. VAT
ORDER NOW
Corsair Hydro H70 High-Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) @ £72.98 inc VAT
The Corsair Hydro Series H70 is the best choice for high performance CPU cooling. A worthy big brother to the already excellent Hydro Series H50, the H70 improves upon the design in every way.
A low profile pump and improved cold plate allow for even easier mounting to your CPU. Compatibility with all modern AMD and Intel desktop CPU sockets is included in the box. A higher-performance radiator with nearly twice the surface provides even more room for liquid to get cool before it returns to the cold plate.
And as if that weren’t enough, the Hydro Series H70 comes with twin high-performance 120mm fans, optimized for a push-pull configuration, to allow maximum airflow through the radiator. The Corsair Hydro Series H70 is the best choice for a high performance CPU cooler on the market, bar none.
- A new improved cold-plate design more efficiently transfers heat.
- A thicker radiator increases the cooling surface area for even better cooling potential.
- Dual 120mm fans with multiple speed options that let you optimize the maximum cooling and minimum noise.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 50mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Selectable 1600 or 2000 RPM
- Air Flow: 50.35 – 61.2 CFM (per fan)
- Static Pressure: 1.8 – 2.3mm H20 (per fan)
- Noise Level: 26 – 31.5 dBA (per fan)
Was £79.99 Inc. VAT
Only £72.98 inc VAT.
ORDER NOW
Asus VH242H 24" Widescreen LCD Multimedia Monitor - Black @ £143.99 inc VAT
23.6” 16:9 widescreen with 1920×1080 resolution enables borderless Full HD 1080p full-screen video display. Embedded HDMI simplifies cabling and provides pristine and stunning clarity multimedia experience together with PC, game consoles, Blu-ray Disc players, etc. Built-in hidden stereo speakers and SPDIF audio output enable audio enjoyment together with true-to-life Full HD visual.
ASCR (ASUS Smart Contrast Ratio) Technology automatically adjusts the luminance of the backlight for better displays according to the image contents, and improves the contrast ratio to 20000:1 – resulting in more realistic depictions of night scenes during games or movies.
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life Full HD 1080p gaming or movie watching without any data loss or image distortion.
Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the best possible color and image fidelity.
With the five preset modes (Standard, Game, Scenery, Night View and Theater) of Splendid™ Video Intelligence Technology, you will enjoy optimized colors for various multimedia entertainment scenarios.
Features:-
- TFT-LCD Panel Panel Size: 23.6“ Wide Screen
- True Resolution: 1920X1080
- Pixel Pitch: 0.272mm
- Brightness(Max): 300 cd/?
- Contrast Ratio (Max.): 20000 :1 (ASCR)
- Display Color: 16.7M
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 5 ms
- Video Features SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes (5 modes)
- Skin-Tone Selection (3 mode)
- HDCP support
- Color Temperature Selection(5 modes)
- Audio Features Stereo Speakers 2Wx2 stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- Input / Output PC Input: DVI-D/D-Sub
- PC Audio Input: 3.5mm Mini-jack
- Video Input: HDMI
- AV Audio Input: HDMI
- Audio Output: SPDIF
- Earphone jack: 3.5mm Mini-jack
- Signal Frequency Analog Signal Frequency: 30 ~ 83 KHz(H)/50 ~ 75 Hz(V)
- Digital Signal Frequency: 30 ~ 83 KHz(H)/50 ~ 75 Hz(V)
- Power Consumption Power Consumption < 55 W
- Power Saving Mode < 2 W
- Mechanical Design Chassis Colors: Black
- Tilt: +20°~ -5°
- VESA Wall Mounting: 100x100mm
- Security Kensington lock
- Dimension (WxHxD mm) Phys.Dimension(WxHxD): 562mm x 416mm x 220mm
- Box Dimension(WxHxD): 638mm x 171mm x 491mm
- Weight Net Weight (Esti.): 5.8 kg
- Gross Weight (Esti.): 8.2 kg
- Accessory DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- support CD
- warranty card
- Regulation Approval Energy Star®, UL/cUL, CB, CE, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, RoHS, WEEE, WHQL
ORDER NOW
BenQ EW2420 24" Widescreen LED Monitor - Black @ £179.99 inc VAT
LED panel combined with VA technology delivers a whole new world of audiovisual entertainment! VA Panel technology enables ultra-wide viewing angle, authentic colors and high contrast image performance. The BenQ EW2420 brings you big-time, cinema class enjoyment with deeper blacks and up to 11 multimedia connections!
BenQ – the world's leading LED monitor brand – has again successfully taken the lead to launch the world’s first VA LED monitor! Such technological revolution is bound to bring a whole new visual experience and enjoyment to the world.
Thanks to the VA panel technology, the BenQ VW Series give you ultra-wide viewing angles of 178°/178° from left, right, above and below – with sharper details, higher contrast and truly authentic colors.
Enjoy the flawless layering and precisely contrasted details in even the darkest images! Free of bright spots with reduced light leakage, VA panels are designed to deliver naturally deeper blacks with better contrast performance by keeping the light from passing through.
8-bit VA panels give you brighter and more saturated images with faithfully recreated subtle, natural details –16.7M color shades with interpolated 24-bit true color.
Equipped with an ultra-fast 8ms gray to gray response time, all you’ll get is the smoothest images for motion picture all the time.
Multiple connectivity gives you added convenience to your multimedia digital devices – allowing you to enjoy multimedia contents. The BenQ EW 2420 has up to 11 ports covering the most popular interfaces, including 2 HDMI’s, D-sub, DVI, 4 USBs and Audio in and out. Everything you need to enjoy the ultimate multimedia visual entertainment is at your command!
An amazing 20,000,000:1 dynamic contrast ratio adds color depth and definition to darkened and complex visuals, so that every thing you see – from the brightest white to the darkest black is perfectly rendered to deliver the most incredible picture performance – and to reveal all the previously hidden details!
The BenQ EW2420 supports the highest image resolution up to 1920 x 1080 with 16:9 aspect ratio. The subtlest details are rendered to stand out with richer, more realistic colors, making your viewing experience even more absorbing.
Features
- LED Backlit
- Screen Size: 24" Widescreen
- Contrast Ratio: 20000000:1
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Inputs: 1x Analogue, 1x DVI-D & 2x HDMI
- Weight: 6.0kg
- USB Hub
- Warranty: 2 Years On-Site
Was £184.98 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
OcUK 24" True HD Widescreen LED Monitor - Black @ £134.39 inc VAT
The OcUK LED-backlit monitor, finished in the latest glossy-black, is a full high definition 24" display that features all the benefits this technology affords. The high specifications of the monitor include the 5,000,000:1 ACR, triple input connectivity (D-Sub, DVI-D, 2 x HDMI) and fast 2ms response for excellent sharpness in high definition video. VESA mount compatibility along with one HDMI input and headphone connector on the side of the cabinet ensures great comfort of usage.
Features:-
- Diagonal: 23.6"
- Panel: LED-Backlit
- Display area: h x w 293.2 x 521.3 mm; 11.54" x 20.51"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Connections: D-Sub, DVI-D & 2x HDMI
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v 0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- 3yr Warranty
ORDER NOW
Asus VE276Q 27" Widescreen LCD Multimedia Monitor - Black @ £254.39 inc VAT
VE276Q leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Be captivated by stunning images with ASUS Smart Contrast Ratio (ASCR) technology that boosts the display´s contrast ratio to an astonishing 100,000:1. AI Light function enables the VE276Q automatically adjusting to lower brightness and make your eyes feel more comfortable in the dim environment. Furthermore, it helps save more 25% power consumption. Embedded digital HDMI and DisplayPort inputs, VE276Q enables the most advanced graphic cards/ computers connection. The DisplayPort interface also offers better support of multiple display streams, longer cable connection, and interoperability with other inputs, such as VGA, DVI and HDMI. Need to research on the Internet, but a championship game is about to start on TV? The VE276Q offers PIP(Picture in Picture) function(via hotkey) and has the capability to display images of two different signals at the same time. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 27.0"(68.6cm) 16:9 Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 100000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Display Colors : 16.7M
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes
- Skin-Tone Selection : 3 Modes
- HDCP support
- Audio Features Stereo Speakers : 3W x 2 Stereo RMS
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DisplayPort,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Power Consumption Power Consumption < 70 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Dimensions Phys.Dimension(WxHxD): 643x445.6x220mm
- Box Dimension(WxHxD): 732x560x176mm
- Weight Net Weight (Esti.): 7.2 kg
- Gross Weight (Esti.): 10.5 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, EK, J-MOSS, Taiwan Green Mark,RoHS, WEEE, WHQL
Was £259.99 Inc. VAT
Only £254.39 inc VAT.
ORDER NOW
Noctua NH-D14 Dual Radiator CPU Cooler (Socket LGA1366/LGA1156/LGA1155/LGA775/AM2/AM2) @ £66.98 inc VAT
Combining a massive six heatpipe dual radiator design with an exquisite NF-P14/NF-P12 dual fan configuration, the NH-D14 is built for ultimate quiet cooling performance. Topped off with a tube of Noctua's award-winning NT-H1 thermal compound as well as the new SecuFirm2 multi-socket mounting system, the NH-D14 is an elite choice for the highest demands in premium quality quiet cooling.
- Six heatpipe dual radiator design
- Dual NF-P14/NF-P12 fan setup
- Asymmetrical design for high compatibility
- Excellent component cooling
- SecuFirm2 multi-socket mounting system
- Dimensions(with fans): 160 x 140 x 158mm ( H x W x D)
- Materials: Copper (base and heat-pipes), aluminium (cooling fins), soldered joints & nickel plating
- Fans Included: Noctua NF-P14 / Noctua NF-P12
- Fan Speeds: 1200 & 1300 RPM
- Fan Aiflow: 64.9 & 54.3 CFM
- Fan Noise: 13.2 & 12.6bDA
- Six Year Warranty
Was £69.98 Inc. VAT
Only £66.98 inc VAT.
ORDER NOW
Iiyama ProLite E2710HDS 27" Widescreen LCD Monitor - Black @ £245.99 inc VAT
The Prolite E2710HDS 27” LCD Display features a stunning 2ms Response Time and a High Definition 1920x 1080 Resolution. The 20000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the DVI, D-Sub and USB connections ensure compatibility across a range of devices including games consoles and work stations.
- Screen Size: 27" Widescreen
- Contrast Ratio: 20000:1
- Brightness: 400cd/m²
- VESA Compliant
- Dimensions: 642.0mm x 438.5mm x 210.0mm
- Weight: 6.9kg
ORDER NOW
Thermalright MUX-120 Black CPU Cooler (Socket LGA775/LGA1156/LGA1155/LGA1366) @ £39.98 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs.), and have a more efficient and secure mounting.(1366/1156/775). Heatsink are all Black nickel plated to ensure the best quality and performance and could last for years. Four sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Include Thermalright X-Silent series 120mm PWM Fan (600~1300RPM) Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
- Dimension: L133 x W58 x H160 mm
- Weight: Weight: 590g without fan ; 670g fan included
- Fan Rated Speed: 600~1300RPM
- Noise Level: 17~25 dBA
- Air Flow: 26.6~57.6 CFM
Was £42.98 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Zalman VF3000-F Graphics Card Cooler (GTX570 and GTX580) @ £39.98 inc VAT
The dual 92mm fans cool not only the heatsink and VGA RAM, but all other peripheral components surrounding the VGA chipset.
- Powerful Cooling Performance
- Ultra Quiet Design
- Ultra Quiet Green LED Fans
- Adjustable fan controller
- High Performance ZM-STG2 thermal grease
- Includes VRAM Sinks
PLEASE NOTE REMOVING THE STOCK COOLER MAY INVALIDATE YOUR GRAPHICS CARD WARRANTY
Was £44.99 Inc. VAT
ORDER NOW
Call Of Duty: Modern Warfare 3 @ £35.99 inc VAT
nonl2br
Modern Warfare is back. On November 8th, the bestselling first-person action series of all-time returns with the epic sequel to the multiple Game of the Year award winner Call of Duty: Modern Warfare 2.<br><br>
<iframe width="640" height="390" src="http://www.youtube.com/embed/coiTJbr9m04" frameborder="0" allowfullscreen></iframe>
Was £39.98 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Acer Aspire 5552 15.6" LED AMD Phenom II Triple Core 2100MHz, 4GB RAM, 500GB HDD, DVD-RW, Win7 Home Premium @ £347.99 inc VAT
The Acer Aspire 5552 meets your daily computing needs with excellent processor performance, a 500GB hard drive, 4GB processor and impressive graphics.
The Aspire 5552's media playback features offer richer entertainment at home or on the road, while boundary-free wireless communication keeps you in touch with family and friends. Comfortable typing is provided by the Acer FineTip keyboard with independent numeric keypad and multi-gesture touchpad that lets you easily scroll, pinch, rotate and flip through web pages, files and images.
A 15.6" HD display provides ample space for multitasking and digital entertainment, while an AMD Phenom II Triple-Core X3 N830 processor handles your applications with ease, and the premium ATI Radeon HD 4250 graphics solution delivers superb image quality and visual effects. The cinematic 16:9 aspect ratio of the display presents sharp, bright visuals, while an HDMI port enables you to connect to HDTVs and projectors for awesome, big-screen entertainment.
An Acer Crystal Eye webcam with 1.3 MP resolution and built-in microphone enables quality video chats, and a Wi-Fi certified network connection lets you get online from any hotspot.
The practical yet handsome Aspire 5552 features a unique mesh-patterned exterior that is not only visually appealing but also protects against smudges and scratches.
What’s in the box:-
- Laptop
- Power cable
- User Manual
- Included Software:
- Adobe Flash Player 10
- Adobe Reader 9.1
- Microsoft Office Starter 2010
- McAfee Internet Security Suite Trial
Specification:-
- Screen Size: 15.6" (LED Backlit) (1366x768 Resolution)
- Processor Type: AMD Phenom II N830
- Processor Speed: 2.1 GHz
- RAM Type: DDR3
- Hard Drive: 500GB
- Memory: 4GB
- Webcam: 1.3 Megapixel
- Audio Type: Built-in Mono Speaker
- Battery Life: 3 Hours
- Card Reader: 2in1 Media Card Reader
- DVD-RW Drive
- Graphics Card: ATI Mobility Radeon HD 4250
- Hard Drive Speed: 5400rpm
- Keyboard: Acer FineTip Keyboard with Standard Numeric Kaypad
- Microphone: Built In
- Networking Ports: 1 x Ethernet RJ45
- Operating System: Windows 7 Home Premium 64bit
- Speakers
- System Memory (RAM) Expandable To 8GB
- USB Ports: 3
- Weight: 4.90 KG
- Wireless Enabled: 802.11 b/g/n
- Warranty: 12 Months, brand new sealed product.
Was £359.99 Inc. VAT
Only £347.99 inc VAT.
ORDER NOW
Corsair Hydro H60 High Performance Liquid CPU Cooler (Socket LGA1366/1155/1156/775/AM2/AM3) @ £54.98 inc VAT
The Corsair Hydro Series H60 is a fantastic choice for cooling. With a new micro-channel cold plate and a split-flow designed manifold, the H60 brings remarkable new technologies to an affordable price point. If that weren’t enough, the H60 also features an all-new fan, custom designed to offer enhanced static pressure, which means better cooling.
You don’t have to sacrifice performance to build a quiet system. Most high-performance coolers use crude, outdated designs that rely on two techniques: put a huge hunk of metal in your case or crank the fan to obnoxiously loud noise levels. The Hydro Series coolers feature innovative, cutting-edge designs that utilize the superior thermal conductivity of liquid over air to provide fantastic cooling at much lower noise levels. In fact, the H60 is similar in noise levels to a 120mm case fan you probably already have.
Almost any case with a rear 120mm fan mount location can house the Hydro Series H60 CPU cooler. And don’t worry about compatibility with your CPU, we’ve got you covered. AMD® sockets AM2 and AM3 are covered, and without having to install a custom backplate, making the H60 a great choice for any modern AMD CPU up to the new Phenom six-core processors. And when it comes to Intel®, don’t worry about it. Whether you’ve got Socket LGA775, LGA1155, LGA1156, or LGA1366, we’ve got compatibility inside the box. That’s right, even the brand new Core i5 and Core i7 2x00 series processors are supported, right out of the box.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 27mm
- Fan Speed: Up to 1700 RPM
- Fan Airflow: 74.4 CFM
- Fan dBA: 30.2 dBA
- Fan Static Pressure: 3.2mm/H20
- Cold Plate: Copper
- Radiator Material: Aluminium
Was £59.99 Inc. VAT
ORDER NOW
Logitech G27 Racing Wheel - PC / PS2 / PS3 (941-000047) @ £224.99 inc VAT
A simulator-grade racing wheel, the Logitech G27 Racing Wheel is designed to deliver the definitive sim racing experience for the PC and Playstation 3. Its powerful, dual-motor force feedback mechanism with helical gearing smoothly and accurately simulates traction loss, weight shift and road feel, with exceptionally quiet steering action. The six-speed shifter with push-down reverse gear allows you to quickly choose exactly the right gear. New RPM/shift indicator LEDs let you know when you should shift gears; the 28-cm leather-wrapped rim provides hours of comfortable, true-to-life racing; and steel accelerator, brake and clutch pedals deliver precise control for heightened realism.
- Dual-motor force feedback mechanism with helical gearing
- RPM/shift indicator
- Sixteen programmable buttons plus D-Pad
- 900 degree wheel rotation
- Ultra-precise optical encoding
- Carpet Grip System
- 6 Speed Gear Shifter
- Steel gas, brake and clutch pedal
- Steel ball bearings
- Works with PC, PS2, PS3
Was £229.99 Inc. VAT
Only £224.99 inc VAT.
ORDER NOW
Gigabyte Z68X-UD4 Intel Z68 (Socket 1155) DDR3 Motherboard @ £159.98 inc VAT
Was £169.99 Inc. VAT
Only £159.98 inc VAT.
ORDER NOW
