I've just cleaned off some excess thermal compound which I should have done when replacing the stock cooler with the Artic Pro 7 Rev 2. My idle temperatures are now about 33-36ºC at this time and my room is quite warm due to the nice weather we are having.
I played some games a short while ago on max settings and the CPU went up to 66ºC at its highest, I was only playing for about 2 hours so perhaps it could have gone higher...?
What is a safe temperature for this CPU? I've heard anything above 62ºC and I should start to get concerned. Is that right?
I've ordered some new paste and compound remover from here which should arrive Saturday just so I can be sure i've done as much as I can.
My case has two 120mm fans on the side blowing air in, one 120mm on the back sucking air out and a turbine fan on the front sucking air in. The air coming out at the back feels quite cool. Case shown below.
