Change Tubing on all in one cooler? (ECO ALT)
23 Mar 2011
Oxford
Just a thight, would it be possible to change the tubing on it? Just to suit my build better? Also is it possible to use another RAD? I think th tubing can come off, Thamks :)
I've seen it done on the Corsair series (tube change) but no idea on the rad change. Can I ask why you didn't go for one of the XSPC Rasa kits seeing as you want to change things?
I didn't think of it at the time, Just wanted something to do the job, And it just crossed my mind to do so... I might try anyway sometime unless if someone knows it can't be done :p thamls
As I mentioned, I've seen it done on the Corsair so it 'may' be possible on the ECO, have you tried google? Just a thought and good luck.
Thanks :) I did do a quick search but found nothing :D I might order some liquids and tubes and tightener thing tomorrow then :p I'm almost out of battery
