AMD Catalyst™ 11.5b hotfix
30 Mar 2010
Under The Stairs!
http://support.amd.com/us/kbarticles/Pages/AMDCatalyst115ahotfix.aspx
11.5 Cap 3 will be out on Friday.
AMD Catalyst™ Driver 11.5b Hotfix Features:
Includes performance optimizations and resolves various quality issues for the upcoming release of Brink™
Resolves transcoding video lagging issues seen when converting multiple H.264 clips to MPEG2 Blu-ray video
Resolves the intermittent mouse cursor lag issue seen by some users
Resolves intermittent flickering issues seen in the following applications in a system using an AMD Radeon™ HD 6000 series graphics card with DDR3 memory and running in DirectX® 9 mode:
Civilization 5
Dead Rising 2
Fallout 3
Mafia 2
NBA 2010
ShenGuiChuanQi
Starcraft 2
Warcraft III
World of Warcraft
Support for additional Stereo 3D-capable displays:
Viewsonic V3D241wm-LED
3D Projectors
Enables AMD CrossFire™ scaling for Brink
Enables AMD CrossFire scaling for The Witcher 2
Improves performance for Dirt 3
^ No problem Krugga, enjoying the new toy?
6950>70 Xfire:
Dirt 3 11.5's Cap 1:
average fps="51.723465" min_fps="30.748877"
Dirt 3 11.5b:
average fps="50.239655" min_fps="34.657738"
Next up Witcher 2, let's see if xfire has been fixed...
Do you uninstall CAP's when changing drivers or what? I've had 11.3 in for so long now I've mainly just been uninstalling/reinstalling CAPS.
Also does anyone know if changing drivers triggers activations for Crysis 2?
Witcher 2 xfire now working!:D
I imagine there must be better performance in single gpu as well because at these settings I was getting about 24 fps in xfire, now I'm getting 58!:D
I'm going to have a look and see if ubersampling kills my fps.
(Ubersampling disabled, I have larger text enabled in case you wonder why my Config tool looks like that)
I never uninstall anything, not even the caps, I always install straight over the top.
Don't have a clue, Crysis Warhead did trigger the activations for me and took 7 emails to EA and 13 days later I got an activation back. I was not a happy chap with EA at the time.
6950>70 Xfire:
Dirt 3 11.5b:
I don't have time until the end of this week to play with it really :(
Thanks for heads up. D3 ran quick already but there is always room for more :D
You'll probably find that's a resounding 'yes'. I've had a look myself with everything maxed and ubersampling on and off.
What cpu are you using?
Tried it myself last night with everything maxed and ubersampling. Playable until I get into a fight then the fps plummets.
Time to upgrade my 3 yr old Q6600 @3.6 GHz I think(been holding off until I see what bulldozer brings to the table).
I'm going to put it back to 4 GHz and see if there is any difference.
I have an i5 750 @ 4ghz. As much as I'd love to play it with ubersampling on, I can't be doing with the low framerates and mouse lag. I believe there's a patch due next week which will give performance boosts, so we'll see how that goes.
This has appeared sooner than I thought it would. :) Looking forward to getting proper use out of my 5850s in TW2 now.
Installing this has broken CCC. Tried repair install of it and full uninstall/re-install and just doesn't open anymore.
