Hi all,
A recent build has resulted in my ending up with a 125W CPU, and a 90W mobo (facepalm). Hence, when I boot the machine I am greeted with a bleep and an error about the CPU being an unsupported CPU. You can bypass this error by pressing F1 and the machine does boot.
So I was wondering, what's the worst that could happen?
Will it simple be a case that the CPU can't get as much juice as it would like? Or will it be the opposite, the CPU will draw more power than the Mobo can handle and flames ensue?
I havn't and don't plan to overclock the machine. I'm open to underclocking it if that may be a way to workaround the problem?
Many thanks
Components in question
Mobo: Asus M4A78LT-M 760G (Socket AM3) DDR3 Motherboard [90-MIBBJ0-G0EAY0WZ]
http://www.overclockers.co.uk/showproduct.php?prodid=MB-424-AS
CPU: AMD Phenom II X4 Quad Core 955 Black Edition "125W Edition" 3.20GHz (Socket AM3) - Retail [HDZ955FBGMBOX]
http://www.overclockers.co.uk/showproduct.php?prodid=CP-244-AM&groupid=701&catid=6&subcat=1943
Many thanks
