[PowerShell] Convert 1 digit number to 2 digit number
25 Mar 2004
Fareham
Hi all,
Is there a way in PowerShell to convert a one digit number to a two digit number?
For example:
Code:
$count = 1..10 ; foreach ($number in $count) {$number}
Loops through numbers 1 to 10 and returns them as values $number.
when run you get this:
1
2
3
4
5
6
7
8
9
10
I want this returned instead:
01
02
03
04
05
06
07
08
09
10
So if number is less than 9 it adds a 0 on the front.
I was thinking something like:
Code:
		if ($number -le 9)
		$number = "0" + $number
	$number
If you run this you do get:
01
02
03
04
05
06
07
08
09
10
But it doesn't seem very elegant, is there a better way?
Thanks!
Legend thanks! :)
P.S Knew about the formatting for decimal places didn't know you could add digits with it though
Yeah, it's one of those things that seems to be less well-known, here at least. Just got to be a bit careful if you want to add leading zeroes on a floating-point number. :p
This is what I was trying to achieve btw, seems to work good now :)
Code:
$CurrentDate = Get-Date
$Time = ""
[string]$Time = "{0:D2}" -f ($CurrentDate.hour) + ":" + "{0:D2}" -f ($CurrentDate.minute) + ":" + "{0:D2}" -f ($CurrentDate.second)
Just wanted the current time in hours:mins:secs to be consistently 2 digits across em all!
