Tell your Parents they can't be trusted on the Interwebs & deny access forthwith.
Haha i told them and they agree lmao!
Im on virgin btw. Thanks for the help so far.
LOL. Should be hung up by their free ringdings tbh. OP scenario sounds like The Ring(u) videotape saga.indeed.
you'd be hoping out foreign secretary would just be saying right then India no more 800million pound aid packets until you crack down on this illegal crap.
You'd have to ask the ISP if its static or not, if you don't know its probably dynamic - with most ISPs you have to specifically ask for a static one... however its probably beside the point unless you know for definite they haven't installed some software that keeps sending them the latest IP address every time you connect.
I'd take Burnsy2023's advice and run malwarebytes, etc. first off but without knowing for definite if they've installed a rootkit or similiar it would be safer to reinstall windows and have a quick look in the router control panel to make sure they haven't enabled a dynamic DNS service or configured remote access on it.
Virgin will be Static IP, or at least mine have always been.
Parent's logins shouldn't have admin rights![]()
Probably got her to go to a site like www.whatismyip.com - I'm not aware of a standard way to get the external IP from DOS as unless your using a modem directly instead of a NAT'd router it will just show router IP and local network IP which they can't connect to.
AFAIK usually they use DOS/command prompt to "show" you some random error to prove your PC "has" a problem.
That's why we have UAC
UAC - leave it on, or your parents will cripple your machine!![]()
I have a friend who v.nearly got scammed by the same lot, they told her that her pc was infected with viruses and affecting their servers, then directed her to a fake website and showed her all the infections she had on her pc (she had to type in a www address in the run dialog box, only it was a dodgy website and nothing actually wrong with her machine), then they tried to get her to install ammyy but it would not install, they tried about three times also trying alternative remote desktop s/ware with no luck (thank goodness) then they asked her age, then she got suspicious, when she questioned them back, the girl called her "supervisor" who came one the phone and quickly became abusive and rude, told her she must be very old? then she decided to hang up and was quite upset to realise what was going on.This
They won't have connected to the PC without her running something first, they probably got her to visit a website to run something like TeamViewer
