Advice needed with gaming upgrade
30 Mar 2003
Hi all!
My PC is due an upgrade. I've stretched it along by sticking in some more memory and an SSD over the last year, but I'm looking at Elder Scrolls V coming up and I know my system won't be up to that come November!
At the moment my systems is as follows:
  • Asus P5B Deluxe
  • Core 2 Duo E6600 conroe @ 2.4GHz and stock cooler
  • Corsair 4GB PC2-6400 DDR2
  • Geforce GTX260
  • Corsair HX 650w PSU
  • Corsair 60GB SSD with Win7 64bit home for applications
  • 500GB Western Digital SATA drive for backups and media
It's by no means a bad rig, but I'm looking at the OCuk bundles and thinking I could replace the guts and be set up nicely for a few years. I'm also aware that I could swap in a better cooler and overclock the conroe, but I'm not sure if that would bring enough extra horsepower to delay a full upgrade for another year or so.
If my budget was topping out at £400, would you go down the upgrade path (and if so, what would you do?) or should I squeeze some more out of what I've already got?
Many thanks!-Sam
  • Asus P5B Deluxe
  • Geforce GTX260 KEEP
  • Corsair HX 650w PSU KEEP
  • Corsair 60GB SSD with Win7 64bit home for applications KEEP
  • 500GB Western Digital SATA drive for backups and media KEEP
i'd keep everything in the above quote and replace the cpu + mobo + cooler + ram with a 2500K bundle from OC'ers
This would be an EPIC upgrade:
http://www.overclockers.co.uk/showproduct.php?prodid=BU-063-OE&groupid=43&catid=339&subcat=1802
Thanks for the quick replies!
That bundle would be the top end of my budget, but it's the one I looked at before I made the thread. Would the Corsair PSU be enough to carry the overclock?
corsair 650W? i wouldnt worry, that is a great power supply :)
perhaps in the future if you wanted an sli system, then you could upgrade the psu
I ordered the parts as per your post, and will have a crack at the overclock myself. At some point after summer I'll look at a graphics upgrade. My order should hopefully arrive tomorrow and I'll get started :)
