Actually - I'll apologise for being a bit of a **** - sorry![]()
Apology accepted
Now, I've been arguing on the Internet for far too long and have to be up for work in 5 hours, so I'd better hit the hay. Night all![]()
You were the only one of us here on the road and in the car at that time so you will have an opinion of whether or not the conditions suited fogs. However, it seems that other road users found your use of them more of a hindrance than a help and as such you maybe should have taken that hint at the time and turned them off![]()
As someone who actually drove through Dartford this afternoon/evening, including on the M25/A282, there were points where visibility was very very bad and fog lights would have assisted.
You mean apart from PMKeates who actually was also in the area and agreed that foglights would have been useful in the conditions?
You say other road users, but it was only singular, only one person had a problem, who then went off and undertook him without indicating in torrential rain, so he sounds like a bit of a ******* anyway, everyone else on the road seemed perfectly ok with it and didn't feel the need to full beam him.
Perhaps you should all take the hint and perhaps not grill the guy so much when none of you actually witnessed the conditions in the first place.
edit - all that said, if he was able to undertake, sounds like the OP was hogging the middle lane/outside lane, perhaps he was just trying to get you to move into the lane you should have been in and it had nothing to do with your fogs at all?![]()
Quote:
Originally Posted by Conscript
My point is, that a fog light in that sort of situation would have made a car easier to discern at longer distance. I'm not saying I couldn't see cars at all without one on, but it was easier to track the movements of cars around me through the rain and spray when they were showing brighter lights.
An example....coming up to a joining slip road. Usually, I tend to move over to the right if I see traffic attempting to join, to make it as easy for them to join the traffic flow. This is something that requires you look ahead toward the slip, to see the car in plenty of time, and plan moving over.
In the visibility I am describing, yes, I could see cars, but I can see them from further off when they are showing a fog light....the eye is drawn to the light first, and can discern that more easily against the more opaque background. They aren't needed, I fully realise that. But in the situation the road was in today, it was a real help, and not off putting.
90% of the time rear fog lights are no use to man nor beast, we all know that. The only real use for them them is in heavy mist and fog at dual lane and motorway speeds when you have large distances between cars, then they help you spot cars your closing in on at speed.
If you can see the driver behind he should be able see you. After that leaving the fog lights on are probably going to cause problems. This is probably what happened between you and the SAAB driver TBH.
Clearly you felt leaving your fogs on was helping the drivers around, but from the sound of it I honestly don't think it was.
*************(i am sorry everyone else is to polite to tell you) Its very easy to confuse fog lights for brake lights as some cars have them in the same place as the rear lights.
226
You MUST use headlights when visibility is seriously reduced, generally when you cannot see for more than 100 metres (328 feet). You may also use front or rear fog lights but you MUST switch them off when visibility improves (see Rule 236).
236
You MUST NOT use front or rear fog lights unless visibility is seriously reduced (see Rule 226) as they dazzle other road users and can obscure your brake lights. You MUST switch them off when visibility improves.
How the hell has this gone on for 5 pages? its not rocket surgery.
Its not even ambiguous (pretty impressive for a government document) if you can see more than 100m in front of you then your not allowed to use your fogs, if you cannot then you are. It doesn't have to be in fog, rainstorm/sandstorm/blizzard/ash cloud will all suffice.
If the op couldn't see more than 100m in front of his car then he was fully correct to be using his fogs.
Jigger has the right idea
You sir are are an idiot. (i am sorry everyone else is to polite to tell you) Its very easy to confuse fog lights for brake lights as some cars have them in the same place as the rear lights.
What makes you so much important then anyone else? Besides why were you driving at 50 mph in rain so heavy you could not see more then 100 meters in front of you. The road must have been a river and you endanagered your life and all those around you by driving at such high speed for very dangerous conditions.
Arrogant self-centering like this could make you rich one day (if you aren't already). But in the mean time it's not going to be winning you any admirers on the road.
PS: You can't control how closely some idiot with his fogs on is following behind you.
