Ideas on how to fit this 140mm fan
The stock screws for the LL panel are M3, so I'd imagine the screw holes are that large. Get some ~12mm M3 countersunk screws, as well as a washer and M3 nyloc nut per screw. The nut basically has some plastic in it to hold it in place better - to prevent it from shaking loose.
Just as a matter of interest lol, are you sure its M3? And how would you know that :eek:
I ask because i can order them online now :)
Edit does 12mm mean length?
Thanks
Yes, I'm sad and yes. I'm assuming though that the fan you'll be using is open cornered? If not, you'll need ~28mm screws. 12mm will be more than enough for open-cornered.
Awesome, its not sad. Its epic :p
Haven't decided on the fan yet :( But I think it will be open-cornered :)
Many Thanks and too everyone else :D
