Tri SLI uneven GPU usage.
10 Sep 2010
Cornwall, England
Hello
I have a very annoying problem with my GTX570's (Tri SLI).
I'll be playing, the GPU usage will be even across all GPU's and then randomly the usage will be completely uneven, say for example GPU 1 at 80%, GPU 2 at 12% and GPU 3 at 58%...This makes the game completely unplayable, feels like 10FPS
This happens randomly, so could be fine for 20 minutes then GPU usage will go crazy and it'll be choppy for usually about 5 minutes then return to normal.
has happened on every game I've played and any benchmark aswell. Tried various different drivers, now using the latest beta's.
Any idea's ?
Thanks in advance.
I doubt it will make any difference but try re-seating the bridge.
While you're doing that turn the bridge the other way around and see if it makes any difference.
Clutching at straws now.
I've decided to give my bro one of the cards, solves a problem for me and he's struggling along with a 512MB HD4870 at 1920 x 1200.
Thanks for your help guys.
Its probably a driver problem as tri-sli crossfire is never supported as well as dual cards. What psu were you running these cards on?
Your brother is gonna be a happy man.
