Skullcandy Hesh Headphones any good ?
23 Aug 2007
Hay all I am after some new headphones and I have seen some that I like look of but I am not 100% sure if there any good.
I will be using them for gaming more then music if that helps :)
Specs are.
Connector Type 3.5mm
Cable Length (m) 1.2
Cable Type Corded, Single sided
Impedance (ohm) 32
Frequency Response (Hz) 18-20000
Max. Input Power (mW) 100
Form Circumaural
Ear Cup Closed back
Driver Type Dynamic
Driver Diameter (mm) 50
Or should I just get the Sennheiser HD 205-II or the Sennheiser HD 418?
Thanks for any advice :)
Skullcandy are usually £20 headphones sold for £100. It's all a marketing thing. The folks here will help you pick the best for your budget, but it won't be Skullcandy. :)
Cheers :)
I was thinking do they look better then they sound lol.
But I wanted to get some advice just incase they are good.
So i am down to 2 options for my price range of £36.
HD 205 or the HD 418.
Both seem good it's a hard choice.
Thanks.
unless you get skullcandy for very cheap, it isnt worth it - i am happy with my set of titan in ear headphones becuase i only paid £12.99 with shipping! :p :D
The skull ones where about £36 so not very cheap lol.
I do like the look of the Creative Fatal1ty HS-800 :D
Makes my choice harder now lol.
But with the added mic i can get rid of my destop mic.
Thanks.
Goldring DR50 if you can find them, don't go for a 'gaming' headset.
Gaming basically means worse than a pair of proper headphones, apparently adding a microphone means they have to reduce audio quality too. :o
lol well the skullcandys are off the list for sure :)
The ones i really like atm are the GOLDRING DR100, HD205 and HD418.
Keep reading same thing about the goldrings "shrillness "
Could you stretch to £48? The Creative Aurvana Live are a very very good gaming/music headphone, and are a bargain at that price. Have a read over on head-fi a lot of people like them over there and they are pretty much the 'experts' in that field!
I would love to but £30 was my limit to start with and going over that already lol.
Leaning more towards the goldring dr100.
I hate buying sound equipment lol i had the same trouble buying my 2.1 setup:(
It took me ages to pick what to get.
Had to up my budget to £50ish to make my choice easy :)
Going to get Goldring NS1000 as they on sale atm :)
Not really sure what the batteries are for?
I will be connecting the headphones to my X-Fi XtremeGamer sound card.
Thanks all.
Yeah i was thinking that as it will work out cheaper in the long run :D
Is worth buying a amp still ? As i only have a X-Fi XtremeGamer.
Sorry one more question :)
I keep reading about CMSS-3D and it's a good thing to use but after playing BF2 a few months back with CMSS-3D the sound sounded degraded?
Maybe my options where setup wrong and not sure what MacroFX or Elevation filter really does.
Still waiting for the ns1000 to be posted to me :D
Thanks.
I actually have the hesh headphones and for music they're excellent. I was really impressed with the sound quality, admittedly the plastic is a bit flimsy but I've chucked them around a bit and they've coped, not used them for gaming yet though.
