hi guys,
just got back of a break, i went to turn on pc and it wouldn,t get past the windows splash screen, also the gpu (HD5850) fan was making a hell of a racket
opened up pc and i could see a sticky substance on the hsf and gpu
i removed the gpu and checked it out and it was coffee
my case has holes on top for fans and someone had spilled coffee and it had dribbled down the holes through the hsf and onto the gpu
i took the gpu apart (my first time ever) and there was a sticky residue over about half of it
i got a damp towel and kept dabbing at it until all the residue was gone.
i put some mx-4 on the gpu and reassembled it.
also cleaned out the cooler (nh-d14)
there was no other splashes any where else, so i was lucky
i then left it for 24hrs and then refitted it.
windows loaded up now problem
and i ran furmark on it for 30mins with no problems
the only problem is the fan is making more noise than it did before.
is there a way to fix this? or is it better to leave it alone? as i can live with it
also would you say the gpu is ok now?
