- 29 Aug 2010
- Cornwall
So it looks like, recently I broke my 5870 while attaching an EK waterblock
So now I'm a little nervous about spending £250-£300 on a new graphics card and waterblock in case I do the same thing to the new card.
So I was thinking I might try to get a card that I can leave the air cooler on. The trouble is due to limitation caused by my motherboard (location of SATA connectors) I need the graphics card to be under 9 inches in length.
I'm looking for something that will give me good performance (at least 5870 levels ideally) while also being as cool and quiet as possible.
It looks like I'm going to be restricted to the 560Ti range
at that length, but if someone can find something better that'd be cool.
It seems like the Gainward Phantom and the Palit Sonic are short 560Ti cards that would fit. The Asus DirectCU II might, as might the EVGA DS Superclocked, but both of those may be a little too long.
I'm not bothered if it's AMD/ATI or Nvidia, so what are my best options? (I'll worry about budget once I know what my options are)
Thanks.
at that length, but if someone can find something better that'd be cool.It seems like the Gainward Phantom and the Palit Sonic are short 560Ti cards that would fit. The Asus DirectCU II might, as might the EVGA DS Superclocked, but both of those may be a little too long.
Thanks.
