** Today Only 30/05/2011 ** Crucial RealSSD M4 64GB & CoolIT Eco A.L.C. 120mm CPU Watercooler
22 Aug 2010
Another 2 stunning deals for this fine bank holiday! Only limited units so be fast!
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive @ £89.99 inc VAT
Continuing the tradition of our award-winning solid-state drives, the Crucial m4 offers mobile and desktop users scorching-fast read and write speeds. Low power, lightweight, and durable, it empowers high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management, and the SATA 6Gb/s interface. Together, that technology dramatically improves data transfers for bandwidth-demanding applications.
Our products are built on decades of design and manufacturing expertise. It is our expertise in NAND technology that enables us to optimize the performance and endurance necessary to build quality solid-state storage devices.
- Sequential Read (up to): 415MB/sec (SATA 6Gb/s)
- Sequential Write (up to): 95MB/sec (SATA 6Gb/s)
- Random 4k Read: 40,000 IOPS
- Random 4k Write: 20,000 IOPS
- PCMark Vantage: 55K HDD Test Score
- Interface: SATA 6Gbps / Backwards Compatible 3Gbps
- Native TRIM support
- Seek Time: .1ms
- Slim 2.5" Design
- 100.5 x 69.85 x 9.5mm
- Lightweight: 75g
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -40°C ~ 85°C
- Low Power Consumption: 150 mW in operation, .65 mW in standby
- Shock Resistant up to 1500G
- RAID Support
- MTBF: 1.2 million hours
- Limited 3-Year Warranty
Only £89.99 inc VAT.
ORDER NOW
CoolIT Eco A.L.C. 120mm CPU Watercooler (Socket AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £39.98 inc VAT
A revolutionary leap in design delivers industry leading realiability, performance and value.
The ECO Advanced Liquid Cooling (A.L.C.) System is an elegantly engineered ultra low profile thermal solution positioned at an economical price point. CoolIT's engineers have focused on offering a superior propriatory cooling technology that delivers the ultimate performance in a compact design. The whisper quiet ECO cooler is widely compatible with the majority of pc cases featuring a 120mm fan and can beinstalled in 3 easy steps. CoolIT's selection and design of each componenthas been scrutinized to ensure the ECO provides the industry leading performance and reliability resulting in the ultimate maintenance free cooling solution.
- CoolIT's compact pump runs quietly whilst maintaining an optimal flow rate
- CoolIT engineered for high heat disapation at low fan speeds reuslting in efficient, quiet operation
- A Micro-Channel Fluid Heat Exchanger that lets you reach the maximum potential of your CPU overclock
- A pre-filled, factory sealed, liquid loop of carefully chosen components offers years of worry free cooling
- CoolIT's pro advanced thermal compound is pre applied for easy installation
- Extremely easy to install retention for Intel 775, 1155, 1156, 1366, and AMD, AM2, AM2+, AM3 Sockets
- Two-year warranty
Only £39.98 inc VAT.
ORDER NOW
No issues as far as i know,they are cracking drives.
Ok cheers.
I see you have a M64 in sig, could you please post a bench. I'm really interested in 4k random reads and ms response times.
Been searching the net but can't find a single review on the 64GB version.
Are there any known issues on the Crucial M4? Do they need flash upgrade or anything.
Thinking of buying to use on Sata II.
Mine is running fine on SATA II in my HTPC (clicky in sig). AM3 785G/710 chipset and getting read speeds of around 250-260MB/s. Booting into Windows 7 in around 12-14 seconds from POST.
Didn't need a firmware upgrade or anything, motherboard recognised drive immediately.
Not a bad price on the drive either. ;)
