Lian Li PC-Z70
4 Jan 2009
Video:
More images on the link
http://www.lian-li.com/v2/en/produc...576&cl_index=1&sc_index=25&ss_index=138&g=spe
Did you even look at the link to the Lian-Li site? It has 3x120mm intake fans and 2x140mm exhaust fans on top and 1x120mm exhaust fan at the back.
Air will get sucked through the bottom vents so I don't see cooling being a problem at all.
The intake is at the side - that's what I'm worried about!
I take it all back, had a proper look and it looks like the intakes are on the side?! In which case I agree with Vinni3.
Don't worry mate! :D
The air will be blown towards the hard drive cage, which isn't even aligned towards the fans anyway so the air will just hit a solid sheet of aluminium with nowhere to go. I suspect things will get rather toasty in that case as a result.
When oh when are lian li going to get with it ? people want black interiors bigger front fans with clear space between fans and internals top fans 140mm rear exhaust i could go on and on.
Brilliant interior but why is the intake on the side! The way the fans are mounted next to the hard drive cage will severely limit airflow.
I don't mind the non-black interior due to the fact that aluminium shines unlike the dull steel look other cases have. It's probably why other cases are painted inside.
Hmm, this case is 5 inches taller than my PC-101. Seems quite tall. Is this classed as a full tower?
They have this case is superb, side fans vent perfectly and it has two top fans and rear exhaust. Perfectly happy with this case and I would not hesitate to recommend it to anyone.
