maths help
1 Jul 2009
y=f(x) = x(x-2)^2
f(x+2)
(x+2)[(x+2)-2]^2
(x+2)(x)^2
Can someone explain how you get from [(x+2)-2]^2 to (x)^2 please. Shouldn't it be (x+2)(-2x-4)^2 ?
(x + 2) - 2 = x + 2 - 2 = x
(As nothing is multiplying the brackets they can be ignored and it can be considered one expression).
Oops.;)
Another thing I'm trying to work out is this:
f(x) = x(x-2)^2
y = f(x) + 2
So it moves up the vertical +2. How do I work out the place where it crosses the x?
sub in y=0 as that is the x axis.
f(x)=x(x-2)²
y = f(x)+2
y = x(x-2)² + 2
y = x(x²-4x+4)+2
y = x³ - 4x² +4x +2
where y=0
0 = x³ - 4x² +4x +2
solve to get x= -0.359304 (with the other two imaginary roots of 2.17965±0.903013i)
Oh and for future reference "²" = Alt0178 on num pad and "³" = Alt0179 :p
To find out where something crosses the x-axis you have to set y = 0 and solve the equation, conversely to find where the y-intercept can be found (the technical name for a crossing point) then set x = 0 and solve.
Yes I know but I've got f(x) = x(x-2)^2 and y = f(x) + 2 so I don't know how to make y=0 before I've put the function into it which I don't know how to do.
I can do it when y=f(x+2) which makes (x+2)[(x+2)-2]^2 = (x+2)(x)^2 which means it crosses at x=-2 and x=0.
But when y=f(x)+2 when the 2 is outside the bracket I don't know how to substitute it into x(x-2)^2.
And no this isn't in for tomorrow, I'm trying to teach myself and just need some help.
f(x)=x(x-2)²
y = f(x)+2
y = x(x-2)² + 2
y = x(x²-4x+4)+2
y = x³ - 4x² +4x +2
where y=0
0 = x³ - 4x² +4x +2
That's complicated.. explains why they didn't ask to work out the x then.:p
Got 0 = x³ - 4x² +4x +2 but not got a clue what to do next, guess I don't need to know for C1..
f(x) = y
therefore:
y = x(x-2)^2 (for the original function) and
y = x(x-2)^2 + 2 (for the shifted function)
You need to expand out the brackets, set y=0 and then solve for x! It always simpler to expand the brackets and that leaves you with what you have to work with.
To solve the quadratic equation remember:
SQRT(b^2 - 4ac) / 2a
gives you the solution where:
y =ax^2 + bx + c
