£312 per year for water, gas, & electric combined seems wildly optimistic. hell, my water bill alone comes to £411.17 per year. ( Severn Trent water, bunch of grasping gits! ).
Our electric bill is around £1,500 a year -.-
What solar panels are you having fitted? How many?
Crystalline ones and however many it takes to generate 4kwp which is apparently the maximum I am allowed to produce.
As I have significant roof space on my Garage we can use the less efficient panels which are larger and so save a few quid. Overall cost is around £12k and we are just waiting for the permissions needed. Should start to be installed in about a month we have been told.
Out of interest, do you have the space/wind to put a turbine in? If you have you should look into it, for that sort of money you could get a wind turbine and be paid rather than be neutral.
Good move. My folks got theirs last year, it's been fantastic. 4 kWp isn't the maximum, just the FiT payment is lower for larger installs so it's not such good value to put in more.
Load of additional hassles with wind, much better off with PV on the small scale.
Depends where he is though, obviously we know now but if you have the space and the money and its feasable, then its definetely the way to go.
It's not definitely the way to go, the wind (1.5-15 kW) FiT is only 26.7 p/kWh compared with 41.3 pence for solar (<4 kW). This negates the capital cost difference. Wind has the extra hassles of planning and maintenance.
But, sure, if you live in a windy place, with no neighbors, a friendly planning officer and you're handy with a geese gun (+scaffold or winch) wind is "definitely the way to go" but for the vast majority of folks, solar is a better bet.
This is why there have been 28,505 PV installs, compared with only 1,329 wind (plus 205 hydro, a few dozen micro CHP and three anaerobic digestion plants). Of the 111MW of new capacity since April 2011, 77.8 MW (70%) has been solar PV.
As I said, its the way to go if you can afford it and have the ability to put it in, im not sure what posting these statistics is intended to do, obviously as the costs are substantially higher then there will be more solar installs but if you want to have be taking more money and energy out of the grid than putting into it, then putting in a wind turbine is the way to do that, especially if its run with a heat pump of sorts.
No that's wrong. The different FiT is there to compensate the differences in energy generation/capital outlay. The rate of return for solar and wind is the same once FiT is considered. The reason why there are 20 times more solar than wind is mostly because for most people solar is more suitable, i.e. wind is not "definetely the way to go" as you said. In fact 19 times out of 20, solar is definitely the way to go!
... if I was building my own property from the ground up tomorrow I would have a heat pump powered by a wind turbine and solar for the hot water. If I could have only one Id have the wind turbine.
