- 8 Jan 2011
I currently have a GTX580 1.5gb card and I am moving up to surround gaming with 3 120hz monitors, totalling 5760x1080. I was intending to move up to SLI 580s with the 3gb cards but been looking at the comparisons against the 6990/6970 xfire.
I actually moved away from ATI/AMD to the 580 because I got so many problems xfiring 5850s.
My Current board only supports SLI but it supports TRI-fire becuase obviously you can use the 6990/6970 combo.
The ATI combo comes out a lot cheaper than sli 580s and even tri-sli580s which match its performance but would need a Mobo upgrade to support.
The only comparison between the 580s and ati combo was back when the 3gb 580s weren't about so I Can't find a comparison now.
1 other good thing about the 580s is I can get the EVGA 3gb models and when I water cool them I still keep the warranty as long as the old cooler is putback on. No EVGA 6990s or 6970s = bye bye warranty when they get water cooled
3 questions I have are.
1)The 6990 has 4gb VRAM but that's 2gb per GPU right? so therefore trifire with the 6970 would be a max of 2gb vram? would that not limit eyefinity resolutions?
2)How loud is this 6990? I was intending to add the SLI 580s to my water cooling loop as I like my pc quiet. I hate the noise of GPU fans and prefer to have 120mm fans running at medium RPM.
3)What would you do?
*edit* Thought of another question!
4)For anyone with the 6990 combo. What are you experiences?
