Just one more, i have put maybe 3 drops in since 7ish and im happy with the strength..is there a set amount to drop in or can i just go on as i am and will i notice a taste difference when there is nothing there etc?
cheers
EDIT: I still go outside to do all my vaping, it just doesnt seem right to do it indoors....must get my head right and remember its not tobacco smoke!
Good to hear that you're getting on well with it!
If you're starting off by filling the carts or dripping onto the filler (ie. putting a few drops directly on the white stuff and letting it soak in for a few minutes) I'd recommend the following:
1. Filling the cart itself:
First, remove the white filler from inside the cart. Drip about 10 drops of liquid into the space inside the cart. If should end up being about 3/4 full. Use tweezers or a toothpick to slowly push the filler back into the cart. It'll immediately start soaking up the liquid. Top it off with 2 or 3 drops straight to the top of the filler now that it's back in. Give that about 3 mins to soak in, then pop the cart on your atomiser and you're good to go for, roughly, 20 long puffs or so I reckon.
2. Dripping onto the filler (not filling the cart as well):
Drip about 3 drips and let it soak in for 4 or 5 mins. Repeat until the filler is wet, but there's no liquid "pooling" on top of it. Pop that on your atomiser, and puff away until you notice that the flavour is absent/extremely weak, or you get a burnt taste instead.
Now, there's also method 3 - my favourite - Direct Dripping:
Remove the filler from your cart. Drip 3 drops of liquid STRAIGHT onto the bridge inside the atomiser (the big cone-shaped metal bit you see when you look it). Give that about 10 secs to soak, then pop your empty cart on and vape away.
Every 3 drops will give you about 5 or 6 nice puffs. You'll notice when the liquid has run out as you'll get an awful burnt taste instead of your usual. To me, that's almost a "cigarette", so to speak. So if you're out and about - 3 drips, puff that dry, putt it away and there's your smoke had.
You'll also know when you've dripped too much as it'll likely flood out through where the battery meets the atomiser, or you'll get a mouth full of liquid when the juice fails to vaporise quickly enough. Not nice, and takes some practice, but it's worth it!
