Best 850w power supply
Whats the best 850w power supply and is not corsair i hate them
Any particular reason you hate them?
They make top quality products and offer great customer service....:confused:
Anywho...
You got a particular budget in mind? One of the best would be 850W Seasonic X-Series which is:
• 80PLUS® Gold Certified Super High Efficiency
• Full Modular Cabling Design
• Patented DC Connector Module with Integrated VRM [Voltage Regulator Module]
• DC to DC Converter Design
• Seasonic Hybrid Silent Fan Control
• Sanyo Denki San Ace Silent Fan
• Conductive Polymer Aluminum Solid Capacitors
• Highly Reliable 105? Japanese Brand Capacitors
• Tight Voltage Regulation [±3%]
• Active Power Factor Correction [99% PF Typical]
• High +12V Output
• High Current Gold Plated Terminals
• Dual Sided PCB Layout
• Ultra Ventilation [Honeycomb Structure]
• Multi-GPU Technologies Supported
• All-in-One DC Cabling Design
• Easy Swap Connector
• Universal AC Input [Full Range]
But at arond £185, very expensive.
Quote from the review:
On top of that, due to its highly overspec’ed components, we could easily pull 1,000 W from it.
The Corsair AX850 & Seasonic X-850 are the best (they use the same platform, FYI), followed extremely closely by the HX850, HCP-850 & XFX BE 850. The XFX is by far the best value out of all of them.
Bequiet PSU's are a bunch of FSP/Topower built units... they're mediocre, not "superb".
I hate corsair bcus i have a 850hx its making coil whine and ive read that many ppl have the same problem even when they did a rma. But what psu do you recommend it should be in the price range of the ax850
Would 850w be enuf for i7 oc 4.0ghz 2 gtx 460 sli overclocked 1 hdd 1ssd p6x58d-e corsair dominator 6gb and haf x
Easy. A decent 650W would be good enough, though I'd get a 750W for headroom.
Not sure how the Haf-X would be a requirement though? :p
Okay not quite 850 but near enough, if you want 'the best' you would have to wait for the Seasonic P-860XP 80 plus Platinum. From what I've read its slated for a summer release?
have to say my Corsair HX850 is totally silent the fan does not speed up on my setup at all in any games and no coil noise at all.
How ever i did get one with a Duff power switch but it was exchanged with no questions asked.
Well good for you but a lot of ppl have this problem anyway just paid for the ax 850
