- 28 Mar 2011
- Space Man INIT
BTW, you can't use 4 of these cards in CrossfireX![]()
Thought you could?
I sent the original trust mail to your trust not the MSN one.
Have replyed to your trust with a new screen shot.
I think you may have mist out on the original message i put in the trust to you.
I missed the bottom.
I know who you are now :s
Thats the best sort of system![]()
Dont forget to post some results,
Free AMD X6 will do it but i will need to look at a hardcore mobo and ram to fit around 2600K
Have you looked at the 2500k?
90-C3CHD0-S0UAY0YZ is the code I have on my unlockable revision1 Asus 6950 OC that I got from OcUK a couple of months ago. The question is would Asus create a new part number for a Revision2.
90-C3CHD0-S0UAY0YZ
