Quick VW golf brake question
6 Mar 2008
Stoke area
Hi all,
need to order some rear pads for the a 2003 mk4 1.6 golf.
For some reason GSF won't let me register, well it will but no email etc. So tried Eurocar parts, put in the reg number and get a list of brake pads.
Upon checking them all it shows that they are for a 1.6 2003 automatic, ours is a manual. Front pads show auto + manual, but rears all say automatic with no mention of manual.
Used their support system to email them, although you can only write about 2 lines. :( No response.
Can anyone here confirm that even though they say auto that they will also fit the manual car?
GSF took ages to send me my login details. They don't ask for auto/manual on that car and the following 3 options are available:
Click For Parts List
646VG013
Fitting Position Rear Axle, For PR number 1KZ, For PR number 1KY, For PR number 1KF, For PR number 1KE;
For manufacturer TRW, Length 105.5 mm, Height 56 mm, Thickness/Strength 17 mm, Excl. wear warning contact
Customs no.: 23914
646RE015
Fitting Position Rear Axle;
For manufacturer TRW, Length 87 mm, Height 52.9 mm, Thickness/Strength 16.2 mm, Not prepared for wear indicator
Customs no.: 20960; 20961; 23554
646VG008
Fitting Position Rear Axle, For PR number 1KD,1KQ;
For manufacturer TRW, Length 87 mm, Height 52.9 mm, Thickness/Strength 17 mm, Not prepared for wear indicator
Customs no.: 20961; 23554
do you not get a lunch break? sheesh
Not today I don't, meetings all day but thanks for the really helpful input in to this thread.
Thanks bat :)
EDIT: Found a live chat option, on eurocar parts, they state it'll work, now, just got to decide on the brands,
Thanks bat :)
Cool. Don't go bargain basement IMO as it's a false economy.
