Best card for 4 monitor setup
16 Jan 2010
I've just inherited 2 nice monitors in addition to the 2 currently on my desk. I use my PC mainly for design work and having 4 monitors would be ideal.
I currently have a 5670 that only supports 2 out. Which card would be the cheapest option to have all 4 monitors spanning my desktop?
I've only got 1 PCIe 16 port so one card would be ideal. I've got a beefy power supply so that won't be an issue.
Any ideas? Been looking at an Eyefinity6 card but it seems a bit over kill just for my design machine.
Thanks for that - looks like the 6870 is the winner. Might even be able to play some games on that too.
It's 4, but there is an ASUS model that supports 6 right away, but it's a 3 bay slot monster.
The 6900's can infact support 6 monitors, but an unreleased break away box is needed to daisy chain the monitors.
http://www.amd.com/us/products/desk...6950/Pages/amd-radeon-hd-6950-overview.aspx#2
"AMD Eyefinity multi-display technology
Native support for up to 5 simultaneous displays
Up to 6 displays supported with DisplayPort 1.2 Multi-Stream Transport
Independent resolutions, refresh rates, color controls, and video overlays
Display grouping
Combine multiple displays to behave like a single large display"
For 3 monitors you need 1 with a DisplayPort connection or appropriate adapter.
For 4 monitors you need 2 with DisplayPort connections or appropriate adapters.
For 5 monitors you need 3 with DisplayPort connections or appropriate adapters.
For 6 monitors you need 4 with DisplayPort connections or appropriate adapters.
