I'm looking for a laptop to replace my netbook (I have a desktop for gaming; so that's not an issue).
I'm not really sure what's out there for laptops and I'm having trouble finding the sort of thing I need.
I want it to have:
-11" to 13" screen
-2GB RAM
-Dual core (I'm fixated on Intel's line here TBH; the ultra low voltage line seems like a good bet)
-Battery life of at least 7 hours when browsing the web/word processing while connected to WiFi
-Lightweight; definitely not more than 2KG and preferably closer to 1.5KG
-Thin
Ideally I'd want around a 60GB SSD but I'm prepared to install one myself if needs be, I can sell the laptop HDD. Also, Windows is not required but unfortunately all I can find is laptops with Windows on... would have liked to have saved £50 here
Budget; well I don't really want to spend more than £500 but could go to £600 if it's something I really like. I've seen the Alienware M11x at £500 (great value!!) but this seems like overkill as I don't need the discrete graphics and the case is a bit garish. I thought if that was £500 then surely I'd be able to find something a bit cheaper without the extras I don't need?
I want it to have:
-11" to 13" screen
-2GB RAM
-Thin
