just wondering what lucky escapes other people have had...
a while ago i was helping my friend in their back garden cut down some trees. He had a chainsaw and the chain was loose (you can see where this is going right?!)
after a while we needed to tighten the blade. the chainsaw has a safety system whereby you need to press a button and pull a trigger to start it up. so when he asked me to HOLD THE BLADE TIGHT, i was a bit unsure! especially as he had not pulled the electric plug out the wall ot switched it off!
'nah dont worry, look you can't start it by just pressing the trigger, it needs the button to release it see? these things are built for safety!'
so i grabbed the blade with both hands and pulled back, squeezing pretty damn hard! After a couple of minutes of trying to tighten it i suddenly let go. dont ask me what made me do it but something told me something was not right. when you get a feeling like that you go with it!
so i dropped the blade, releasing my fingers. at the same time the blade spun up!!!!
now if ever anyone has ever used a chainsaw you will know that they speed up really fast! if you were holding one and it spun up, no way would you be able to let go before you lost your fingers!
as it happens, i let go just before the blade spun up, so all i got was a paper cut!!
In fact although the skin was split, i didnt even bleed, so all this superfast tree felling killing machine did was cut the the outside layers of my skin!
i still cant believe that i still have all my fingers after something like that!
so, was anyone else dumb, or lucky enough?!
