All is well so far!
Ordered at around 11:00am on Thursday. DPD Website stated a 3:25pm-4:25pm delivery time for yesterday. The parcels arrived just before 4:00pm, with everything safe and sound and very well packaged. Great service from both OcUK and DPD.
Spent much of last night on the build. So glad I bought the Fractal! Build quality is immense, looks great and even my usual spaghetti junction of cables doesn't look half as bad! Only slight gripe is that the front panel LED doesn't seem to be working. Will have a look at it later but if that's all it is then it doesn't really bother me. Made a rookie mistake while fitting the A50 and as a result had to reapply the supplied thermal paste
. Fans seem a bit noisy at the moment but it isn't something a bit or tinkering won't fix. Having both side panels off probably doesn't help either
All in all, for my first full build, things look very good so far. All drivers installed. Took around 5 minutes to install Windows 7
eek
, and acheived a 5.9 Windows rating which is promising.
Been running Prime95 for the past hour having overclocked to 4.4GHz at just under 1.30V, no problems thus far.
Sorry for the lack of pics, all I currently have is the camera on my phone, which is worse than bad. I might as well draw the rig in Paint and show that instead. Hoping to borrow mum's camera later
Here is the spec once more.:
Gigabyte GeForce GTX 560Ti OC 1024MB GDDR5 PCI-Express Graphics Card
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
MSI P67A-C45 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION **
Fractal Design Define XL Full Tower Case - Titanium Grey
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9)
Antec High Current Gamer 620W Power Supply
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366)
Sony Optiarc AD-5260S 24x DVD±RW SATA ReWriter (Black) - OEM
Akasa 8-Pin 30cm PSU Extension Cable
