Joule Creates Renewable Fossil Fuels At Unlimited Quantity.
Hydrocarbons are made of carbon, hydrogen and oxygen. The idea would be that the bacterium would "eat" the CARBON diOXIDE and somehow combine that with the diHYDROGEN monOXIDE around it to form hydrocarbons. However, to create hydrocarbons it would have to be imparting energy to the molecules in order to form them, and where is it going to get that energy from? And if it has to take in energy from somewhere in order to impart that into the hydrocarbons, then unless we are hooked on forming hydrocarbons, then there would be more efficient ways using the bacterium's energy source.
It isn't even a matter of chemistry - physics can tell you that this isn't likely to be viable.
it sunlight.
Photosynthesis normally turns carbon dioxide into sugar and all the carbohydrates the plant needs to build and feed it's self, now though these bacteria also produce a extra hydrocarbon and excrete it.
it's like modified photosynthesis.
And all the mas of the plant life around you shows you how capable that is of turning the co2 in the atmosphere into a solid (or liquid) product.
I'll believe it when I see it. Going by other similar stories I see on the net makes me think this will be the last I hear about it.
couldn't agree more, we get at least 2 of these stories a year.
Common sense says to me "why not", all fossils fuels are just trapped sunlight anyway, but obviously it's not that simple.
Whoops.
I wonder how much work it is to keep the bacteria alive and in working order. It might be that it's more energy intensive to maintain their conditions than makes it worthwhile.
one problem all the other ones found is the algae just grows on the surface of the pipes/bags/tank and blocks all the light, so 90% of the space is wasted as they an only grow on the very edge where there's light.
A few I've seen are lots of glass tubes/pipes to increase area, one did lots of little plastic bags (that's this one i think)
Don't believe that this will lead to anything and probably for the best, the environment has been damaged enough through emissions of sulphur dioxide and other toxic byproducts of fossil fuels.
I always thought for it to be a hydrocarbon it has to contain only carbon and hydrogen such as ethene (C2H4) whereas ethanol is not a hydrocarbon as it contains oxygen
(C2H5OH).
Are there other types of hydrocarbons other than alkenes and alkanes?
