what engine oil do you use?
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
After reading "What's in your boot" thread, I am putting the basics into the boot but when I got to the Engine Oil part, I am a little stuck. Went to Halfords and I am confronted with about a dozen different brand/types. There are synthetic ones, ones for sports car (are they better?).
What do you get?
The car is a only a standard Yaris 1.8L Petrol.
5w30 semi-synth from memory.. check to see what oil was put in on the last service, best to top up with the same oil :)
I'm supposed to use mineral oil but use semi 10-40
I use castrol gtx normally stock up on it when it invariably pops up cheaply every so often
What oil does the handbook say it needs?
Should have thought of that, i keep forgetting the car comes with a manual lol
It lists 2 types as the Manual is for all Toyota Yaris'
1KR-FE Engines & 2ZR-FE Engines.
Turns out 1 KR-FE is the 1.0L ones so thats out
http://en.wikipedia.org/wiki/Toyota_KR_engine
leaving the 2ZR-FE
http://en.wikipedia.org/wiki/Toyota_ZR_engine
Looks right, which it says:-
SAE 0W-20 is the best choice, if SAW 0W-20 is not available then 5W-30 may be used until the next oil change.
[TW]Fox;19299623 said:
Castrol Edge 0w30.
Though not sure how much of a help what I put into my completely different car is to you, shouldnt you be asking us what you should get not what we get? :p
My noob knowledge in engines thought there were only 2 types, oil for Diesel and oil for Petrol. Pistons are Pistons right? :p
Only did I realise when standing in the engine oil aisle I as confronted with more selection than what Durex offers. lol
The correct type will be in the handbook. If it is anything like the t-sport that went before it, it will be 5w30 semi synthetic.
Silkolene 10w50 pro s for the scooby
Fuchs titan xtr 10w40 for the diesel metro as it's the cheapest that met the top oil standards for derv.
