NZXT Phantom Red Limited Edition *Lotsa Pics*
ultra high end graphics card
ultra high end motherboard
catastrophically mediocre cpu cooler
:confused:
i cant see the point in buying an outrageously specced overclocking motherboard and then restricting its capabilities with that
I couldnt afford a full water cooling setup at the point I bought the stuff... The antec was sufficient for my needs and I can get a decent overclock with it. It was only hitting around 50 something degrees at the moment on full load with prime95 CPU only test at 4.4ghz.
I could probably push it further, but I didnt see the point right now. When I buy stuff I tend to get the best I can within my budget, the cpu cooler seemed the best part to go easy on so I could get the the other parts. This is by no means a "mediocre" cooler. If anything I would have complained about the psu....
Why limit the potential of the setup with a poor performing board?
I dont think the graphics card was white, I think it was silver but ill double check :P
Hey mate, if you want to watercool in the future, I can help you mod it :)
This is my phantom at the moment:
Top 360 rad, bottom 240 rad, custom side window. Beans :)
Yours is rather nice though :)
Wow that case looks amazing!
I am seriously tempted by it. Bad news is I will need some more spare cash to fill it up with shiny new components :p
Only because I removed the DVD drive in that pic, it sort of balances on it :D
As soon as I set up PP on the top rad that won't be a problem :)
Will do, I'm getting some mayhems dye and a couple of cold cathodes to celebrate if and when Msi replace my magical exploding motherboard! :)
