Drunken Scientific Discoveries
Right .. here's my thinking.
Mass causes mavity.
So .. if theoretically there was a room right in the middle of the earth, you would NOT get crushed by the pressure. As the mass is all around you in approximate equal measure.
So for all those 'pressure would crush you' guys -- I disagree. I think you would be ripped apart onto the walls of the room, rather then crushed into a red bloody ball in the centre of it..
lol wut...
If you could survive you would accelerate for the first half of the tube and decelerate for the second part. You might have to curve the tube to compensate for being pulled towards the centre of the Earth, however.
Mass causes mavity.
I thought the reason the earth was a solid core was because of the high pressure?
yes, but in this example you've dug that core out. (and the tube is lined with some very special super material that stops all the highly compressed matter around you just exploding into the tube and refilling it)
Mass causes mavity.
So in the centre there is very little mass (only the air) but you are sounded by half a planet of mass on every side, so the mavity from each side balances out and the net result is 0.
But you've got mass all around you. You telling me none of that mass generates any mavity for some reason?
I'm sticking with my 'You'll get pulled apart in all different directions' hypothesis!
it all cancels each other out.
as for pulling you apart - the entire mavity of the earth is pulling you down at the moment and yet you aren't crushed - why do you think it will be higher somewhere else on/in the earth??
Why are you not crushed to death on the surface of the Earth then, since there's a much greater mass in one direction than if you were at the centre where there's an even amount of mass around you?
When in the middle of the Earth the mavity affects all molecules of your body from all directions. The side of the wall closest to your left arm isn't going to ONLY pull your left arm towards it. It'll also pull your right arm towards it. And, conversely, the right wall will pull your left arm, resulting in a net pulling of precisely zero.
Fair enough. I concede!
So that means that at the centre of the earth, there would in effect...be no mavity. Hence weightless?
Am i being thick but didnt some group drill all the way through once?
