- 18 Nov 2010
They do, its just your perception that changes with whats acceptable.
I disagree.
You load a for instane a 100K MS Word file on a PIII 1Ghz CPU with 512Mb of RAM running Windows 98SE with Word 97
Then you load the Same 100K MS Word file on a P4 3Ghz CPU with 1Gb of RAM running Windows XP with Word 2003
Then you load the same 100K MS Word file on a Intel i5 2nd Gen CPU with 3Gb of RAM running Windows 7 with Word 2010
The loading speed is almost the same or within half a second of each other, due to the fact that with newer software eg O/S & Word versions require more powerful PC's the actual process of loading the 100K file is the same ish no matter what spec your PC is.
