- 8 Apr 2004
Hi all, I have a IBM Lenovo T500 laptop from the United States that was dropped and resulted in a cracked panel. I bought a new panel and installed it and while I could see the desktop at a certain angle, there was absolutely no backlighting at all, even when using the fn keys to max out the brightness.
It outputs fine via VGA to an external monitor.
I double checked the LCD panel cable and found a small copper connection snapped off, so I ordered a new cable thinking that would solve the issue. Again, no backlight.
So I thought surely it must be the inverter which I ordered and installed. Again, still no backlight!
I'm guessing it must be the motherboard now which could have been damaged when it was dropped. In which case, I won't want to spend anymore money fixing this. But if the motherboard is damaged, then why would it still output fine on an external monitor?
Does anyone have any more ideas cos I've run out of them
Many thanks.
Many thanks.
