Northbridge temps
10 Aug 2009
Malvern
I recently found out that one of the temps on cpuid was my northbridge and is running at 80*c,its o/c to 2.4 but doesnt matter as even when it is set at stock its about the same,gets up to 84*c at times but never any higher, is this anythiing to worry about?seems high to me,i had this board a couple of years now
ok, did that no problems. applied new compound knocked a few degrees off so i might go for the spot fan
anyone know if the after market heatsinks are any good?
now running northbrige speed and voltage at stock, still no difference, guess ill have to go for the spot cooler, thanks for your help
Pressure also helps reduce temps, replacing the plastic pins with some nuts, bolts & silicone washers & nipping them down fairly tightly should bring temps down a bit more.
