Multiple stereo outputs from MoBo
1 Sep 2010
Guys,
I just bought myself a nice new separates hifi system that I have wired up to the backpanel of my PC with a 3.5mm jack to listen to music - it sounds great. However, sometimes I will want to continue to use my little creative desktop speakers - i.e. when the Mrs is watching TV and I'm gaming.
What is the easiest way to wire this up so that I don't have to mess about at the back of the computer to move the wires over?
I have 6 ports on the internal sound card of this MoBo, is there a nice piece of software that can persuade the board to play out of the main 'line out' and (e.g.) the side speaker output as simple stereo? I can then just switch the amp input on the stereo or turn down the creatives when I don't want to listen to them.
Recommendations please...
Yea that was my first plan...
For some reason the front port doesn't seem to work, the front USBs work, so I have something configured wrong but I can't figure out what. I have checked the cabling to the MoBo and the Bios settings, will check for driver updates tmw.
Routing the creatives to the back might be neater.
I am never going to use 5.1 surround sound etc from the computer so figured I might be able to utilise the back ports for something.
Get a sound card, onboard is shown up for being the sub par audio that it is, if you have a nice separates speaker setup. You could either use the front panel, or get a switch box. They can had pretty cheaply from the famous auction site.
If you have a Realtek onboard chip, install the Realtek HD Audio manager - this lets you specify what items are plugged into which sockets (multiple front speakers is an option)
Do you not have an optical/spdif out on the motherboard? Use this to the amp and then the jack to the speakers
Normally separates hi-fi's do not have SPDIF connections. I'm quite surprised how many people suggest this. Most of the time, an amp, is just an amp. I think Onkyo are one of the very few that have a stereo amp with a DAC.
I've managed to get the front jack working and have configured the default devices correctly in the control panel and as 3dcandy said it switches over automatically. BUT as marsman says I now need a sound card as the quality is clearly inferior to CD even with my untrained ears! I'll cruise the forum and look for suggestions...
Thanks guys
