Right, after some research it seems that if I replace the stock fans on my h70 I can get about 5degs cooler on my 930.
So, I think the best option would be http://www.overclockers.co.uk/showproduct.php?prodid=FG-059-AK&groupid=701&catid=57&subcat=4
although
http://www.overclockers.co.uk/showproduct.php?prodid=FG-004-NC&groupid=701&catid=57&subcat=4
seems like it may be a good option as well.
Basically, I am not that concerned with noise as the system isn't on at night or anything - I just want maximum cooling. My only other concern is that I want to be able to literally unplug the current stock fans and plug the new fans into the same socket to avoid having to re-wire etc.
On a separate note, I have another system that is using an h50 - would it be possible to put two fans on that (push/pull) or would there be problems?
Thanks,
Madals
although
Thanks,
Madals
