Today we have ultimate backup and cooling solutions at a tasty price drop. By popular demand these items have been craved for on today only's special deal. Now is your chance!
Western Digital Caviar Green 2TB SATA-II 64MB Cache - OEM (WD20EARS) @ £53.99 inc VAT
WD Caviar Green SATA hard drives reduce power consumption by up to 40% and offer best-in-class acoustics and operating temperature. Based on WD's exclusive GreenPower technology, these drives are designed to deliver power savings as the primary attribute. As hard drive capacities increase, the power required to run those drives increases as well. WD Caviar Green drives make it possible for energy-conscious customers to build systems with higher capacities and the right balance of system performance, ensured reliability, and energy conservation. They are ideal for PCs, external storage and other devices that require lower power consumption and cool, quiet operation.
- Capacity: 2TB
- Cache: 64MB
- Interface: SATA-II
- Spin Speed: IntelliPower
- Warranty: 3 Years
Only £53.99 inc VAT.
ORDER NOW
Corsair Hydro H70 High-Performance Liquid CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) @ £71.99 inc VAT
The Corsair Hydro Series H70 is the best choice for high performance CPU cooling. A worthy big brother to the already excellent Hydro Series H50, the H70 improves upon the design in every way.
A low profile pump and improved cold plate allow for even easier mounting to your CPU. Compatibility with all modern AMD and Intel desktop CPU sockets is included in the box. A higher-performance radiator with nearly twice the surface provides even more room for liquid to get cool before it returns to the cold plate.
And as if that weren’t enough, the Hydro Series H70 comes with twin high-performance 120mm fans, optimized for a push-pull configuration, to allow maximum airflow through the radiator. The Corsair Hydro Series H70 is the best choice for a high performance CPU cooler on the market, bar none.
- A new improved cold-plate design more efficiently transfers heat.
- A thicker radiator increases the cooling surface area for even better cooling potential.
- Dual 120mm fans with multiple speed options that let you optimize the maximum cooling and minimum noise.
- Includes mounting hardware compatible with all modern CPU socket designs
- Radiator Dimensions: 120mm x 50mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Selectable 1600 or 2000 RPM
- Air Flow: 50.35 – 61.2 CFM (per fan)
- Static Pressure: 1.8 – 2.3mm H20 (per fan)
- Noise Level: 26 – 31.5 dBA (per fan)
Only £71.99 inc VAT.
ORDER NOW
- Capacity: 2TB
- Cache: 64MB
- Warranty: 3 Years
ORDER NOW
ORDER NOW
