My Cooler Master Stacker 830 Nvidia Edition makes a lot of noise on start up from vibration. Bother cases are CM and both of our sounds are from hard drives. I think its vibration causing your noise.
Yep, like I said, exactly the same as what happens to mine and mine is vibration. So we probably have the same issue, I just haven't rubber padded everything as im making a new PC in a months time.
But until I hear the noise from your case and you cant describe the noise it, we wont know for definite.
I would say this is vibration, simply because it is the exact same problem I have, and I know what the problem is on mine. Have a search for a hard drive anti vibration kit.
If anyone else fancys giving their two cents, please do so.
