pictures: http://s1110.photobucket.com/albums/h452/killianzz/My pc/
Hi everyone.
Seeing as though I used this forum quite a lot to spec my new pc and bought most of my components from OCUK
I thought I would give it a review now that it is built.
Anyway, this is my first build. My dad had built me budget computers in the past, and I fancied a powerful pc for when I go
back to university. It needed to be quiet and powerful, for use as a HTPC and gaming. As this is my first build any feedback
of any type would be great, also any possible improvements would be appreciated.
The specs are as following:
Case: Lian Li PC-P50 with window.
Motherboard: Asus P8P67 Pro
CPU: 2500k @4.5 ghz
CPU cooler: Noctua D-14
RAM: OCZ Platinum 2x2gb 1600mhz ddr3
GPU: Msi GTX 570 twin frozr II
HDD: 1TB Samsung spinpoint F3
PSU: Corsair TX750W
Keyboard: Razer Lycosa
Mouse: Gigabyte M6980
Monitor: Samsung 23" 1080p job
Windows 7 Ultimate
Original budget was £600 (oops) but final cost was £1000 (excl monitor + OS).
Very impressed with the case. Gaming case cooling performance without the horrible tacky looks. Sleek and oozes quality,
while keeping a discretely aggressive look. Wasnt sure about the window and leds, but with the matching keyboard and mouse leds
I think it looks brilliant. Fans are quiet but I am fussy and will probably replace them with some silent ones. 2x 140mm
and 2x 120 mm, any recommendations? Strangely when I start it up, it turns off after a second, then a couple of seconds later
starts up fine lol. Cable management was ok, could have done with a few more holes so was a bit limited. Also, had to remove
motherboard to fit heatsink backplate. Average CM for a mid tower case I suppose, no experience though so Im not sure,
did the best I could.
P8P67 pro is a great innovative motherboard. Overclocking on it was easy, 4.5ghz reached on 1.27V and I havn't tried any lower
yet. Had some issues with overclocking, see RAM. Dont know what else to say about it really, does everything I need it to.
The 2500k is a remarkable cpu, and that is at stock. I was going to get a 6 core AMD but after receiving a lot of persuasion
and looking at a few benchmarks I decided on sandybridge. Good decision I must say. The D-14 heatsink is an absolute
monster. Keeps my 2500k below 52 deg c under load at 4.5ghz and idle temps are equally impressive. It is quiet and very
powerful. It is MASSIVE though I must say, but not an issue with my case.
My RAM is the only disappointment of my pc. Having set the timings and voltage in the bios, it fails prim95 blend test and
memtest at 1600mhz. Not really an issue during games apart from the odd 'blip' but I would expect it to run at its advertised speed.
Any advice?
My graphics card is simply awesome. I took the longest amount of time choosing this component. About a month of looking
through reviews and forums I decided on the 570. I was going to get a 6950 and unlock the shaders and overclock, but
I decided just to fork out a little more money for my ears sake. I can never hear the fans on it, and it maxes crysis warhead
and almost the original crysis. Stock core is 780 and I can reach 820mhz + on stock voltage, although I leave it at stock.
Always stays cool and quiet. Havn't seen it get over 70 deg c yet. Very impressed.
HDD is quiet and fast, good buy.
PSU looks cool and feels like a quality product. I will only be able to comment on its reliability after a couple of years.
It seems silent. It is not modular, but not really a problem as I cable tied the extra cables and hid them under the hdd tray.
The razer keyboard looks good, and feels good. Only had it a few days but it seems like a good buy, if slightly overpriced.
Mouse was a bargain, never owned a gaming mouse before but it seems like good value. £23 on ocuk for a comfortable and
pleasantly styled gaming mouse cant be bad.
For £1000, I honestly don't think I could have built a better computer. It does everything I need it to perfectly.
Runs cool and quiet while producing ample power. Games look lush and run jitter free.
Future upgrades: HD tv-tuner, 28" 1920x1200 hannspree monitor, saitek joystick, another 1tb hd, quiet case fans,
maybe an SSD, maybe another 570 (hmmmm doubtful, but possible none the less)
I hope this helps anyone who is thinking of buying a similar system, although I doubt it will unless, like myself, you
are a first time builder. Please give me some feedback, good or bad, or any advice etc.
Please bear in mind that I bought the components in March. I built it in March too, so this review is a little bit old, but at least
that means that I can properly comment on it. Also the location is only temporary, It will have a proper desk soon
Hi everyone.
CPU: 2500k @4.5 ghz
PSU: Corsair TX750W
Windows 7 Ultimate
Any advice?
