- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys,
We have teamed up directly with MSI to bring you two great motherboards with free CPU Coolers. The high end Sandybridge MSI Big bang comes with a free CM V6GT cooler and the mid range Sandybridge MSI GD65 now has a free CM Hyper 212 Plus with it. Stock is limited, so it's strictly first come, first served!
MSI Big Bang Marshal Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) **B3 REVISION** with FREE Cooler Master V6GT CPU Cooler @ £259.99 inc VAT
Key Features
Military Class
- HI-C Capacitor - More Stable Tantalum Core, Higher reliability and Longer Lifespan
- Super Ferrite Choke - 30% Higher Current Capacity, whistle-free design
- Solid Capacitor - 10 Year Ultra-Long Lifetime, low ESR
OC Genie 2
- Intelligent detect hardware settings
- Automatically overclock CPU and Memory in 1 second
- Increase CPU speed up to 4.GHz
Click BIOS
- New UEFI BIOS with graphical menu
- User Friendly Mouse or Keyboard Controlled Interface
- Multi-language support
X-Fi MB2 Audio
- Cinematic Gaming Audio
- EAX Advanced HD 5.0 Support
- THX TruStudio PRO Support
Specifications
- Intel LGA1155 Socket
- Intel 2nd Generation Core i7/i5/i3 & Pentium/Celeron Support
- 4x DIMMs with support for DDR3 2133/1866/1600/1333/1066 up to 16GB MAX
- 8x PCI-Express x16 Slot (two 16x, two 8x, four 1x)
- ATI CrossfireX and Nvidia SLI Support
- 4x SATA 3Gb/s ports with RAID
- 4x SATA 6Gb/s ports with RAID
- 2x eSATA ports
- 12x USB 3.0 ports
- 2x IEEE 1394 Fire
- 8 Channel HD Audio with X-Fi MB and THX TruStudio Pro
- Gigabit LAN
- Triple BIOS
V6GT follows in the footsteps of the revolutionary V8 and V10 CPU coolers from Cooler Master. Designed with a muscular engine look, the V6GT fits nicely with any performance hardware. The V6GT also features new mechanical structure that includes: V-shaped heatpipe array, asymmetrical aluminum fins (which are densely stacked for optimal cooling), two 12 cm silent fans with enhanced airflow, PWM speed control function, and DynaLoop™ long life bearing technology, snap-on cover to conveniently replace fan if needed.
- Socket Support: Intel Socket LGA1366 / 1156 / 1155 / 775 and AMD Socket AM3/AM2+/AM2
- Copper base heatpipes
- V array of heatpipes
- Densely stacked fins
- Dynaloop bearing fan
- Quick release fan cover
- Colour changing LEDs
- Dimension: 131 x 120 x 165 mm (5.2 x 4.7 x 6.5 inch)
- Weight: 939g
- Heat Sink Material: Copper base / 55 x 0.3mm Aluminum fins / 6 heatpipes
- Fan Dimension: 120 x 120 x 25 mm (4.7 x 4.7 x 1 inch)
- Fan Speed: 800 – 2200 RPM (PWM)
- Fan Airflow: 34.02 – 93.74 CFM
- Fan Air Pressure: 0.43 - 3.30 mm H2O
- Bearing Type: DynaLoop™ Bearing
- Fan Life Expectancy: 40,000hrs
- Fan Noise Level: 15– 38 dBA
- Connector : 4-pins
- Heat Pipes Dimensions: ø6mm
SAVING £39.98 INC. VAT.
Only £259.99 inc VAT.
ORDER NOW
MSI P67A-GD65 Intel P67 (socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** with FREE Coolermaster Hyper 212 Plus CPU Cooler @ £139.99 inc VAT
Key Features
Military Class
OC Genie 2
Click BIOS
Specifications
- 4x DIMMs with support for DDR3 1133/1066 up to 16GB MAX
- 2x PCI-Express x16 Slot
- ATI Crossfire and Nvidia SLI Support
- 3x PCI-Express x1 Slots
- 2x PCI Slots
- 2x eSATA ports
- 4x USB 3.0 ports
- 10x USB 2.0 ports
- 2x IEEE 1394 Fire
- 8 Channel HD Audio with THX TruStudio Pro
- Gigabit LAN
- Dual BIOS
Succeeding the popular Hyper 212, the Hyper 212 Plus carries on the legacy of providing a great balance of performance and noise level during high and low speed operations.
Hyper 212 Plus is Cooler Master's first cooler to be equipped with an all-in-one mounting solution that includes LGA 1156 and 1366. Direct Contact heat-pipe is now also utilized in this latest update.
- Versatile all-in-one mounting solution for Intel Socket LGA775/1155/1156/1366 and AMD Socket AM2/AM2+/AM3
- Silent operation with minimal noise level at 13 dBA.
- Excellent airflow design with compact heatsink dimension.
- Computer aided heatsink design provides fin optimization with perfect balance between high and low speed operation.
- 4 x Direct Contact heat-pipes for seamless contact between CPU surface and cooler.
- Wide-range PWM fan with unique blade design for excellent airflow.
- Upgradable to dual fans and swapping of fans with extra fan-clips included.
SAVING £19.98 INC. VAT.
Only £139.99 inc VAT.
ORDER NOW
Key Features
Military Class
OC Genie 2
Click BIOS
X-Fi MB2 Audio
Specifications
- 2x eSATA ports
- 12x USB 3.0 ports
- 2x IEEE 1394 Fire
- Gigabit LAN
- Triple BIOS
- Weight: 939g
ORDER NOW
Key Features
Military Class
OC Genie 2
Click BIOS
Specifications
- 2x PCI Slots
- 2x eSATA ports
- 4x USB 3.0 ports
- 10x USB 2.0 ports
- 2x IEEE 1394 Fire
- Gigabit LAN
- Dual BIOS
ORDER NOW
