Case looks very tidymakes me wish I never cheeped out on a case ^^
Friend of mine just dropped by and said I've gone overkill with the fans in my case... Have I?
If they're doing the job/cooling that you want and it's relatively quiet - which it should be at low RPM then it's not a problem.
You may be able to lose a fan and notice no/negligable cooling difference but you wont no unless you experiment.
How are the fans orientated - around the case - i.e. intake/out take?
EDIT: If you exclude the RAD fans - you have a pretty standard amount for a quality set up...
Looks fine - temps can't be an issue and hopefully it's relatively quiet?
But where are all your HDDs?![]()
I'm going to use one ssd for os the other for games and everything else is stored on my servers.
Waiting on a rma on my SSD from OCUK but when that back all that will be in the case is 2x 60 SSD's and can get rid of that one hdd in there atm.
If you're just using it for games and OS wouldn't it be better to put them into Raid 0?
there not the same spec brand SSD's just an old one I had from another rig and one that I picked up at ocuk on a offer.
Your fans look fine to me mate.
Don't suppose you'd mind trusting me the location where you got them screws for the H50 radiator would you?
