A) They have had to shrink the transitors in order to fit two 6950 GPU's onto a single card.
I thought it was 2 x 6970 GPUs?
I also suggest 2 x 6970s with decent coolers. I have the 6990 and you cannot turn CFX off if you need to
Good luck!
xfiring 6950's is the way to go, unles your Uber rich and would eventually crossfire 6990's![]()
if your set on it then you want 2 of these:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-119-MS&groupid=701&catid=56&subcat=1752
then unlock the shaders to 1536 making it a 6970, dont listen to people saying dont flash it you'll brick it because its pretty much impossible... IF the flash goes wrong then you flick the bios switch on the card (the card has a back up bios incase of anything going wrong) and it flashes the ruined bios back the the origonal, ive done this, and when i did it my PC locked up so i had to hard restart, and my 6950/70 is fine... so flashing yours really wont be a problem, also, if the card breaks at any time you also can flick the bios switch again and it'll flash it back making it impossible for you to fin out that its been flashed, and Gibbo said he'll still honor the warrenty if you flash and it breaks so you have to return,,,
