I've just put myself a rig together (specs in my sig) and am noticing a very annoying thing with my graphics (MSI Radeon 6950 2048). When I play in full screen I get a horrible flickering whenever there is any fast movement (i.e. a cutscene).
I've spent the past two days trying to figure out why using all my searching tricks, found post after post of people having the same problem but no mention of a fix or the good old "Never mind; I fixed it" posts which really make me mad
My initial setup was DVI and 1080p, this is what I've tried so far;
- HDMI connection - Doesn't fill screen (turned off scaling to rectify) and leaves all my colours looking weird and text blurry (couldn't correct).
- VGA connection - Same problem with lines appearing horizontally (like DVI)
- Mini Display Port to VGA Adapter - As above
- Mini Display Port to DVI Adapter - As above
- Borrowed a second monitor from work - Same problem
If I play in windowed mode then the lines don't appear so really not sure what's going on. Should I return it and ask for a replacement or would I have the same problem?
Any thoughts or suggestions would be great, pulling my hair out at the minute. Really want to get into my game but the cutscenes annoy me too much and spoil the experience some.
Help
Help
