Crazy watercooling idea
19 Jan 2011
As part of my ongoing (and possibly never ending) custom case project I've decided to go watercooled, and I plan to have 2 loops to boot. I have a nice space along the top of the case for a triple rad, but I was struggling to find a place for a second rad. Then I had a brainwave:
I've got a bit of space at the front of my case that's about a cube in shape. what if I had the following setup:
fan > rad > fan > rad > fan
intake from one side of the case and exhaust out the other.
So my question is: is the second rad any benefit at all? Will I see better temps, or will the fact the hot air from the first rad mean that the second rad will be redundant?
Just throwing it out there!
Exhausting a radiator onto a radiator will do nothing to aid cooling of the loop. If both rads were in the same loop, then the temperature would even out to be around that of the single rad. If one rad per loop, then one loop would be cool, the other hot. In essence, you are making a heat exchange.
Not sure if I'm allowed to link to it, but google 'radiator sandwich testing'.
Summary is that it's basically not good value for money. The main problem is the second radiator totally blocks off airflow from the first set of fans - the hot air itself won't affect temps that much.
If you have absolutely no space in your case, leave about an inch or two inches between the two rads, and make sure your fans are all in push. That way the static pressure requirements for both sets of fans is greatly reduced. Also, you'll need to use low fpi rads.
heres another idea for you: mount the 2nd rad at the back of the 5.25 inch bays:
*link to 5.25 inch bay radiator adapters removed*
googles radiator sandwich testing, interesting reading
I'll probably have a complete rethink now anyway. Maybe 2 radiators each with one fan (in push) drawing air from the bottom and blowing out the side?
Anyway, thanks, that's one idea of the list!
not sure what cases the ones i have linked will work on, but it gives you an idea of what i mean
Would edit that link as it's technically a competitor :(. OP - just search 5.25 radiator bracket.
It will work. But not great results. You would need some good fans for it to work and will end up being louder that if you were to air cool your parts.
Could you not put a rad on the out side of your case
Tell him to edit it then quote it lol
rjkoneill Ive seen you twice in a few days telling people not to do some thing with no explanation at all. Just a basic dont do it.... Do you not give reasons when you give comments like that
no - i dont need to.
if i say that something is a bad idea, it is because i have tried it myself.
i only speak from experience.
check my build log, you will see that i have done it and founf out that it is pointless.
put your experience into what your saying. your a mod... are mods supposed to moderate and also guide people.?
not make basic comments that we would get a warning for spamming.
OP is asking for our help not just a no dont do it.
ok, i will bear that in mind. does the fact that i am a moderator of this subforum not indicate that i may know what i am talking about?
oops, didnt realise it was a competotor.
link removed
@rjkoneill: you might be a moderator, but i'm sure people would like to know why they shouldnt do it. also, being a moderator doesnt make you correct 100% of the time, because as you moderators say, your only human, and you can make mistakes
so if you say dont do it it must be right without backing it up?
my link says different and the other thread im taking about the other guy showed info different to your dont do it. he also asked for a reason to why. no reply
its not professional.
fan > shroud > ThermoChill PA160 > shroud > fan
If you can find one (and it fits) a PA160 would work a treat in that location - other wise a single deep rad would work.
He's already said he'd keep it in mind...you having a bad day or something?
@ OP: what case is it?
