Hi all, just this week I installed my new pc bits, which consisted of a new mobo, i5 2500k, xms3 ram and the eco coolit, the system is in my sig. well all installed ok and was concentrating mainly on installing win 7 64 and sorting out that so did not go for any overclock on the 2500k, I did however run 1 instance of prime blend just to check all was good @ stock and left it at that. below are what it is like on everything stock, all seems ok to me.
Anyway, today I decided to get some juice out of the 2500k and went straight to bios and cranked up to 1.30v on the core and thought I would just check temps at 1.30v without increasing the multiplier, so I saved the setting and re-booted the system and the thing wouldnt boot, the pc`s fans come on for about 15 secs and then shutdown, then it would turn on again on its own and same thing over and over, I tried clearing the cmos, by taking the battery out and clearing via the cmos jumper, all to no avail!
So I left the pc off whilst I had a bath and low and behold the thing fires up 1st time, which has left me confused that something in my system is not working as it should. I guess it is one of three things, the psu,mobo or cpu or could it be that I have a short somewhere?? anyone have anything similar to my issue? dont want to random rma!
Thanks in advance!
Thanks in advance!
