The BIG Weekend - At OcUK!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
We have hand picked a range of products to enable you to build a brand new PC - offering a discount on each of these products, this means you can save big bucks this weekend. We are offering both AMD and Intel options and ATI and NVIDIA. Ranging from budget to pro-gamer.
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail @ £41.99 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.00Ghz clock speed (AM3 Socket)
- Multiplier unlocked
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 3yr Warranty
- Retail Boxed with Heatsink & Fan
Was £44.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £157.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £167.99 Inc. VAT
Only £157.99 inc VAT.
ORDER NOW
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard @ £57.98 inc VAT
The GA-880GM-UD2H introduces revolutionary Gigabyte Ultra Durable 3 Classic technology on AMD platform featuring a 2oz copper PCB and further helps to reduce the system temperature and dramatically enhance the performance. Based on AMD 880G chipset, the GA-880GM-UD2H is integrated ATI Radeon HD 4200 (DX10.1) graphics engine and supports AMD Phenom II quad-core processors, DDR3 memory modules, HyperTransport 3.0 technology links, PCI Express 2.0 graphics interface and more. With the innovative Gigabyte Easy Energy Saver technology, GA-880GM-UD2H is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
- AMD 880G Chipset with 6 core support
- Hybrid Crossfire Support
- Onboard GFX with HDMI output
- MicroATX Form Factor
- 3 Year Warranty
Was £69.98 Inc. VAT
Only £57.98 inc VAT.
ORDER NOW
MSI P67A-GD65 Intel P67 (socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** with FREE Coolermaster Hyper 212 Plus CPU Cooler @ £124.99 inc VAT
Was £139.99 Inc. VAT
Only £124.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/4GX) @ £34.99 inc VAT
Kingston's KHX1600C9D3X2K2/4GX is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/4GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (2GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was £39.99[OLDPRICE] Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
Samsung SpinPoint F4 EcoGreen 2TB SATA-II 32MB Cache - OEM (HD204UI) @ £51.98 inc VAT
Samsung's F4 EcoGreen is the first drive available to feature 667GB per platter. Samsung’s F4 Series EcoGreen Drive (F4EG) is the ideal high capacity drive for green computing environments. The new eco-friendly hard drive, F4EG is designed to meet demand for high performance devices with lower power consumption. Samsung’s EcoGreen F4 makes it possible to design storage systems with the right balance of high capacity, fast performance and energy conservation. Samsung F4EG has the world’s best areal density at 5400RPM rotation speeds. High density means more bits pass under the head faster, and it improves the drive performance. Samsung employs an advanced data recording technology, which brings the next generation technology into today’s single disk platform, enabling Samsung’s new 5400RPM drives to perform at current 7200RPM drive speeds. The internal SysMark test results confirms that F4EG performs as same as 7200RPM drive speeds, and even 10% faster than other green drives.
- Capacity: 2TB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 5400RPM
- Seek Time: 8.9ms
- 3.5" Drive
- Warranty: 3 Years
Was £59.99 Inc. VAT
Only £51.98 inc VAT.
ORDER NOW
OCZ Agility Series 30GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1AGT30G) @ £44.99 inc VAT
Offering your system the incredible performance of flash-based storage, the OCZ Agility Series delivers the performance and reliability of SSDs at less price per gigabyte than other high speed offerings currently on the market. The OCZ Agility Series is the result of all the latest breakthroughs in SSD technology, including new architecture and controller design, blazing read/write speeds, and 64MB of onboard cache. Designed for ultimate reliability, Agility Series SSDs have an excellent 1.5 million hour mean time before failure (MTBF) ensuring peace of mind over the long term. All Agility Series SSD drives come backed a two year warranty and OCZ’s legendary service and support.
- Capacity: 30GB
- Cache: 64MB
- Read: Up to 185MB/sec
- Write: Up to 100MB/sec
- NAND Flash: Multi-Level Cell (MLC)
- Low Power Consumption
- Lightweight (77g)
- Shock Resistant
- RAID Support
- TRIM Support
- OCZ Garbage Collection
- Warranty: 2 Years
Was £49.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
OCZ StealthXStream 2 700W Power Supply @ £52.99 inc VAT
The new StealthXstream II strikes the right balance between mainstream power needs and high-performance build quality to deliver unprecedented value. Designed for both gamers and mainstream power users in mind, key features of the sleek StealthXstream II include a thermally controlled 120mm double-ball bearing fan maximum airflow at near-silent audible noise levels, exceptionally well regulated electrical noise and ripple for stable operation, an ideal array of connector types for each wattage, and excellent efficiency, converting up to a full 82% of AC to DC power at typical loads. The StealthXstream II Series from OCZ is fully compliant with the latest ATX12V and EPS12V specifications.
- Series: StealthXstream II
- Type: ATX12V V2.2 / EPS12V
- Wattage: 700W
- Fan Size: 120mm double ball-bearing
- PFC: Active
- Main Connector: 20+4-Pin, +12V Rails: 4, PCI-E Connector: 1 x 6-Pin, 1 x (6+2-Pin) PCI-E, SATA Power 8
- Efficiency: Typical load 82% Efficiency
- Energy Certifications: 80 PLUS Certified
- Input Voltage: 100 – 240V
- Input Frequency Range: 50/60 Hz
- Output: +3.3V@25A,+5V@25A,+12V1@18A, +12V2@18A, ,+12V3@18A, +12V4@18A
- [email protected],+5VSB @ 3.0A
- Dimensions: 15cm x 8.5cm x 14cm (W x H x L)
- Connectors: 1 x Main connector (20+4Pin), 1 x 8 (4+4) Pin, 1 x 6-Pin PCI-E, 1 x 6+2-Pin PCI-E, 6 x Peripheral, 8 x SATA, 1 x Floppy
- 3 Year Warranty
Was £60.98 Inc. VAT
Only £52.99 inc VAT.
ORDER NOW
Samsung SH-B123L/BSBP 12x BluRay ROM / 16x DVD±RW Lightscribe SATA-II Optical Drive - Black (OEM) @ £49.99 inc VAT
True 1080p Full HD technology is more than just entertainment, it's an experience. And it's the pinnacle of picture quality, engulfing and entertaining you with spectacular detail-rich, eye-popping colours and super-sharp, ultra-realistic images that enhance anything and everything on your screen. With our Blu-ray drives, you'll feel like you're seeing your favourite movie for the very first time.
Blu-ray lets you get the most out of your movie watching, so shouldn't you get the most out of Blu-ray? That's where BD Advisor comes in. It lets you unlock the power of interactive high-definition movie viewing with PowerDVD and Blu-ray Discs. BD Advisor helps you test your system and understand Blu-ray basics as well as suggest upgrades. Now you can always enjoy the best Blu-ray has to offer.
Breathe new life into your movie collection with Samsung's up-scale technology. It gives your standard definition DVDs a dramatically different high resolution look. And it gives your movie-viewing experience a cinematic boost. By up-scaling, your favourite DVDs will feature the same brilliant details and rich, robust colours you've come to enjoy from the high definition content on your HDTV.
Write Speeds
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 12x
- BD-R: 8x
- BD-RE: 8x
- BD-RE DL: 6x
- DVD: 16x
- CD: 48x
Was £59.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Corsair Hydro H60 CPU Cooler with free Akasa Apache Fan (Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3) @ £54.98 inc VAT
The Corsair Hydro Series H60 is a fantastic choice for cooling. With a new micro-channel cold plate and a split-flow designed manifold, the H60 brings remarkable new technologies to an affordable price point. If that weren’t enough, the H60 also features an all-new fan, custom designed to offer enhanced static pressure, which means better cooling.
You don’t have to sacrifice performance to build a quiet system. Most high-performance coolers use crude, outdated designs that rely on two techniques: put a huge hunk of metal in your case or crank the fan to obnoxiously loud noise levels. The Hydro Series coolers feature innovative, cutting-edge designs that utilize the superior thermal conductivity of liquid over air to provide fantastic cooling at much lower noise levels. In fact, the H60 is similar in noise levels to a 120mm case fan you probably already have.
Almost any case with a rear 120mm fan mount location can house the Hydro Series H60 CPU cooler. And don’t worry about compatibility with your CPU, we’ve got you covered. AMD® sockets AM2 and AM3 are covered, and without having to install a custom backplate, making the H60 a great choice for any modern AMD CPU up to the new Phenom six-core processors. And when it comes to Intel®, don’t worry about it. Whether you’ve got Socket LGA775, LGA1155, LGA1156, or LGA1366, we’ve got compatibility inside the box. That’s right, even the brand new Core i5 and Core i7 2x00 series processors are supported, right out of the box.
- Socket LGA1366 / 1155 / 1156 / 775 / AM2 / AM3
- Radiator Dimensions: 120mm x 152mm x 27mm
- Fan Dimensions: 120mm x 25mm
- Fan Speed: Up to 1700 RPM
- Fan Airflow: 74.4 CFM
- Fan dBA: 30.2 dBA
- Fan Static Pressure: 3.2mm/H20
- Cold Plate: Copper
- Radiator Material: Aluminium
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum. The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It’s powerful, quiet and tough!
- Super silent APACHE fans in Black Stealth colour
- S-FLOW fan blade design delivers 30% higher airflow
- IP-54 military standard moisture and dust protection
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension 120 X 120 X 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 -1300 RPM
- Max airflow 57.53 CFM (97.74 m3/h)
- Sound level 6.9 -16.05 dB(A)
- Max static air pressure 26.40 mm-H2O
- Rated voltage 12V
- Connector PWM-4pin
Was £59.99 Inc. VAT
Only £54.98 inc VAT.
ORDER NOW
Cooler Master HAF 912 Plus Case - Black @ £54.98 inc VAT
Cooler Master adds another new member to the HAF series, the HAF 912 Plus. To carry the mission of providing the best thermal solutions, HAF 912 Plus supports two 120 mm for external radiator and high-end CPU coolers. Furthermore, the spacious interior accommodates two 200mm fans and two-- 120mm fans for better and superior airflow yet, enough to fit 12 devices and high-end GPUs such as Radeon HD5970 and Nvidia GTX 480.
- Superior cooling performance support up to two 200 mm and two 120 mm fans
- Front 200mm fan with brilliant Red LED provides the best airflow to HDDs
- Removable 3.5”HDD cage provides enthusiasts more convenient installation
- Customized neat cable management
- Dimensions 230 x 480 x 496 mm (WxHxL)
- Weight: 8,45 kg
- Motherboard Support: ATX, Micro-ATX
- Front Cooling: 1x 200 mm (19 dB(A), 700 RPM, Red LED) or 2 x 120mm fans (optional)
- Top Cooling: 1x 200 mm or 2 x 120mm fans (optional)
- Rear Cooling: 1x 120 mm (17 dB(A), 1.200 RPM)
- Side Cooling: 1x 140 / 120 mm (Optional)
- 5.25" Drive Bays: 4
- 3.5" Drive Bays: 7
- 2.5" Drive Bays: 4
- Expansions Slots: 8
- Front I/O Ports: 2x USB 2.0 / 1x eSATA/ 1x Audio In/Out
- VGA Card Size: Up to 39 cm
Was £59.99 Inc. VAT
ORDER NOW
Sapphire ATI Radeon HD 5850 Extreme 1024MB GDDR5 PCI-Express Graphics Card **OcUK Exclusive** @ £99.98 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 725MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 128.0GB/s
- Processing Cores: 1440
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- 2yr Warranty
Was £124.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
OcUK GeForce GTX 550Ti OC 1024MB GDDR5 PCI-Express Graphics Card @ £99.98 inc VAT
Designed with unparalleled levels of price/performance and more than 2x the DirectX 11 performance over competing GPUs, NVIDIA GeForce GTX 550 dominates the competition and offers amazing game realism on the latest DirectX 11 titles like Civilization V. Equipped with the latest industry leading technologies including NVIDIA 3D Vision, NVIDIA PhysX, high performance NVIDIA GeForce drivers, and more, GeForce GTX 550 has everything you need to spoil your senses.
- Gerforce GPU: GF116
- Core clock: 950Mhz
- Processing Cores: 192
- Memory Clock: 4300MHz (Effective)
- Shader Clock: 1900MHz
- Memory Bandwidth: 98.4GB/Sec
- 1x HDMI
- 1x Analogue
- 1x DVI
- Dimensions: 210x140x35mm (LxDxH)
- DirectX Version: 11
- OpenGL Version: 4
- SLI Support
- Warranty: 2 Years
Was £109.99 Inc. VAT
ORDER NOW
Creative Sound Blaster X-Fi Titanium HD Sound Card with FREE Creative Fatal1ty HS-800 Gaming Headset @ £154.99 inc VAT
The Sound Blaster X-Fi Titanium HD provides the highest quality audio playback of any sound card Creative has ever introduced and includes THX TruStudio PC audio technology, bringing together two of the most respected names in sound quality to provide an unparalleled audio experience on the PC. The Sound Blaster X-Fi Titanium HD features audiophile-grade components for high-quality playback of music, games and movies, including 122db SNR Digital-to-Analog Converters (DACs), the highest signal-to-noise ratio ever produced by a Creative sound card. Replaceable OP-amp provides the flexibility to further customize the audio experience through different sound coloration. If you are serious about your PC sound, this is the ultimate Sound Blaster experience.
- High-Fidelity audio performance D/A, A/D converter with SN ratio of 122dB with 0.001% (THD) distortion
- High quality audiophile grade performance components designed to eliminate noise, while dramatically improve sound field dynamics in high and mid tones
- Headphone out with 115dB, 24bit/96kHz support High-Definition (HD) quality sound for original playback
- Personalize sound field experiences with swappable OP-amp sockets
- THX TruStudio PC effects transforms your experience into a true High-Definition (HD) multimedia emotional journey
- Hardware-powered 3D positional audio and EAX 5.0 effects provide stunning audio realism over headphones and speakers
- ASIO recording support with latency as low as one millisecond with minimal CPU load. Dolby Digital and DTS encoding enables one-step single-cable connection to home entertainment systems, with included optical cables
Creative's Fatal1ty Gamer Headset provides power, precision and comfort for the serious gamer. The ergonomic, lightweight design, with padded velvet earpieces and headband, ensures a comfortable fit during extended gaming sessions. Weapons, positional cues and environmental audio effects sound fantastic through the high-quality drivers, with excellent bass response for powerful explosions. The noise-cancelling microphone transmits voice commands clearly to other team members, and it can be detached for easy storage or to use the headset like regular headphones. In the heat of battle this is the headset that won't leave people stranded - and that's why Johnathan 'Fatal1ty' Wendel, the world's best known pro gamer, uses it.
- Ergonomically designed and acoustically tuned for gaming.
- Padded headband and earpieces for ambient noise exclusion and comfort during long gaming sessions.
- Swivel joint earpiece design adapts to every user.
- Detachable and adjustable noise-cancelling microphone.
- In-line external volume control with microphone on/off.
- Excellent response for voice communications and dynamic in-game audio, with extended bass response for high-impact explosions.
Was £184.97 Inc. VAT
Only £154.99 inc VAT.
ORDER NOW
OcUK what on earth are you doing to me?
I think I might have to go for the P67-GD65 deal. Can't be bothered to wait for the Z68-GD65 and at that price it seems too generous to say no. Think I'll give myself til 4pm to make my mind up.
Free Cooler too :) You know it makes sense
Hmm.. If only my p55 gd65 hadn't blown up on me (literally) I would be getting the p67 version :(
WOW. That 5850 is once again a steal!! Well done.
Damn...was about to order the Antec Kuhler 620 but now you throw in the Corsair H60 with the extra fan!!
...does it come with screws to mount the extra fan or not?
How many of the 5850s you have ? Will it be possible to get them for tomorrow with sat del if I order in the next 2hrs ?
Just order 3 5830s for not much less elsewhere yesterday but I might be able to cancel just yet ...
nvm just called em and order was dispatched over an hour ago already....
DAMNNNNNNNNN hate my luck lol, also got mobo and psu from them just for the sake of ordering from one place for sat del.
Oh well, maybe next time, I'll take the HDD off you tho ! ; )
Hmm, H60 or a 2TB HDD.
Can sell either my 1TB or Titan fenrir to offset the hit to my wallet, arghhhh
DSR it and buy from us. You get all the money back from the other place.
