Samsung SM2233RZ 22" 120Hz 3D LCD Monitor - £27 off!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Samsung 3D 120Hz Monitor, now down to an amazing £164.99! Giving you a massive saving of £27!
Samsung SM2233RZ 22" 120Hz 3D Widescreen LCD Monitor - Black @ £164.99 inc VAT
The Samsung 2233RZ monitor boasts the refined, streamlined and unique design, in addition to its top-class performance, that consumers have come to expect from Samsung. The display is housed in a thin, glossy black bezel that is a stylish accent to any environment and provides a compelling 3D experience with incredible picture quality. Unlike many other widescreen monitors, the Samsung 2233RZ displays 5:4 and 4:3 images at accurate aspect ratios without enlargement or distortion.
- Screen Size: 22" Widescreen
- Resolution: 1680x1050
- Contrast Ratio: 20000:1
- Brightness: 300cd/m²
- Response Time: 5ms (2D) / 3ms (3D)
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x DVI-D
- VESA Compliant
- Dimensions: 516.8mm x 421.3mm x 208.7mm
- Weight: 5.5kg
- Warranty: 3 Years On-Site
- Note 3D Glasses not included, purchase these seperately from ALSO purchase.
Was £191.99 Inc. VAT
Only £164.99 inc VAT.
ORDER NOW
Yes - they are one of the better panels out atm for hardcore fps gaming - they are pretty decent panels all around infact, granted its 6bit TN with average viewing angles, but they calibrate as well as you'll get with a 6bit TN with good 6500K color accuracy and deep blacks along with a sharp image - shame you have to be close to dead on angle wise and theres dithering if you look for it. Build quality is solid (except for the base which feels a bit flimsy) backlight bleed is minimal, input latency very low and residual imaging (ghosting) limited. Very little else comes close for hardcore gaming i.e. playing Call of Duty or Quake games to a high level of skill - but I guess thats a fairly small market. Its pretty reasonable for 3D Vision as well but I don't rate that highly myself.
The LG panel which I guess you are referring to is good to but for fps gaming this one would have the edge for me despite the lower resolution.
Most of these panels get fairly close to optimal color calibration with these settings:
Red: 48
Green: 35
Blue: 41
Contrast: 75
Brightness: Your choice - 24-40 works well.
Actually no. :D
Its just it really bugs me when people read the marketing blurb and assume its accurate and factual. The given ms response is about as reliable as marketing contrast ratios.
