** This Weekend Only 11/06/2011 - 13/06/2011 ** Corsair XMS3 4GB 1600MHZ and OCZ Agility 3 60GB SSD!
20 Jul 2009
The bleak North East arm pit of Britain
Hello!
On This Weekend Only we have 60 units of the fantasticly reliable XMS3 performance memory from Corsair in the shape of the popular 4GB 1600mhz CL9 Dual Channel memory kit.
We also have 75 units of the OCZ Agility 3 60GB, the Worlds Fastest 60GB SSD!!
Both of these are sure to sell very quickly so be quick to purchase as they will not be around very long at all at this price!
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £32.99 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
- Sandybridge compatible (use sub 1.60v)
Was £39.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £88.39 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £99.98 Inc. VAT
Only £88.39 inc VAT.
ORDER NOW
SSD is a very fast drive! If it works of course :) got it last week for £95 only to return for RMA yesterday(cold boot issue and then I suspect to be a dead drive)
According to what OCZ told me, it may not work with ICH9R!
This is what I got from OCZ
Trouble Ticket ID: 191341
Description: AGT3-25SAT3-60G
Comment By: Eric Von Stwolinski
Comment: I strongly recommend upgrading to a Sandybridge based computer to get the full advantage of the drive. The drive will also work on ICH10R though at reduced speed, but it is not designed to work with the ICH9R which is two generations behind the current chipset that the drive was designed to run with.
Alternatively if you no longer want the drive I recommend contacting the retailer and they may be able to refund or exchange it for something else.
Regards,
[email protected]
So the "Backwards compatible with SATA-II" part in the description should also include "may not work if you have ICH9R" ;)
Regards,
[email protected]
Then why didn't OCZ warn other of these IMPORTANT GUIDES on the front page before purchase it. Pretty bad indeed. Still waiting for my OCZ Vertex 2 SSD to arrive from Germany after RMA for 6 weeks. :(
