I'm just wondering really, my amp blew up earlier. It's just an old 80's Technics amp, but I'm quite fond of it - so I'd like to get it repaired.
Normally I'd have a go myself, but I've had it apart and I can't find any bulging capacitors or burned resistors etc (basically whenever I turn it on the VU meter for the left channel maxes out and I get an almighty hum/signal).
Firstly I suppose, is it worth me buying a multimeter and having a poke around?, how easy is it to fault find?. (I've built a couple of cmos amps in the past, but it was basically solder by numbers..).
Or am I best handing it over the the local tv/stereo repair man?.
As an aside. It happened when I switched (amp) inputs between my on-board sound card and my m-audio 1010Lt. And a mixer that the M audio was connected to has recently died a death too.. Could these things be related?. How much power could an AGP card muster through the RCA cables?, and surely there's some type of failsafe employed. Confuzzled I am.. Hmm
They won't be at mains voltage however, in fact they should measure around 30-40v DC when the amp is switched on. This is the first thing I would check with the multimeter, and be careful not to short the pins while amp is switched on. You'll probably need to remove the PCB in order this.
